Question about Epson Stylus CX5000 InkJet Photo Printer
INK DOES NOT FLOW. HOW TO CLEAN INK AREA.
EPSON CX5000 INK DOES NOT FLOW. HOW TO CLEAN INK AREA.
    Brigadier General:
  • 3,614 Answers
Here is a few steps to clean the print head of your printer.
1. Make sure the CX5000 Series all-in-one is turned on but not printing, and the ink cartridges are not low or expended.
2. Right-click the printer icon on your taskbar (in the lower right corner of your screen). Select Head Cleaning.
3. Click Start or Next.
Cleaning takes several seconds. The CX5000 Series runs a head cleaning cycle and the On light flashes.
Caution:
Never turn off the CX5000 Series while head cleaning is in progress. You may damage it.
4. When the On light stops flashing, make sure paper is loaded in the CX5000 Series, then do the following:
Windows:
Click Print Nozzle Check Pattern. Then click Print.
5. If there are no gaps or lines, click Finish.
If there are still gaps or lines, or the test patterns are faint, click Clean to clean the print head again.
If you don’t see any improvement after cleaning three times, refer to Problems and Solutions. You can also turn the printer off and wait overnight. This lets any dried ink soften. Then try cleaning the print head again.
Tip:
If you do not use your CX5000 Series often, it is a good idea to print a few pages at least once a month to maintain good print quality.
Cleaning the Print Head
Hope this initial / info idea helps.
Posted on Dec 10, 2009
Have an Epson Stylus CX5000 & A new iMac. OS X. I am unable to see what levels my ink supplies are with my Epson. With my old PC I could always see which ink was low or? What do I need to do to be...
If you are running the drivers included in the Mac OSX, you won't have levels. These are generic/running drivers only.
Hit this Epson site for current drivers.
Epson CX5000
Happy printing! :)
Aug 24, 2011 | Apple Computers & Internet
How to resit the cartrage of cx500
ill be happy to assist you on that.
sorry but there's no cx 500, maybe cx5000.
anyway,
1. Make sure the CX5000 Series all-in-one is turned on. 2. Make sure that the document cover is closed, then open the scanner. 3. Press and release the maint.5.10.2.jpg ink button. The On and maint.5.10.3.jpg ink lights flash. Note:
Do not hold down the maint.5.10.4.jpg ink button for more than 3 seconds or the printer will start to clean the print head. If one of the cartridges is low or expended, the CX5000 Series moves that cartridge to the maint.5.10.5.jpg expended ink mark. Go to step 4. If no cartridges are low or expended, the ink cartridge holder moves to the ink replacement position. Go to step 5. Caution:
Do not move the print head by hand; this may damage the CX5000 Series. Always press the maint.5.10.7.jpg ink button to move it.
Feb 16, 2010 | Epson Office Equipment & Supplies
Espon cx5000 printing problem
Try to reinstall your printer.
Check if you have installed the ink cartridge properly.
Clean your print head.
Make sure you are installing a original Epson ink cartridge and not just a refill ink.
Sep 10, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Epson cx5000
The problem may not be the nozzle on the cartridge, but the pin on the printer that connects to the nozzle. There may be better ways to do this, but it worked for me: remove all the cartridges and look into the docking bays; you'll see the pins sticking up. I use the word pin for lack of a better word; they're actually nozzles themselves. Take a paper towel and gently wipe off the pins until most of the ink is removed, then replace your cartridges.
I found all that the print utility clean function does is waste ink. Don't use it.
Good luck
Sep 18, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson styus cx5000
Go into Printers, Properties, Printing Preferences, then Black Ink Only. If you make that the default, it will automatically print black ink with you click on the printer in the toolbar. If you want to print one document in color, click on File, Print, Properties, and set it for color for that one job only. The default of Black Ink should stay the same.
Aug 28, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson stylus cx5000 series
i cleaned the post where the ink cartridge slides down on with alcohol. they could maybe be called the print heads i am not sure. but it is for sure this model cx5000 loves ink!
Aug 18, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus CX5000 blurry or smudged printing
epson uses pigmented ink and compatibles use dyes and thus if the paper is not of good quality then you can have this problem.
do the following
change the paper and try.
As there will be ink in the head and the ink feed tubes , print some 10 -15 copies of all color prints so that the original ink starts to get into the head and then the paper.
this should solve your problem
Also use your printer every 2 -3 days if you dont have any prints then give a noozle check and then switch off the printer. This will avoid the printer from doing a head clean very time you switch on the printer and also the ink will give you more output as there is less amount of head cleaning
bye
Aug 09, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
Dec 31, 2007 | Epson Stylus CX5000 InkJet Photo Printer
Epson Stylus  CX5000 InkJet Photo Printer Logo
462 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
