Question about Emerson Audio Players & Recorders
My clock radio CK5250 was plug to a 220 voltage and no longer work. what would i do
You might of just blown the power supply / transformer inside of the unit, pull the back cover off and see if the transformer is blown, smells odd, and if you can read the fine print you might be able to replace just the transfomer. What voltage is it?
Posted on Jan 24, 2010
  • 603 Answers
If you mean a US 120 volt clock radio was plugged into 220 volts -
it's shot - not to be fixed
Posted on Dec 10, 2009
I have a kenmore 790.9021 electric range. The burners and broil world but the oven doesn't. Have changed the element with another and that isn't the problem. Clock and everything else works fine
Below is from the Sears website, you might happen to have the opposite half of the 220 volts working where your clock works and theirs didn't. The other possibility is that a relay or triac (electronic component) on the control board is no longer working.
Thank you for your question and I understand your concern.
Based on your symptom and details it sounds like a problem with the incoming power supply. The line one (L1) voltage supply is not likely supplying the voltage to the clock. When a burner is turned on, the line two (L2) voltage is passing through the burner and switch providing the line one voltage to the clock which will then power up. This could be caused by one of the two house circuit breakers dedicated for the range has tripped or your missing the Line One voltage supply to the range. It could also be an issue with the circuit breaker or the incoming voltage supply to the breaker or wiring issue within the range.
The first thing that should be checked and confirmed is the voltage supply to the range where the power cord is attached. There will be three terminals on the terminal block. The voltage must measure 220-240 volts when measuring across the two outside terminals. The voltage must also measure 110-120 across the center terminal to each outside terminal.
NOTE: I do not recommend measuring voltage unless you have experience and feel safe and confident in doing so; otherwise I strongly recommend calling a service technician to diagnose the failure.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician.
Sep 06, 2016 | Kenmore Kitchen Ranges
Had ck5250 for yrs accidently knocked it off nightstand and it is just dead. got a sony dream machine-sounds like ****. Want to buy another Emerson but only if it will sound decent
Barb, they are still out there, just google Emerson clock radio.
Show your appreciation and press the helpful button and follow me on fixya
Feb 17, 2016 | Sony Audio Players & Recorders
ICF C25
Most likely the clock radio is damaged beyond repair. If it can be repaired it may cost nearly a much as a new clock radio.
Dec 24, 2012 | Sony Dual-Alarm AM/FM Clock Radio with...
My Tivoli radio overheated and doesnt work anymore
This is not good, the voltage in Europe is 220 and normally the damage it creates to a 110 unit is catatrophic, the only suggestion I can make is allow a technician to check it to see if it can be restored to operational mode.
Feb 28, 2012 | Audio Players & Recorders
Bought a used iPal and it only came with a european compatible plug. I bought a US converter. Plugged it in and can't make sense of it. The radio doesn't work. When off, there's no green light....
If the radio has a European-style plug, it's probably expecting 220-volt power since that's their standard. If you got a plug adapter but not a voltage converter, the radio won't work because the line voltage is too low.
Check the radio for a ratings label which will tell you for sure what the radio expects. There may be a selector switch on the back which will let the radio work on our line voltage. Otherwise you'll need to purchase a voltage converter to use the radio.
Jun 20, 2011 | Tivoli (PAL) AM/FM Radio
Over-voltage connection - 220v - instead of 110v
That thing is fried.If you can do your own electronic repair,there are a few components where the plug comes in that would be cheap to replace.Without a solder gun and voltage meter though I would replace.
Jul 20, 2010 | Timex Auto-set Clock Radio
120 volt to 220 volt plug
it is sorry that the clock has been damged by high voltage so , it can not be repaired but you can replace the entire set
thank you
May 15, 2009 | Sony ICF-C318 AM/FM Clock Radio ( White )
Power supply
if you are in usa, you need 1-468-809-11 POWER UNIT input ac 110 volt and output 8.5volt dc
and if you are in uk, then
1-468-811-11 POWER UNIT input ac 220 volt and output 8.5 volt dc
bye.
Sep 08, 2008 | Sony ICF-CD855VSIL Clock Radio
Clock radio
Unless thate is an internal fuse it that blew, most likely it will be more expensive to repair than replace. The transformer primary winding is probably burned out. You have nothing to lose, take it apart and see if there is a fuse. If so, replace it with the EXACT same value as the original. If not, its not worth fixing.
You didn't say what the symptoms were, other than it didn't work anymore. I am assuming it is completely dead.
Please let me know if I can be of further assistance to you.
- Jim
Feb 13, 2008 | Audio Players & Recorders
188 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
