Question about TallyGenicom 6306 Matrix Printer
Incorrect hex codes for barcode printing Tallygenicom
I am trying to get our Tallygenicom 6306 matrix printer to print barcodes containing the invoice number on our invoices, but it only prints the invoice number where the barcode should be.
I am trying to create a code 3of 9 barcode using this hex code 1B10410802000006010101001B104208
1B40
jigeo
  • 57 Answers
SOURCE: zebra lp 2844 thermal printer
It sounds like it needs to be re gapped. Try this:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
Posted on Apr 24, 2008
  • 169 Answers
SOURCE: HUMMER VOLTAGE ERROR
There are two different Hammer Voltage errors on the 6306; Hammer Voltage 1 and Hammer Voltage 2.
Hammer Voltage 1:
One of the hammer drive circuits was turned on when it shouldn’t have been, so all printing has been disabled. The usual cause is a failed drive transistor.
Solution: Replace the Controller Board.
Hammer Voltage 2:
A high resistance coil fault has likely occurred in one or more of the hammer coils. Note: this fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Solution:
Check the hammer bank for defective coils.
Posted on Jun 22, 2009
  • 257 Answers
SOURCE: Gaps in barcode with Zebra S4M
The gaps run in the direction of the label feed? You have a bad printhead. Bad dots on the printhead prevent it from printing your format in the areas that you see the blank lines.
There is no easy fix other than replacing the printhead. You can prevent (or actually prolong the time between failures) in the future by periodically cleaning your printhead. It's recommended that you clean the printhead after every roll of labels. The printhead is underneath the hinged assembly. Over time, ribbon or adhesive from the labels builds up and causes dots to go bad - creating the blank lines you see. Clean your new printhead with rubbing alcohol.
Posted on May 17, 2010
  • 21 Answers
SOURCE: The print job for the TallyGenicom 6312 is a
Try to adjust the "Bar" setting in the Graphics menu. Here you can specify the density of the barcode. I have seen the best results using the Medium setting.
Posted on Dec 04, 2010
sysabed
tallygenicom 6312 not print nither from LB1 nor from serial
please help me
Posted on Sep 15, 2013
I am using Sage to print invoices, i installed a dot matrix printer to do this. The model is Panasonic KX-P2023. The problem is when i print an invoice, the invoice for some reason keeps printing the...
you need to change the paper size or font size in the software that creates the printout. if you can, do a print preview before you print to see if its going to try and print to one page
Mar 16, 2011 | Office Equipment & Supplies
The print job for the TallyGenicom 6312 is a coupon and has a barcode in it, and the barcode is not readable by the barcode reader. The printed barcode looks perfect. And, the barcode reader has no...
Jul 12, 2010 | TallyGenicom 6312 Matrix Printer
LQ 570 Printing garbled text
1st you cancel all the print jobs from the pc .
In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs.
Jan 12, 2010 | Epson LQ 570+ Matrix Printer
Cant print continuosly in epson lq300+
Sounds as if the format is wrong. You must set the paper format in the PC wordprocessor or invoicing software to the same size as the actual paper size of the invoice.
Jul 08, 2009 | Epson LQ 300+ Matrix Printer
Unable to do a reverse line feed
Describe your Epson LQ-2180 Dot Matrix Printer Problem
Apr 12, 2009 | Epson LQ-2180 Dot Matrix Printer
Hammer Voltage 1:
Hammer Voltage 2:
Solution:
May 07, 2008 | TallyGenicom 6306 Matrix Printer
TallyGenicom 6306 Matrix Printer Logo
73 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Clive
Clive
Kolbrun...
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
