Question about SanDisk Sansa e260 MP3 Player
Why won't my computer recognize my sandisk player.....i just plugged in the usb cable directly in the computer....but it's not being recognized.
  • 820 Answers
For the Sans e260, see the e200 series support site on "not recognized":
http://kb.sandisk.com/app/answers/detail/a_id/266/kw/recognize/r_id/101834
Solution 1 RESETTING THE DEVICE
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
NOTE: Resetting will turn the player off while it is frozen.
When RESETTING the player did NOT help
Solution 2
GOING TO MSC or RECOVERY MODE and next UPDATE FIRMWARE
STEP 1 GOING TO MSC MODE or RECOVERY MODE
For e200v1/e200R (Recovery mode only): Connecting in Recovery mode
For e200v2 (Force MSC mode only): Enabling MSC mode
Check your firmware, see the differences on next link:
http://kb.sandisk.com/app/answers/detail/a_id/193/related/1/session/L2F2LzEvc2lkL0NqNGJpNVBq
STEP 2 FIRMWARE REINSTALLATION OR UPDATE
ALL DATA ON THE PLAYER will be ERASED !
Method 1: Automatic, using the Sansa Firmware Updater
Method 2: Manual, downloading firmware from the Sansa Forum
For e200 series version 1 and 2 to the Forum e200 thread
For e200 series version Rhapsody to the Forum e200R thread
Need more help ? Just post a comment.
Posted on Dec 10, 2009
2 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sansa Sandisk e260.. not working
Sometimes you can try plugging the device into a different computer - the instant reformatting will cause the device to work on your original computer. But here are other things you can try (remember to substitute the REC button for the volume + button on the e200 series):
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
I just bought the usb connector for the sansa sandisk c150 mp3 player and my computer will not recognize it when I plug it in.
Make sure it is the right thing.
I tried to use an extension cable for
mine and It won't work with it.
I don't understand it!
No ext fine, use ext no fine.
It could be the wrong cable/connector.
PLEASE RATE YOUR ANSWER
Aug 13, 2011 | SanDisk Sansa c150 MP3 Player
My sansa clip is frozen on the blue flower
One issue that people experience with the Sansa Fuze player is that the screen turns white when they are trying to use it. If you experience this common Sansa Fuze MP3 player repair issue, you need to reset your player. Hold down the "Play" and "Power" buttons for about 20 seconds. The player should automatically reset.
MP3 Player Freezes
Another issue is that the player freezes. You may see lights on the player, but it won't do anything. Follow the below steps to correct this issue:
1. Use the above steps to perform a hard reset.
2. Turn the player back on, and slide the "Power" button upward.
3. Use the USB cord that came with your player, and connect it to your computer. Only connect your player directly to the computer. Don't connect it to a USB hub.
4. See if your computer recognizes that a device was connected to it. Or, look in "Devices and Printers" folder, and see if the device shows up in it.
If your device doesn't reset, and the computer doesn't recognize it, contact SanDisk for additional assistance. Or, you can attempt to repair the device yourself.
Repairing Internal Components
If your Sansa Fuze player is out of warranty, you can attempt to repair internal components. This is an "enter at your own risk" solution, but you may be able to fix the issue. If it doesn't work, or if you damage another component, you will most likely need to get a new player.
1. Shut off the device.
2. If you don't have one, purchase a case opener tool. This is a tool with an extremely small head that is used specifically for opening up small devices.
3. Place the head of the tool in the seam of the device, and rise up the faceplate. Do not do this forcibly, or you'll break the ribbon cable connected to it.
4. Remove the ribbon cable from the faceplate.
5. Examine the battery cable. If this connection is loose, your Fuze player won't turn on. Plug the connection firmly into the port.
6. Check the LCD screen connection. A loose connection here means that you can't see anything on your screen. Disconnect the cable from the port, and reconnect it.
7. Reattach the cable to the faceplate, and reattach the faceplate. Turn the device back on.
These Sansa Fuze MP3 player repair suggestions may not fix all issues. If your player is still not working properly, either take it back to the place where you bought it, or contact SanDisk for additional help.
References
Fixya.com, http://www.fixya.com/support/t4267400-sandisk_fuze_4gb_locked_lights_will_not
SanDisk, http://www.sandisk.com/products/sansa-music-and-video-players/sandisk-sansa-fuze
Jul 18, 2011 | SanDisk Sansa Clip MP3 Player
Computer does not recognize MP3 after reinstall
When you connect your mp3 player to your PC, it will appear in "My Computer" as a removable drive. If it does not, the USB port may be the problem. Plug a different device into this port to make sure it is working. If it is not, make sure you have all the drivers for your computer inastalled. Also try a different USB cable.
Nov 13, 2009 | SanDisk Sansa Clip MP3 Player
Operating System does not recognize San 230
What is your operating system? You may need to update your usb drivers.
Aug 28, 2009 | SanDisk Sansa m230 MP3 Player
My computer will not recognize my Sansa sandisk MP3 player. I tried to reset it, and when I get the "Please connect USB" message, it still won't recognize it.
Aug 26, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Where can I find a program to download for e250 to recognize my computer
you do not need a program to recognize your MP3 in your com puter, the things you should do is just directly plug your MP3 to the back of your CPU direct to the board, if did not wort jus try using other USB cable
Jul 01, 2009 | SanDisk Sansa e250 MP3 Player
My XP system does not recognize Sandisk Sansa e260
The XP did not recognize the device because I used a after- marked USB expander board that did not provide enough power to the device. Plugging to the Motherboard - attached USB port solved the problem.
Mar 20, 2009 | SanDisk Sansa e250 MP3 Player
Sansa c200 will not connect to computer via USB
Try add new hardware wizard.
Once it does not find it.
Tell the new hardware wizard to search for MTP device.
Jan 16, 2009 | SanDisk Sansa c200 MP3 Player
My sandisk c240 charges when plugged in but fails to be recognized on the computer
There is quite possibly a problem with the USB cable or the USB port on the computer, but try this shortcut force to force the computer to recognize the Mp3 player: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 23, 2008 | SanDisk Sansa c240 MP3 Player
Computer won't recognize device
Your probably using the extension cable that came with the unit, try plugging the device directly into one of the rear ports on your computer without the USB extension cable, it should recognize.
May 26, 2008 | Coby MPC895 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
515 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
