Question about Briggs Stratton H7159 & Stratton® 5500, 10 HP Generator
It started but when i pluged in ti it it quit. has not started since. checked plug and it was loaded with gas. install new plug and tried. check spark and it appears eratic. pulled air filter off and it is spitting gas out of carburator. i have maybe 10 hours on this generator
  • 161 Answers
Sounds like the float is stuck, how long has it ben setting around? try some carburetor cleaner. spray the carburetor down. empty the fuel tank put fresh fuel with fuel treatment. you may have to remove the spark plug, pull starter string a couple of times to clear out cylinder make sure spark plug is dry put back in and try to start the generator.
Posted on Dec 10, 2009
My van want start not getting gas an fire to injectors
My van want start not getting gas an fire to injectors Melvin could be fuel pump weak or quit, have ti checked for fault codes, if they are present diagnosing will be easier..
Mar 23, 2016 | Cars & Trucks
Echo chain saw won't start tried new gas ran then quit plug is clean
check air, gas and oil ratio.... check high voltage to plug..
Sep 21, 2013 | Echo Garden
My lawn trimmer stalls out after running for several minutes
id Check the spark plug. If the electrode on the plug is worn , id replace the plug. Make sure you check the gap on the plug before, you install it. Id also check to see if the air cleaner is dirty, or not. If the air cleaner is dirty the engine can't breath. Is the gas old that's in the trimmer? If it is dump it out, an replace it with new gas/oil. Are you sure that you mixed the gas/oil correctly? Is there a choke button on the trimmer? Make sure that after you start the trimmer,an it warm's up a little you shut the choke back off.
Jun 01, 2012 | Garden
Will not start
If you have a spark plug wrench take out the spark plug look at it if it is all wet engine is flooded with gas,dry it and clean it if it is dry its not getting gas, try putting in a new spark plug. is there gas in tank , is switch on, is gas turned off, is the tank full, is the gas old and stinky? has the tiller sat for months carb may be plugged check ,engine oil level, try a little shot of engine starting fluid or gas sprayed into carb needle valve in carb may be pluged, float in carb may be stuck. tap on carburetor good luck
Jan 31, 2011 | Troy-Bilt Garden
On my TI-Inspire, when I go to start the calculator, it stops loading and gives me the message "Operating System not found. Install OS now." How can I fix this?
If you dont have the TI Computer Link Software you must download it from the TI site. Once it is installed plug you device into the computer and run the program. Select your device using the button at the bottom right of screen. Once selected click help then check for handheld OS update then follow on screen instructions.
Nov 17, 2010 | Texas Instruments TI-Nspire Graphic...
1993 volvo 760 getting gas and spark,but still wont start.
Its easy enough to check for spark but how are you checking that you are really getting gas. Are the spark plugs new. If so the check that you have the right ones. It is not uncommon for a parts guy to give you the wrong plugs . If the plugs are not new and the car was running fine with those plugs before all this happened and the plugs look fine now, no bad, black carbon deposits then lets move on . Did you just put gas in the car. sometimes you can get a load of bad gas, I mean water in the gas when I say bad. Been lots of rain lately and this does happen. Pull the plugs on the car and spray some starter fluid down the cylenders. Replace the plugs and turn the engine over. If it fire up for a second or two and then quits, I would start looking at the fuel system. The fuel solinoid relay, which would supply power to the fuel pump could be a problem. Be sure you are getting fuel in the cylenders.
Sep 18, 2010 | Volvo 760 Cars & Trucks
Stihl Gas hedge trimmer will not start after sitting idol for some time (4 months) with gas in ti.
Purchase a new spark plug. Pour all the fuel out of the tank and fill it with a fresh supply of fuel. Now, remove the spark plug and spray a small amount of carb cleaner in the combustion chamber. Quickly install the spark plug and fully close the choke, press the primer button 3 times and try to start it. You may have to do this several times until it starts and runs.
May 31, 2010 | Garden
Stumbles when u 1st accelerate,quits on take off
one it could be a valve not producing the right pressure.faulty emission system,or defective pcm or information system.i hope this helps.
Feb 09, 2010 | 1996 Saturn SL
Briggs Stratton H7159  & Stratton® 5500, 10 HP Generator Logo
199 people viewed this question
Top Briggs Electrical Supplies Experts
John Trevino
rlev_7
Level 1 Expert
 steve
steve
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
