Question about Dell Inspiron 1525 Notebook
My dell inspiron 1525 has a black screen with a white cursor showing
  • Priscilla mcdaniel May 11, 2010
    Did you try swtching the display?
    Novelist:
  • 225 Answers
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Posted on Dec 10, 2009
  • Jazzhollo88 Jan 27, 2012
    Thank for your help...this method definitely worked for me.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 22 Answers
Solution 1) Try removing all the usb devices if attached then restart it,
Solution 2) Restart the computer on dell logo press f2 to enter setup menu. change the boot sequence > 1st bootable decvie to hdd >save it and restart your computer and it will work. :)
2 Suggested Answers
  • 998 Answers
SOURCE: Dell Inspiron 1525 stays black
Do you have any CD’s that came with your laptop? If so, look for one that has “Diagnostics and utilities” listed under the “Contents”. You will have to boot from that CD disk. To do this, power on your laptop and tap the <F12> key to bring you to the “One time boot menu”. Insert the CD and then select CD/DVD drive and hit <Enter> key. Select the “Run the 32 Bit Dell Diagnostics”. Next select the “Express Test” and see if any errors are detected. If no errors are reported, then your operating system software is probably the culprit.
Hopes this helps.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Posted on Oct 22, 2008
Dell Inspriron 1545- black screen no home screen
can you get in windows safe mode by pressing F8, and get screen? it might be a display driver
Jun 10, 2012 | Dell Inspiron 1525 Laptop
Dell inspiron 1525 shows black screen after dell logo?
The computer cant find a bootable device. Either your boot sector on your Hard drive is gone/damaged (most likely a virus) or the Hard drive failed. Start with booting with your windows disk and try to do a repair installation.
Nov 03, 2010 | Dell Inspiron 1525 Notebook
Black screen on Inspiron 1525
This is a common problem. The problem is probably a bad charger. Take charger to a repair shop and ask them to check it. If it is good then problem is inside the laptop and probably the power connector.
Please rate this answer as a rating is all we get for answers. Thanks
Apr 11, 2010 | Dell Inspiron 1525 Laptop
My dell inspiron 1525 webcam wont work with yahoo messenger
This is happening because the Dell webcam central is accessing the webcam at the same time as yahoo messenger. Click on start and click on Run(XP), Type MSCONFIG in start search (Vista) and you'll get the system configuration utility. Open it and go to the startup tab. Uncheck anything related to Dell webcam. Click on Apply and OK and restart the computer. If yahoo messenger shows a black screen uninstall Yahoo messenger and reinstall with the more recent version.
Aug 09, 2009 | Dell Inspiron 1525 Laptop Jet Black
In window vista show black screen with cursor
I have a dell inspiron 1525 ..the screen blacks out leaving the cursor only... hod do I remedy?
Nov 29, 2008 | Computers & Internet
Dell Inspiron 1525 Notebook Logo
3,180 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
