The computer green light comes on and then nothing happens. Have disconnected the power supply tried another power supply nothing. Tried connecting another monitor. Monitor screen says no signal. Can you help
  • 1 more comment
  • kmarrow29 Dec 10, 2009
    No the operating system does not load.
    Did all of that same thing happens
    removed a replaced memory modules . Get a beep then nothing
  • 2,567 Answers
Does your computer seem to load the operating system but not displaying anything on the monitor?
Posted on Dec 10, 2009
  • 1 more comment
  • Mohamed Omran Dec 10, 2009
    Try to re-seat the main system components, especially memory modules, video card, & any other cards installed in the PCI slots on the motherboard.
    You can also clean the contacts of these components as well as the PCI slots by using a non-oily contact cleaner, & leaving them for 15-20 minutes to dry before re-installing them back & powering up the computer.
    Also, notice if you get any beeps when powering up the computer.
    Please let me know of the outcome so that I could follow up with you towards the solution of this problem.
    Try removing the memory modules from the computer & power it up. Notice if you will get any beeps.
    Then, power it down, replace back the memory modules, remove the display card, power the computer up again & notice if you will get any beeps.
    Keep me updated.
    This means that your motherboard's BIOS is fine.
    Most probably, one of the expansion cards installed into the PCI slots on your motherboard is defective.
    Remove these cards one-by-one, powering up the computer each time to see if it will work. Once the computer works, you will know the defective card.
Power Light comes on, no function what so ever
Check to make sure that the FireWire or USB cables are
correctly attached and firmly seated in both the drive and
computer's FireWire or USB ports. Disconnect them, wait 30
seconds, and reconnect them. If the drive is still not
recognized, restart your computer and try again. If they are
correctly connected and your drive still does not power on,
trying using the optional power sharing cable, described in
section 2.3 Connecting the Optional Power Supply of the LaCie Mobile Hard Drive User Manual.
Feb 17, 2013 | LaCie Computers & Internet
Hello, Last night I shut down my Dell E510 desktop - the proper way - by going to the start menu, shut down, turn power off. Then, today, I pressed the power button on the front of my tower and...
This sounds like a definite power issue. This means that the problem could range from being as simple as the power button itself not working/disconnected to the power supply being dead.
Things to try:
1. Have the side of your computer open and press the power button. Notice if any fans start to move or anything that happens.
2. Do you notice the Hard drive light flashing at all when turning on?
3. Has anyone else been using or been close in proximity to the computer that could have bumped it, causing something to come loose?
4. ONLY if you feel competent enough, check the cable connections inside the computer. Make sure to disconnect from the wall for 30 seconds and reconnect before touching any cables inside. Leaving the cable connected allows the computer case itself to act as a ground to prevent static shock.
Dec 23, 2010 | Dell Dimension E510 PC Desktop
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
I have a HIPRO HP-305 power supply. The green
the 4 pin connector is for cpu power. the hipro power supply are not very reliable.
Jun 14, 2017 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Gateway 3200S will not power up.
i have a big feeling its the mother board
Jun 04, 2009 | Computers & Internet
Flashing Green Light on Power BESTEC Power Supply
This is an easy fix so here you go nice and simple:
Problem: Your motherboard circuit has been cut.
Causes: Power disconnected during operation. Power outage or short in the surge protector.
Symptoms: Flashing green light on both motherboard and power supply. System will not power on.
Solution:
Step 1: Ensure that both the power supply and the motherboard lights are flashing green, not solid or off.
Step 2: While the power is on, disconnect the power supply from the motherboard. This connection is the largest of the connections and should be listed as the 'P1' or 'Primary' power connection.
Step 3: Wait until the green light on the motherboard stops flashing and check to ensure that the green light on the power supply is now solid. If it is not solid, disconnect the power to the power supply and wait until the light turns off completely. Then reconnect, it should be solid now.
Step 4: While the power is on, reconnect the P1 connection to the motherboard and you should now see that the light on the motherboard is solid.
Step 5: Power on your PC. The problem should not persist.
Warnings: If the power supply light remains flashing after you have restored power to it while it is disconnected from the motherboard, it may be a system failure in the power supply itself requiring replacement. Always be careful when working with an active or live power machine.
I hope this helped! Good luck!
Jun 23, 2008 | Bestec (ATX-250-12E) 250-Watt Power Supply
Blinking green light on the back of hp pavilion
1. Your smps is OK for power supply
2. check the beep sound for RAM and Video card (If it is long beep the RAM is having and short and frequent the Video card) o
3. Remove RAM then start ssytem see the response shoutdown, clean the RAM place it back start the ssytem
4. Remove the CMOS battery or short the jumber for any setting in BIOS start the ssytem
5. Disconnect all the cables connecting motherboard including Hard disk except SMPS power supply to Mother board
Jun 22, 2008 | Computers & Internet
Motherboard fried?
the problem is your power supply, since the power supply have differrent output voltage there is 12volts, 3volts and so on. the 12volts output voltage is not giving enough power. you can determine this by detaching the 20pins from your motherboard coming from the power supply then power-on the power supply then use a jumper wire insulated but scraped both ends (conductor visible) then connect it to the green connector and the grey connector if the fan of the power supply doen't rotate then you 12volts output voltage is busted.
Oct 22, 2007 | EliteGroup 915P-A Motherboard
22 people viewed this question
k24674
jasbo
jasbo
