Question about Dyson Vacuums
Brushes not rotating - Dyson Vacuums
  • 701 Answers
You need to change the belt. You can get replacement belts here:
Replacement Vacuum Belts
Posted on Dec 10, 2009
My Shark rotator is very hard to push at times, easy at other times. What makes it hard to push and how do I fix it?
Does it have a "brushes" lowering/higher switch?
Normally due to brushes being too low in particular on deep pile carpets??
check the actual fixings for the rotating brushes are ok and the brush not simply need "clicking" back into place?
Feb 12, 2015 | Shark Rotator Professional Lift-Away...
Brushes wont rotate, no blockage and seal working perfectly. there is no difference when I turn on and off. but the noise when a turn on, for brushes to rotate.is louder. It was just turning slowly and...
I don't know what model you own, but all the models I owned did have a driving belt for the brushes. Usually situated at the bottom and can be accessed by removing the screws from the bottom cover. Hope this helps!
Oct 12, 2013 | Vacuums
Belt not broken.... brushes will not rotate.
most have two belts, brush roll rotates only when head is level with the floor....
Feb 19, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a Hoover Steam Vacuum, All Terrain, and the bristle brushes are not rotating. They appear to be seated properly and, the entire vacuum is clean and free of lint, hair etc., so everything is working...
I checked the owner's manual and the parts breakdown for your model F5807. Both showed that your model has a stationary brush strip and not rotating brushes. Is F5807 the correct model number?
May 18, 2010 | Hoover F5807 SteamVac Wet/Dry Vacuum
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes do not rotate
The brushes are turned by a turbine assembly, most likely the bearings have seized and will require replacement. not a job for the mechanicaly challanged, however this problem can be solved through a service shop
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Mar 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
6 rotating brushes
When you turn on the Vac with the brush strip NOT installed does the part that engages the brush strip turn at all? If so, when you install the brush strip see if the will turn when no pressure is applied to the brushes (tilt the Vac back). If none of this works, then the switch that engages the brushes when the unit is not fully upright may be broken. If the part that engages the brushes turns but won't turn when the brush strip is engaged then one of the parts that mate up it most likely stripped. Let us know what you discover!
Aug 23, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Sounds as though your drive belt has come off. Or you have an object stopping the brushes from rotating.
May 17, 2008 | Vacuums
Vacuums Logo
141 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Etronix
Level 1 Expert
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
