Question about Homelite Garden
I have a homelite 4618 chainsaw that will rev up for no reason.
slohry
  • 87 Answers
SOURCE: homelite cs3314 chainsaw
Here is a link to get you your parts list. Make sure you have your UT#
http://odref.com/homelite/chainsaw/index.html
Posted on Apr 09, 2009
  • 4088 Answers
SOURCE: homelite 4618 saw won't idle , stays at 1/2
Try backing the idle speed screw off (CCW) with the engine running. The speed should come down as you turn it. If nothing happens, then probably debris is jamming the throttle mechanism (not inside the carburetor). If this works, set speed just below turning the chain.
Posted on Jul 06, 2009
  • 15 Answers
SOURCE: homelite chainsaw engine rev to high
Check for an air leak between the carb and the engine. It has to be sucking air .
Posted on Nov 03, 2009
dontbother10
  • 2220 Answers
SOURCE: set carb homelite chainsaw mod ut 10939
No response to CR.
Posted on Mar 13, 2010
  • 4088 Answers
SOURCE: Homelite 10540 chainsaw 35CC chainsaw won't start when hot
Go to: http://www.drystacked com for a 12 page article on Walbro carburetor theory and troubleshooting. Check particularly, the position of the gasket in the lower chamber. Check the spark plug for blue, snappy spark when the engine is hot. If ok, place a small amount of fuel mix in the cylinder and try for start. If it pops several times, look to the fuel system. Check the fuel filter, air filter, and muffler for plugging. Does the primer bulb fill with fuel after several pumps? Check the fuel lines for decay or other damage. When the engine is hot, try not using the choke, but set the fast idle. Hope some of this helps!
Posted on Jul 14, 2010
Homelite 42cc model ut10580 high low jet set settings?how to ajust
try 1 1/2 turns from shut then adjust to get highest revs and richen it a bit till rpm slow. too rich is highest revs. and will burn piston if continued at too lean.
Nov 30, 2016 | Homelite Garden
I have a Homelite 45cc chainsaw that spits gas out of the carburetor intake. I have thoroughly cleaned out the carburetor. Also engine revs very high when it briefly turns on, then it dies.Any ideas
Carb needs some serious cleaning. Best to soak it in a dip for a day or so then remove, rinse, blow dry and reassemble. If that does not do the trick your only option is to replace it. Those things can be a royal PIA when they go bad.
Sep 30, 2016 | Homelite Garden
Where do i put the gas for ryobi 4618 chainsaw
tip it on the side and remove the white screw in plug next to the pull cord
fill with fuel
go google and type in ---ryobi 4618 chain saw --and watch the movie on u-tube
Jun 12, 2016 | Ryobi Garden
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
Spear&jackson chainsaw exhaustblocked would this not run at full rev's
IF THE MUFFLER IS BLOCKED, OR THE SPARK ARRESTOR IN THE MUFFLER OUT LET IS BLOCKED, THEN YES IT WILL NEVER REV FULLY
Feb 29, 2012 | Homelite Garden
Homelite chainsaw engine rev to high
you may have it running too lean. turn the high speed jet out until it starts to miss and then turn it in until it smooths out. hope this helps you
Nov 01, 2009 | Homelite Garden
What is th petrol and oil ratio for a homelite petrol chainsaw 33c- csp 3314
Generally you're looking at a 50:1 ratio on most chainsaws and I wouldn't see any reason the homelite should be any different. Usually it's one 2.5oz container of the oil mixture to one gallon of gasoline but check the label to be sure.
Jul 30, 2009 | Homelite Garden
Homelite 4618 saw won't idle , stays at 1/2 throttle. any ideas.
Remove air cleaner and run if ok clean filter and reinstall.Please rate me .Thanks
Mar 16, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Problem oil doenst arrive at chain Homelite model CSP 4016 40cc
Remove your bar and free rev the engine, check that the oiler hole is pulsing and free from debris.
Feb 22, 2009 | Homelite Garden
Homelite CSP 3314 Chainsaw
starts no prob will not rev , just stalls when you try
Feb 11, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
122 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Homelite Garden Expert? Answer questions, earn points and help others
