Question about Sharp CV-P09FX Portable Air Conditioner
Air con trips off
My sharp portable air con trips off after like 1 minute. On the plug says dont operate unless problem is solve.
    New Friend:
    Problem Solver:
  • 6 Answers
To be honest I have recently purchased one for 20 bucks that was doing the same thing except mine is a 11500 btu cv-2p12sx and I figure out why it kept shutting off after 1 or so minutes I have no remote with mine and what you need to do is go to your unit while its plugged in and off press and hold the power button until it beeps and when it does unplug the unit from the wall let off of the button and do it again except this time when you turn it off keep holding the button in and plug it back in and all of the light should light up on your unit then it is ready to operate hope this helps they tried to charge me and tell me it was something else
Posted on Jun 22, 2013
  • 20 Answers
I think MCB isn't enough replace 20A MCB
Posted on Dec 10, 2009
When I put the plug in the wall it keeps tripping the fuse what can I do
hi ya
if its tripping the MCB on the consumer unit there could be several reasons,
The fuse in the plug is too low / high in the plug, as the Air con, requires more power on start up,
it is also worth checking the plug is wired correctly E N Live etc..
or the MBC is too low, normally sockets are 16 amp - if its lower check with a qualified electrician it will be noted on the MCB denoted sockets
if the air con is portable, or able to be plugged in else where try upstairs sockets or kitchen sockets as these should be on a different circuit - if it does trip on these the air con is faulty and dump or see if a qualified repair agent is local
but always consult someone who is qualified - simply doing the above should be fine,
Apr 13, 2015 | Heating & Cooling
Tip
How to stop portable air conditioner leaking water
I heard that some portable air conditioners can leak water from the unit after being operated for about an hour or so if they are not on a level floor. <br /> I solved this with my DeLonghi air con after discovering the floor my unit was on had about 1 - 2 mm difference from one side to the other. By buying a small builder's liquid level (like you use to keep a line of bricks aligned) I used a small piece of wood (ruler thickness) under one side of the air con and no more leaks! Hope this helps someone. Kez, Perth WA
on Jan 30, 2011 | Heating & Cooling
I have a fedders portable a/c unit and it works for five minutes and it then shuts down. The circuit braker does not trip and I plugged the unit on different locations with the same results. The unit has...
Thanks for your information that " The unit has very cold air".It's cut off by indoor coil sensor.
Reason for shut off in 5 minutes.(There are one or more reasons for the problem) Check as follows.
1. Evaporator coil,air filter and bower wheel full of dusty. Service your unit completely.
2. Check rpm of blower motor. If less rpm replace capacitor.
3.If all above is o.k and still problem means defective coil sensor. Replace it.
Hope, it's helpful?
Jan 19, 2011 | Fedders A6X05F2D Air Conditioner
Need manual for a heller portable air conditioner. Model: GUSTY10CO
I have a Heller Gusty10c0 Portable Air Con. When It hasn't been used for a while. I turn it on and it last about 10 minutes then just stops. Then when ever I turn it on it cuts out after about 30 secs to a minute. Can anybody help me please?
Dec 12, 2010 | Heating & Cooling
Brand new portable air con- burn smell
Two units, same plug, burning smell ... hire an electrician to check your wiring
Jul 19, 2010 | Sharp CV-P09FX Air Conditioner
Hi I have a sharp portable AC unit model CVp 10lc works for 1hour
I have the same problem. I have only used my unit 3 times. It keeps "triping" and shuts off. Also, I smell a plastic burning smell and the plug gets very hot.
Apr 02, 2010 | Sharp CV-P09FX Air Conditioner
I'm not getting cool air anymore
Is the fan blowing. If not check theGFI plug at the receptacle It may be tripped.
Jun 12, 2009 | Sharp CV-P09FX Portable Air Conditioner
Sharp CV-P09FX Portable Air Conditioner Logo
497 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
