Question about Cell Phones
Solution #1: Throw this phone into dustbin. #2: Step1: Take a jar. Step2: Take your Nokia 3110C along with ALL its enhancements and memory cards and put all into the jar. Step3: Make sure the phone is powered ON and still restarting endlessly like mine is doing since last 8 hours. Step4: Bring gasoline and pour into the jar untill Nokia 3110C is completely immersed into gasoline. Step4: Unzip your pants and fill rest of the jar with urine(make sure you pee right on top of the Nokia 3110C and this **** logo Nokia written on it). Step5: Put a lil cotton on top of the jar. Step6: Burn the cotton with lighter Step7: Watch this **** burn to its complete extinction along with gasoline and the jar and feel your soul satisfied. Step8: Buy Sony Erricson or anyother phone for future. My phone is not restarting 3 or 4 times and then switching off but it is ONLY restarting since last 8 hours. It does not even let me go to the MENU where i can set the ******** Factory Settings.. It doesnot even let the Factory Settings take place if i do it with *#7780#. Before ANYTHING god damn thing happens, this **** RESTARTS.
  • ivan georgiev
    ivan georgiev May 11, 2010
    i so glad that you find solution of this problem. my question is can i use spirit or diesel ?
My nokia 3110c shows only nokia logo and after that only white screen . please help me what is the problem
follow these steps:
1) remove the back case 2) press the power on button 3) remove the battery (button still pressed) 4) insert the battery (button still pressed)
repeat 2-3 times, this will solve the issue...
if it helps plz vote it
Jan 16, 2011 | Nokia 3110 Cellular Phone
Write failed is coming when i transfer a file through bluetooth
step1. copy everything from your phone memory card in to system( for preventing data loss)
step2.Then format your memory
step 3.give full right to ftp access
step 4. the stored folder ftp folder should be your memory card
step5. then try to ftp connection and get files
for me it works fine
thanks- cahndru
Aug 11, 2010 | Nokia N97 Cell Phone
I forgot the password of micro sd card
better u download elock or ilock software from net in jar format..use tat software and lock ur folder
Jul 03, 2009 | Nokia 6233 Cellular Phone
Format code for nokia 3110 classic
Hi Friend,
There are 2 ways to format ur nokia 3110c
Step1.
1.hard reset
hard reset using this code *#7370# (ALL DATA WILL BE DELETED)
Step2.
1: Turn off your mobile
2: remove your memory card
3: Turn it on again
4: Go to Menu then Applications
5: there will be 2 folders games and collection
6: open each one seperatley and delete everything inside them>
7: Turn your phone off replace the memory card then Turn it on and have fun no more problems try it
Regards,
Ayyasam
May 30, 2009 | Nokia 3110 Cellular Phone
Automatic restarting problem with Nokia 3110c mobile phone
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Feb 12, 2009 | Nokia 3110 Cellular Phone
Formatting internal memory of nokia 3110c
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Cause 5 - MP3 files
Jan 14, 2009 | Nokia 3110 Cellular Phone
Memory card locked
please help me in unlock my memory card in nokia 3110c
Aug 08, 2008 | Nokia 3110 Cellular Phone
Memory card lock or Folder lock
Aug 05, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 classic
Solution 4 Nokia 3110c Restart
Those who still have this restarting problem on Nokia 3110c ... Im telling the solution again, step by step.
It ll work . you dont need to go 4 the firmware v5.05
If
ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings from the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now
ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off
ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Feb 11, 2008 | Nokia 3110 Cellular Phone
Cell Phones Logo
81 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
