Question about Giorgio Armani Watches
How to change the year on your meccanico AR4218
How to change the year on Aramani meccanico watch AR4218 model
2 Suggested Answers
  • 2501 Answers
SOURCE: How to set the year for armani meccanico watch
The Armani site is not very helpful but try this one:-
The year should change when the month hand passes from December to January.
If you pull out the winder (it may need to be screwed out anticlockwise first), you should be able to find a position where the month can be changed. Wind the month hand passed December. If you need to advance it more than one year, then wind it backwards from January to December and then forwards again to January.
Posted on Jan 19, 2010
I bought aan armani meccanico watch and it is fast. The seller says it is normal and that all maccabico watches need time to adjust to the person using them.
No way man. A mechanical watch should be timed in the factory & the rate is in no way different on different people. They are simply hoping you will go away.
It will not be as accurate as a quartz watch, but you should be +/- 15 seconds a day on a product like that. They are not great, you are buying a name. But you still should get something for your money.
Feb 14, 2011 | Giorgio Armani Armani Meccanico watch...
How to install the timing belt on a ford focus 2.0 engine with a dual head cam?
mcdevito75 here, With the tools, Jacks and time and effort needed, It"s best and cheaper tohop do this $200.00 job, If your not familiar with this particular job, your looking at 4--6 hours, the shop does it in 3 hours.
Aug 19, 2010 | Giorgio Armani Emporio Armani Meccanico...
My ladies' Gucci watch, model 9000 L has an interm...
It can be fixed Penny, but you need to send it to a Gucci authorised repairer. See the link
Gucci watch service center Google Search
Feb 12, 2018 | Watches
Emporio armani AR0203 face glass broken need to replace
If you have no joy anywhere else, you could try the Aramani service center. Below is an extract from their web site.
"If you have questions about Warranty or Repair please contact us at:
800-277-4013 Available M-F between 8:00am – 6:00pm CST
customerservice@emporioarmaniwatches.com"
Mar 06, 2010 | Giorgio Armani Emporio Armani AR0203...
How to set the year for armani meccanico watch AR4218?
Jan 18, 2010 | Giorgio Armani Emporio Armani Sport Ar0532...
What battery number and type for a colt chrono
Depends on the year. Google however is your friend Google Breitling Source and the watch type and see which year yours is.
Assuming its a 2006 to 2010 model it takes a 394 battery. I suggest a google to Breitling source and look in the watch archives there.
Consider sending it to breitling UK, you have a watch worth at least many hundreds of pounds that is waterproof. If you nip down the local muppets he will change the battery and charge you GBP20 not GBP70 but he will not change the case seals or pressure test the watch to ensure the seals are doing their job. Worst case you write off the watch when it gets wet or when you next get sweaty which is the same thing.
Specify you want the battery change service only and thats what Breitling do.
Good luck whatever you do.
Oct 15, 2009 | Breitling Colt GMT 292/SLV/FGHT Wrist...
Need manual/User Guide for an ''Athletic Works'' watch, model V403
Dave,
If you hold the reset button you will see the number 12 flashing with an H next to it this is for standard or military time. To change it press the st/stp button. To go forward press mode.Then it will ask for the year set that then press mode.Now the date change it just like the Hour and year.then day do the same.Now timeSet that the same and it should work!
Apr 26, 2009 | Watches
Casio 2688 Wave Ceptor - No Display
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
Feb 23, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
236 people viewed this question
Top Giorgio Armani Watches Experts
Ansel Alberto
Ansel Alberto
Watchmaker71
Level 1 Expert
Are you a Giorgio Armani Watch Expert? Answer questions, earn points and help others
