Question about Samsung SGH-A707 Cellular Phone
Display screen inside has gone white-outside is working-where do i fix it and what would be the cost
Outside screen on env3 is broken, how much to fix it?
you have to change the whole cabinet of your phone it cost you approximately Rs. 600-700
Jan 30, 2010 | LG enV3 VX9200 Cell Phone
White screen when turned on inside and outside
The cable that connects the screen to the phone is damaged, causing it to white screen. Other than sending it back to the manufacturer or having Nextel fix it, there's no fix other than for it to be swapped out.
Nov 18, 2009 | Motorola Mobility i776 Cell Phone
Inside screen in black, outside is white
s see for software updations for your mobile in google & u can download it & install it in your mobile via data cable
Jul 17, 2009 | LG enV VX9900 Cellular Phone
N95 display gone suddenly........do no Y ? ??
cost would be very less dont worry try reloading thhe software
Jul 03, 2009 | Nokia N95 Cellular Phone
Mw22u monitor has white screen.
Manufacturer out of business. Local repair shops want more $ to fix than the cost of a new one.
Solution --- Trash old and replace with new display.
Mar 25, 2009 | X2Gen MW22U Monitor
Canon S2 IS - LCD screen is white after taking an outside picture
the image is all white or has lines through it.Definitely sounds like a repair issue, and has been a previous problem with the camera in the past. There is a defect in the sensor of the camera, and happens quite frequently in this model. I would try and contact Canon about it, and see if they'll repair it for free. If not, its probably going to cost more than the camera is worth to repair it.
Mar 24, 2009 | Canon PowerShot S2 IS Digital Camera
Inside screen broken
yes you can change out the screens if you have the ability to work on these if not you will have to send them to a repair person
Dec 12, 2007 | Motorola Mobility RAZR V3
Outside screen works inside does not
That's a problem with the dispaly of ur phone just go to service centre and let them check its a hardware problem. and at the dame time ask them to flash ur handset.
Oct 18, 2007 | Motorola Mobility RAZR V3
White screen
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything
Sep 03, 2007 | Motorola Mobility RAZR V3
SCP-7050 screen reads backwards like a mirror image
I had the same problem with my phone, had it fixed once under warranty a few months later had the same problem. They told me it would cost a fortune to fix, I was about ready to give up until i examined the phone a bit further, it seemed as though the contacts on the battery were somewhat worn, I simply packed some paper between the battery case and the top of the battery, seemed to fix the problem for now.
Aug 03, 2007 | Sanyo SCP-7050 Cellular Phone
Samsung SGH-A707 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
