Question about ASUS AI Lifestyle P5N32-E SLI (P5N32-E-SLI-GREEN) Motherboard
Hello, configuration: Motherboard ASUS P5N32-E SLI graphic: 2 x GTS 8800 RAM: 2 x 1 GB DIMM DDR2 non-ECC I want to update my RAM to 6 GB (+ 2x 2 GB Kingston) and it doesn´t work mwith existibg BIOS. I update my bios from 1201 to Bios Version 1801 .. Flash-Programm (bulit in Bios) reports "update sucsessfull - pc will reboot in 5 seconds" . The PC restarts and the screen stay black and PC doesn´t boot. When I start the PC fan starts, CD and Cardreader get checked in the POST but nothing elese. There is no possibility to ente4r the BIOS again. I need some help! Best regards Robert
  • 557 Answers
Hello
you have installed wrong bios update
noting are to do now buy new motherboard
Posted on Dec 10, 2009
WHATS HIGHEST RAM AND WHAT I CAN USE
2 x240-pin DIMM, Max. 4 GB, DDR2 667/533/400 Non-ECC,Un-buffered Memory
Apr 18, 2012 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
Want to add ddr3 memory to my p5qc board
Hello
The motherboard supports DDR3 1333/1066/800 MHz or DDR2 memory 1066/800/667 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3/DDR2 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 19.2 GB/s.
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel
2 x DIMM, Max. 8 GB, DDR3 1333/1066/800 Non-ECC,Un-buffered Memory 4 x DIMM, max. 16GB, DDR2 1066 / 800 / 667 MHz, Non-ECC, Un-buffered memory Dual channel memory architecture When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots! Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists). When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Hope this helps
Jan 19, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
I want to upgrade my from 512 to 2GB RAM. Pls let me know which brand RAM and speed will suport to upgrade the same. my motherboard is P5RD2-VM, with intel pentium D 820 processor. pls guide me on the...
Your Motherboard will support:
2 x 240-pin DIMM's (4GB Max)
Unbuffered
non-ECC
667/533/400 MHz DDR2
You should be pretty safe with any main brand name of memory from your local computer shop.
Below is a list of ASUS TESTED and Qualifed Vendor RAM.
Jan 02, 2011 | ASUS P5RD2-VM Motherboard
Asus p5ld2 deluxe ranlike a champ until I added 2 additional 1gb sticks of RAM itbeeps whenthe power is turned on but will notboot
it doesn't like the ram obviously,
  • 240-pin DDR2 DIMM Banking: 4 (2 banks of 2)
  • Chipset: Intel 945P
  • DDR2 SDRAM Frequencies: PC2-4200 and PC2-5300
  • Error Detection Support: Non-ECC only
  • Graphics Support: PCI Express x16
  • Max Component Density: 1024
  • Max Unbuffered DDR2 SDRAM: 4096MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR2 SDRAM only
  • USB Support: 2.x Compliant
  • make sure you installed the correct speed of ram, secondly if the ram speed is correct take out one sitck at a time, and try to boot, it's possible that one is bad from factory.
  • Jan 01, 2011 | ASUS P5LD2 Deluxe Motherboard
    My asus m3n78-em motherboard does not boots with 6 gb ddr2(3 chips of 2 gb) ram it works properly with 4 gb ram(2 chips of 2 gb) i dont know what to do it used to work properly before but its not working...
    This board has a dual channel memory. To function correctly both channels must be identical otherwise , as you can witness, it chokes. To put it simply you must put either 2 identical sticks of memory or 4 - it can't run on 3.
    Jun 16, 2010 | Computers & Internet
    I am using this ASUS (asus M2N-MX nvidia mcp61p chipset
    According to the manufacturer's web-site:
    http://usa.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
    this motherboard has 4 x DIMM sockets,
    supporting a maximum of 4 GB
    of DDR2 800/667/533/ Non-ECC, Un-buffered Memory
    and supports Dual Channel memory architecture.
    So, add one 512MB DDR2 533 Mhz RAM into one of the slots,
    being sure to leave *ONE* *EMPTY* slot between the two sticks,
    in order to enable the high-performance "dual-channel" option.
    Try your computer -- it should feel faster.
    If you still think that need more RAM, buy two 512MB (or two 1024MB) DDR2 533 Mhz RAM, putting the 2 sticks into the two empty slots.
    Dec 26, 2009 | ASUS M2N-MX Motherboard
    RAM capacity & Soundcard Driver can not be installed
    this is the ram specs.
    Max Supported RAM2 GB
    Memory TypeDDR2 SDRAM Supported RAM Speeds400 MHz · 533 MHz what sound card do you have ?
    Apr 01, 2009 | ASUS P5GC-MX/1333 Motherboard
    Problem in my asus motherboard
    I don't understand the exact problem you are facing but hope that you are getting your problem due to the processor. If possible, try with dual core processor.
    Feb 14, 2008 | ASUS AI Lifestyle P5N32-E SLI...
    ASUS AI Lifestyle P5N32-E SLI (P5N32-E-SLI-GREEN) Motherboard Logo
    190 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
