Question about Pioneer SD-643HD5 64" Rear Projection Television
Won't turn on
When I turn on the standby button it comes on, but the green light will not come on when I turn on the small power button
  • tharsing Sep 29, 2008
    I have the same problem, I checked the fuses inside the TV. I only found 5 fuses. All are in good order and none are blown. What now?
In most cases the fix for this is simple if you know how to test and find blown fuses. The same happened to mine and it takes 5 minutes to fix and $4 from radio shack.
1) turn off and unplug the TV
remove back panel from TV (like 5 to 10 screws)
2) locate the small fuses on the circuit board -- they are slightly right of center and kind of hidden behind taller componets. There are several, some "standard" size, some shorter GMA-type. In my case it was one of the shorter GMA 4 or 5 amp ones that had blown.
3) find the blown fuse with a test meter (no or limited continuity)or by taking each out and giving it a visual inspection. DON'T TOUCH ANY OTHER ELECTRONIC COMPONENT -- some parts can retain a electric charge long after the TV is unplugged and you don't want to get zapped!
4) replace with fuse of same type
5) re-install back cover.
6) enjoy!
As a note, while I was in there I cleaned my 3 CRT lenses, they where very dusty, used a Canon optic lense cloth.
Also, I have found that once my fuse blew for the 1st time it happens now periodically (once every 3 months or so), so I assume it is a symptom of a greater problem, however this fix is so easy and I keep extra fuses on hand that I haven't called tech to check it out (TV is kinda old anyway).
If you would like a better explaination than this, search the web because it seems to be a common problem and there are a lot of posts on it (www.hometheaterspot.com)
Regards
Posted on Jan 24, 2008
6ya staff
SOURCE:
Tv screen keeps going off and on how to fix it
Sounds like you have an intermittent power supply issue.
Feb 05, 2016 | Televison & Video
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
I have a Emerson 32" LC 320 EM1F, When I press power button, green light flashes 12 times then red light comes on and goes to standby. What seems to be the problem? How can I fix it?
It sounds that the main digital board has damaged. 12 blinks indicates it. if you wish to know more check this link for more details about 12 blinks to Emerson TVs
Jan 25, 2013 | Emerson Lc320em1f TV
Acer p241w stays standby
CHECK IN BIOS MODE ,THIS PC NOT GOES TO STANDBY SO PROBLUM IN YOUR OS .FORMATE PC NOW CHECK .
Aug 31, 2017 | Acer P241W 24 inch Monitor
PS3 wont power up
try another outlet if the light still will not turn green you will need to contact sony,
if the light does turn green let me know and we will get this fixed
Dec 24, 2011 | Sony Playstation 3 (PS3) Console
I have a RCA DVD Home theater system and I plug it in and the blue standby light comes on, but when I push it or other buttons on the unit, it just powers off and then won't turn turn back on at all....
I am having the same problem...i plug it in the standby light xomes on but i press the power button and nothing happens...mine is a rca rtd315wr model
Sep 03, 2011 | RCA RT2360 System
My screen will not power up. If I disconnect the current, wait a few seconds then re-connect - the standby light will go on. As soon as I try to turn on the computer - the standby light turns to green, a...
Hi rj05
I'm sorry to have to say this but you will have to take the monitor in to a repair shop. There is a definate hardware failure inside the monitor.
Regards
Go-Tech
Dec 15, 2008 | Computers & Internet
No lamp
whats your location, The power supply is faulty, but fairly easily repaired, if you send it to me, I will sort it out
Feb 13, 2008 | Hitachi CP-X327 Multimedia Projector
Pioneer SD-643HD5 64" Rear Projection Television Logo
147 people viewed this question
Top Pioneer Televison & Video Experts
Marvin
Marvin
Ekse
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
