Question about Toshiba 37HL67 37 in. LCD HDTV
Need tv help to get digital
I just bought a toshiba 37HL67 Its 37 " HD,LCD,tv. This Tv has the Integrated digitial tuning built right. in.(8VSB ATSC AND Quam. The digital stations I can't get to work.Do I need special cabLE wire and if so where Can I purchase it?Also How do I hook it up, thanks so much for your help Andrea
  • Chris Loar
    Chris Loar Mar 05, 2014
    You have to have the antenna on for the option to unlock.
You need to go to set up and on the far right menu there is an antenna setting. Can't remember the exact wording but the set comes set up for cable, just change it to antenna. After that run the channel setup.
Posted on Mar 20, 2008
6ya staff
SOURCE:
How can i tell if my tv is digital
The iLo IWT3206 TV provides two built-in -- or integrated -- TV tuners: a National Television System Committee (NTSC) tuner and an Advanced Television Systems Committee (ATSC) tuner.
While the NTSC tuner allows iLo IWT3206-viewers to receive analog, free-to-air TV broadcasts, the ATSC tuner allows viewers to receive digital TV broadcasts via a cable or satellite provider.
The benefit of having an integrated ATSC tuner is that it negates the need for a separate cable box or satellite receiver, which can take up space.
Oct 24, 2013 | iLO IWT3206 TV
Is my REGZA 42" 42HL167
This REGZA 42" 42HL167 has ATSC digital tuner built-in. when you set the TV to scan for channels, you must set the source to AIR, not CABLE. Since the Digital TV signals use the Old UHF band for transmission, your amplifier is made for this band? Try it without th amp first.
Please leave rating if it helps
Jan 31, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Does this tv have a digital converter box?
It has:
  • 37" HD Integrated LCD TV with NTSC/ATSC/PAL/SECAM Worldwide Tuner.
  • Per Amazon: http://www.amazon.com/SABRE-37-LCD-TV-LCT371BKA/dp/B001DL8OY4
    So you do not need the Digital converter box since it has built-in ATSC for off the air DIGITAL signal.
    http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
    http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
    Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
    Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
    Dec 01, 2010 | Sabre LCT371BKA LCD TV
    If these tv is digital why I need to use a converter box to see the channels
    Because it does not have a ATSC nor a Quam tuner in it. Just a regular tuner. As it says HDTV ready. This meant back when you bought it that it will receive HD when a hd cable box is used and connected to the DVI or the Component input in the back. This was a low end set at the time. It will still receive regular cable without a box.
    Nov 27, 2010 | Zenith E44W46LCD 44" Rear Projection...
    No digital picture for Sony KDL-40v2500
    These tv's receive digital on the atsc 8vsb. Do you know what there broadcasting in New Zealand ? It could be that a Sony tech there can fix your problem. The TV can be set-up for a different digital broadcast and Sony is all over the world even in New Zealand .
    May 04, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
    SWITCHING TV FROM NTSC TO ATSC USING THE REMOTE
    I need the model # to make sure you have an ATSC or QUAM tuner?
    Feb 17, 2009 | Insignia IS-LCDTV32 32 in. Television
    Is my Toshiba TV digital or analog?
    if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
    if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
    Jan 08, 2009 | Toshiba 24AF42 24" TV
    Tv Tuners
    Hey jp62388,
    According to information provided by the manufacturer, this model TV should have a built-in NTSC/ATSC and QAM tuner. These should allow you to receive locally broadcast digital TV signals without the use of a set-top box or digital converter box.
    If you're concerned about your TV's specifications, the most important thing you'll need to look for is a built-in or integrated ATSC tuner. NTSC is the old analog standard that is to be phased out in early 2009, while ATSC is the new digital standard that is to be used within the United States and Canada as NTSC’s replacement.
    Should you have any other questions or concerns, I'd strongly suggest checking out the FAQ section of the federal government’s official DTV transition website:
    http://www.dtv.gov/index.html
    Hope this helps you out.
    Sincerely,
    Aaron
    Go Ahead. Use Us.
    Jul 03, 2008 | Televison & Video
    Seting up the digital seems to be a problem, tv is tuned in, put digital doesnt? samsung 42" lcd plasma
    First I need to know if you have a digital quam tuner in the set? If you don't you will only get analog thru the tuner. You must use a HD box from your cable co. or sat. provider to receive digital channels thru your component input.
    May 08, 2008 | Televison & Video
    Toshiba 37HL67 37 in. LCD HDTV Logo
    201 people viewed this question
    Top Toshiba Televison & Video Experts
    matt martin
    matt martin
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
