My projection tv makes everything look green - Televison & Video
  • tllittlenik Dec 10, 2009
    its a sony KDS-r70xbr and i replaced the lamp but everything that suppose to be white is green. would it be possible one of my projection bulbs are out
  • Jan McZeal
    Jan McZeal May 11, 2010
    It is a convergence issue, a bad convergence IC. Please indicate brand and model.
    President:
  • 632 Answers
Your set is totally different and it couldn't be a convergence issue. It appears to be an HDMI connection issue. Cleaning the HDMI terminals thoroughly will resolve the problem.To verify, use a different connection or hook a different device to a different input connection on your TV.
In case the problem exists in all of the inputs please let me know.
Posted on Dec 10, 2009
Replaced projection bulb 2months ago, now everything is pink and green...what do i do?
Sounds like one of your optical screens are out more likly the blue one. In rear projection tv there are three screens that converges on the frount display screen that makes up the picture you see. The three screens are blue red and green. It may be that one is out or is out of alignment. If you don't have good knowledge of electroncis especially high voltage circuits it would be best to take it to a repair shop to have it fixed. The price of repair can range from vary high to just a few hundred. It may not be worth fixing depending on model, type and brand of tv. There are a few types of rear projection tv. Most common are crt, lcd.
Oct 10, 2015 | Televison & Video
The tv is all orange tv works well just that everything looks orange
Check ur signal input,u lost one color is green.Change all the signal input conections.still same problem,one ur CRT colors gun is dead green.
Jan 14, 2010 | Philips Magnavox 51MP392H Rear Projection...
Green Light comes on but no picture or sound
Check and make sure you have everything correctly hooked up to the TV such as DVD Cable or Sat recievers and make sure you are on the correct input.
Nov 02, 2009 | RCA R52WH73 Projection Television
EVERYTHING IN WRITING IS DOUBLE AND THE PICTURE IS DISTORTED
Hello Tim this is a very common problem with the projection tv set, the problem is coming from the convergence board with faulty ICs that have to replaced in order for your tv set picture to work properly,they do sell convergence repair kits for your tv set but i would not recommend this the reason being is that if you make a mistake while changing out a component your whole tv set is gone not going to work anymore so for this i would recommend for you to call a near by tv repair shop and have a tech come out and change this ICs for you, after you change this ICs from the convergence board your tv set should go back to working normal on the link below you can check out how a convergence board looks like thank you hope this helps.
http://bestbuy.partsearch.com/content/pages/tv-convergence-boards.html
Aug 29, 2009 | Sony KP-46WT500 46" Rear Projection...
Red and green shadow lines
This 3-D problem is because to failure of convergence out ICs failure in TV and convergence ICs will be replaced.
If TV is Sony KP-51WS500 then check D board for STK392-560 and replace 02 ICs.
Required parts are available in Part Store.
Mar 13, 2009 | Sony KP-51WS500 51" Rear Projection...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green tint to everything on my Samsung HDTV Digital 1080i television
I have the same problem here on this Samsung 40" LCD. its a 2007 model. everything was fine until recently. I had to reset my digital cable box. now the picture has the green tint. its ruined what was a nice tv, and it won't go away.
Mar 11, 2008 | JVC HD-56G886 56" Rear Projection HDTV
HDTV comes up green
there is a setting in the menu under setup i believe it is called "LABEL VIDEO INPUTS". check you owners manual. you need to make sure that the DTV input is set to YPbPr NOT RGB.
Feb 23, 2008 | Mitsubishi WS-55907 55" Rear Projection...
CONVERGENCE Problem cannot adjust ( green gun )
Compare your rgb voltages and your cathode voltages(green, red, blue) and also access your service mode settings. It might not be the STK-392-150 that is defective.
Sep 26, 2007 | Sony KP-43T90 43" Rear Projection...
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
