Question about Nokia 1600 Cellular Phone
Handset is displaying than pin 2 code rejected
Handset is displaying than pin 2 code rejected for which i cannot do fixed dialling
    Guru:
  • 312 Answers
You can call to your network provider customer care and ask for puk2 code by using this you can unlock pin2 code . hope you will succeed....
Posted on Dec 10, 2009
Phone displaying 'Out of Range', no dialling tone
This could be due to the fact that one of your phones is off the hook or unplugged. Check and make sure that all devices are operational and charged.. Don't forget to check the phone line itseft.
Cheers
Jan 21, 2014 | Uniden 5.8GHz Expandable Cordless Phone...
What does Fixed Dialling Numbers mean?
Fixed Dialing Numbers or FDN list is a SIM card based security feature which allows the phone to be "locked" so that it can only dial certain numbers, or numbers with certain prefixes.
A PIN2 code (numeric password) protects the allowed list of numbers from being changed by any person who does not know the PIN2 code.
In FDN mode, your device will restrict outgoing calls, except for the numbers stored in the FDN list.
To activate FDN mode,
1.) In idle mode, open the application list and select Settings ? Call settings ? Fixed Dialling Numbers ? Enable FDN.
2.) Enter the PIN2 supplied with your SIM or USIM card and select OK.
3.) Select FDN list and add contacts to be used in FDN mode.
To De-activate
1.) In idle mode, open the application list and select Settings ? Call settings ? Fixed Dialling Numbers ? Disable FDN.
Warning: PIN2 is a serious SIM-based security feature of the handset. If you are not sure of your PIN2, please do not enter random PIN2. When you access a menu requiring the PIN2, you must enter the PIN2 supplied with the SIM or USIM card. Contact your service provider/ Network for your PIN2. If the wrong PIN2 code is entered three times in a row, PIN Lock(PUK2) will be automatically activated.
Oct 31, 2011 | Samsung I5500 Galaxy 5 Unlocked Android...
How tomake outgoing calls with my american telecom digital cordless phone model#ra23634H
Thuis was hard to find but it worked for my ra2364hh's
note the phone stopped working in "tone dial" after 2 months and now functions with "pulse dial" only.....
Registration The handset and base will be pre-registered with a digital security code identification, which is stored in the phone’s memory, so that your phone will be ready to work right out of the box. However, your phone also has a procedure to allow you to re-register in case the link is lost accidentally. Enter menu, press the key - Select REGISTER and confirm PIN CODE will be displayed, enter the PIN code (the default value is 0000) and confirm. SEARCHING will be displayed while your handset is in registration mode Press and hold the Page key for 3 seconds on the base until the “In use” LED is ON, putting the base in registration mode SUCCESS will be displayed. This means the handset has located the base, and will get a handset number from the base that displays after the handset name for internal calling. If the handset does not locate the base, FAILED will be displayed and it will return to the non-located display mode that displays BS SEARCH with the antenna icon flash. Try again and check that you are not in an environment with interference. Note: Your base can register up to four handsets. If you have more than one handset, repeat the above steps to register each new handset.
TESTED IT 2 minutes ago and it WORKS.....
tony
Feb 23, 2009 | Lands Phones
Where is the redial button on my KX-A144ES
you need to press the interlocking circles button on the handset (in the centre at the top) to show the last number dialled (incidentally, you can now press the down arrow to scroll through previous dialled numbers).
When you get to the one you want, simply press the green handset button to dial the number displayed.
That's last number re-dial in 2 steps (there is no single click solution)
Feb 06, 2009 | BellSouth GH5816 Cordless Phone
Pin code blocked and then sim card rejected
Hi
You can obtain the puk code by contacting your phone service provider.
If you have entered the puk code wrong too many times (tried to guess it) the sim card has disabled itself, and its useless, you will have to contact your phone service provider to obtain another sim card.
I've explained more about it here
Dec 30, 2008 | Nokia 6300 Cellular Phone
BT Studio 3100 handset 1. Display flashing base 1, cannot go to setup menu, not changed pin code, turned off and on, removed batteries, turned off base unit, waited 20-30secs for all of above and still...
Help
My Bt Studio 3100 cordless telephone ( 2 Pack ). I have carried out the setting up procedures as per instructions.
Handset batteries are fully charged, but I am not getting the dialling tone.
Jul 11, 2008 | Lands Phones
Nokia puk2 code remova
PUK it means pin unlocking key. so try ur service provider custmer care from other cell phone and tell ur mobile no, then u will get ur puk.no. it is eight digit no. which u will put in ur mobile while it ask fr puk no. then put ur pin no and repeat the same and u will able to use ur mobile phone. reply me if u get thru.
Jun 14, 2008 | Cell Phones
Uniden dect6.0 handsets do not operate
I am writing for my Mum, who is 99. We live far apart, so it is a bit difficult to fix her problem. She had a new Uniden DECT 60 (?) installed in early July. It seemed to be working fine when we left her, but she says it only rings twice before going to voice mail. She says it has always been like that. How can we fix this for her even though we live at a distance?.
Mar 12, 2008 | Uniden DECT 6.0 Cordless Telephone...
About puk 2 code
puk code can be found on on the simcard holder when you first buy them.they are written as pin code1 and puk code1,pin code2 and pukcode2.you can get your code on your subscriber,buy calling into their customer service hotline.this can only be done on smart sim users only
Feb 24, 2008 | Motorola Mobility W220 Cellular Phone
Nokia 1600 Cellular Phone Logo
227 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
