Question about Samsung SyncMaster 910MP 19" LCD Monitor
Brightness i have too much brightness on screen in case when using PC source, when using TV it's OK. There's nothing I can do with OSM. Have any idea what to do?
  • ftaci Dec 10, 2009
    Well, look guys, I open this monitor, change some capatitors, because they were bad (on power PCB), still bad. First thing i tryed was thet what you recomende.
    Thanks anyway, any other idea?
  • 285 Answers
Rightclick on your destop, and there should besome graphics options menu (not Windows display settings, but something with Intel, Catalyst or NVidia in the name. Open that menu and look for brightness options. They should be in there somewhere, but unless you ca tell what brand graphics card you have, I can't tell you where.
I hope this helps,
Yannick.
Posted on Dec 10, 2009
  • 585 Answers
Hi my name is Roety,
I can help you with your issue ,
there is a brightness adjustment within the video/display properties in windows.  Right click on the desktop left click on properties then Lft clk advanced then look for the adjustment in the tabs. Nvidia and ATI have different setups as does Intel .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Devant tv tech.model no.32DL410 power on but no display on the screen can you help me.???
Try goong to menu and check if brightness, color, sharpness, hue, contrast is set to 0. I have the same model, whenever I use USB in Source, those settings in menu automatically change. If thats the case, go ahead and change brightness to 50, contrast to 50, color to 50, sharpness to 2, hue to 50
Apr 04, 2017 | Televison & Video
Mitsubishi VS-50501A Rear Screen Proj. Picture is painfully bright and will not adjust.
check that the button is not stuck, if button is ok, then it is a faulty control board
Jul 07, 2008 | Mitsubishi VS-50501 50" Rear Projection...
How do i increase the screen brightness HP elitebook 8530p
Sounds like your keybinding/hotkey combo is not doing its job. (or your bulb in the display is going out)
You can open up Control Panel and adjust brightness from there.
Step 1 Click "Start ' Control Panel ' Hardware and Sound ' Power Options" to open the Power Options window.
Step 2 Click and drag the bottom "Screen Brightness" slider to the right to increase screen brightness and to the left to decrease it. Making this adjustment changes the brightness level only for the current power source; if you change power sources, the screen brightness may change again.
Step 3 Click "Change Plan Settings" on whichever power plan is currently selected.
Step 4 Click and drag the "Adjust Plan Brightness" slider to the right to increase brightness for each of the power sources, such as "On Battery" or "Plugged In." If you want high-precision numeric control, you need to access the advanced settings.
Step 5 Click "Change Advanced Power Settings."
Step 6 Click "+" next to "Display" and then "Display Brightness" to expand these options.
Step 7 Click "On Battery" and enter a percentage in the field provided. Choosing "100" will set the screen to maximum brightness; any other brightness will be a percentage of the maximum brightness. To increase the brightness, make sure the number you enter is higher than the current value.
Step 8 Click "Plugged In" and set its brightness percentage.
Step 9 Click "Apply" and then "OK" to close the Advanced Settings window.
Step 10 Click "Save Changes" to save any changes you made on the Edit Plan Settings page. If you only make changes in the Advanced Settings page, the Save Changes button will be grayed out. If that's the case, just click "Cancel."
Hope this helps!
Apr 28, 2014 | HP EliteBook 8530p Notebook
Screen black
Use the stock remote to cycle though the input sources.
Jan 13, 2014 | Philips 47PFL5603D/27 Flat Widescreen TV...
Hp probook 6460bMy laptop screen went completely off the laptop itself works just fine i even used it with the screen just a couple of hours ago before i left.but now i have to use an external screen with...
If you shine a bright light at the screen, with no external screen connected, and you can see a picture/desktop just around the light source, the ballast unit or flourescent back light maybe faulty. If nothing at all, check out flea bay for a replacement screen.
Dec 14, 2013 | Computers & Internet
Color calibration
All monitors have a brightness control. Click the menu button and from the on screen menu choose the brightness and set it to your liking. There should also be a contrast control and may or may not be a backlight control. All the user controlled setting are in the OSM.
Nov 27, 2009 | Computers & Internet
The 'hand' on screen
Make sure that the Sensor Bar is setup correctly:
Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
Verify that the Wii Remote is being used between 3 and 8 feet directly in front of the TV, and that the Sensor Bar is placed properly (see Sensor Bar setup).
Verify that there are no bright light sources, including sunlight, behind or near the TV, shining towards the Wii Remote or reflecting off the TV screen. Also verify there are no heat sources (such as electric, propane or kerosene heaters, flames from fireplaces or candles, stoves, etc.). If there are bright lights shinning directly behind the TV or on the screen, turn the lights off.
If problem persist your Wii Remote need service.
Oct 21, 2009 | Nintendo Wii Console
Just brought tv home and it is too bright. nothing i do changes it help me
try going into the menu of the tv and adjust brightness lower or in some cases flat screens have an option for picyure quality like , sports , movies , try putting it on movies and sometimes that will take away brightness
Apr 25, 2009 | Dynex DX-LCD32-09 LCD TV
Tube turns on nothing else does
If the Tv turns on (power supply is ok), screen lights up (inverters are ok) but don't get a blue screen, menu options, source options, or audio, it's most likely the main board (aka Motherboard) is faulty. If a DVD player is hooked upto the TV, check whether you can get audio from that (change the source using remote), in such a case it could be a problem with LCD Interface board. My $3 is on faulty Main board.
Jul 27, 2007 | Sanyo Vizon LCD-15A2 Television
Samsung SyncMaster 910MP 19" LCD Monitor Logo
186 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
ismael castillo
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
