Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Kodak esp3 all in one home center is saying disconected but it is not
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
Remove the esp3 driver on the printer setup window the restart your computer to redetect the device. Also make sure that the printer has no error and also check the connections.
Posted on Dec 24, 2009
SOURCE:
Kodak software removal problem
Sure, its very simple. You log onto www.kodak.com/go/clear and follow the online prompts to run the clear tool.
May 04, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Can't use the scanner on my ESP3
Go to the following destination
C:\WINDOWS\twain_32
There should be a Kodak folder and a file named "wiatwain.ds"
If there is any other file or folder > Right cick on it > CUT > And paste it on the desktop
MAKE SURE THAT THE IN TWAIN_32 folder THERE SHOULD BE ONLY > Kodak and wiatwain.ds
Feb 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do I clean the print head for a kodak printer
This is for Kodak AiO printer that has home center software installed
1.On your computer, start the KODAK AiO Home Center software.
2.Click the Help (?) icon located at the upper-right corner of the Home Center window
3.From the Help toolbar, select Maintenance.
4.Click Printhead Cleaning, and wait for the printer to complete the cleaning.
If there is NO Kodak AiO home Center software installed
1. 5100 printer HOME CENTER should be use or open the printer access door wait for the printhead to move at the middle then close the printer access door forcing the printehead to eject ink on the printhead nozzle
2.5300 & 5500 printer press the MENU button > select CLEAN PRINTHEAD > then select BASIC/DEEP CLEAN
3. ESP3 printer [press and hold at the same time COPY and CANCEL button for atleast 10 sec or until the printer start moving]
Nov 13, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Wont print pics
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.
Aug 01, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak esp3 says ink is gone...its actually full and its saying theres no paper and there is im soo aggrevated please respond yo dmp4205882@comcast.net thanks
upgrade the firmware of the printer,before dat, go to www.kodak.com/go/printheadsupport.click on 3rd link on how to replace a printhead. then take cartridges out and printhead out, after 1 minute,insert printhead back into the carriage and install both cartridges, go to kodak aio home center on ur desktop and from there on mai ntenance under help and select printhead cleaning. then try to print.ur problem will be resolved
Jul 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak ESP3 will not print,I reloaded program it says printer is online, however when I click to print it does nothing, how do I correct this.
go to printers and faxes on ur windows xp or printing and features on vista from control panel of ur coomputer make sure that ur printer is check marked there and set as default if not,right click and set it as default if the printer is already set as default,right click,go to properties and an option says print test page if it prints, there is a problem with the software communication b/w printer and computer installing and uninstalling of home center will not solve the issue kodak will replace ur printer with esp-5 call kodak toll free number-1800 419 1909 for further directions
Jul 11, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
The kodak aio home center won't open getting error 1--2010 esp3 printer
if using vista try this:
Right-click on the Home Center icon.
Select Properties.
Select the Compatibility tab.
Click Run this program as administrator.
Click OK.
reply if does not work.........
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
KODAK AiO Home Center has encountered a problem
you need to uninstall the software and reinstall it, if you have not tried that. For XP Start-->control panel-->add/remove programme-->look for Kodak Printer software and uninstall it. For Vista Start-->control panel-->programmes and features and uninstall the software. Run the Kodak clear utility from http://unexpectedtwist4u.com/matthew and click on clear utility and you can either run it or save it first and then run it. Make sure to unplug the USB cable after uninstalling the software and reinstall the software from www.kodak.com/go/esp3downloads. Kodak phone support is open from 9 am to 12 midnight EST. Hope that works:)
Feb 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
198 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
