Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
Access code user has set the access code feature, but has now forgotten the code. How can you clear this setting?
    President:
  • 3,085 Answers
Press
Function
7
monitor key slowly 4 times
star key *
6
scroll down to SHIPMENT SET
set
wait for the machine to intialize
Posted on Dec 10, 2009
How do I recover a forgotten password for an overdrivepro63E wireless internet stick
Wireless networking is a common feature in homes and offices.
Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network.
If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu.
Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable.
Open your Web browser. Enter the default address of your router.
The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Enter your username and password.
Many routers use "admin" for the username and password by default.
Locate the wireless security settings.
Disable the wireless security.
Reset to Factory Defaults
Locate the reset button on your router.
Typically the reset button is a small indented hole on the back of the device.
Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings.
Locate the wireless security settings and add security as necessary.
Nov 05, 2013 | Computers & Internet
Master pin reset
We've received many emails from GPS users who say they have lost their PIN code.
For those of you that don't know what a PIN code is:
Some GPS manufacturers provide a feature, which allows the GPS owner to assign a unlock access code or PIN to their GPS.
The PIN is designed to prevent your GPS from being used by an un-authorized user. It was also meant to be used a a deterrent to thieves, making the GPS useless if stolen.
When you set up the PIN, you will be asked to enter in a code. After you enter the last digit, you will be asked again for the code. This is to make sure that both entries match and verifies that the PIN that you requested will be the one written into memory.
Your PIN is written into non-volatile memory..... it's not a file that is accessible via USB communications between the GPS and a PC. You can't clear it by disconnecting the power or disconnecting the battery or letting the battery run down. There is no jumper or switch inside the GPS to reset it, so don't waste your time tearing your GPS apart in an attempt to clear it.
Now, after you set the PIN, you will be asked to set the "secure" location. This can be anywhere.... your work location, home, local gas station, school, etc. In order to set the secure location, your antenna must be up and you have to have a satellite lock. If you don't have a lock, the "set" key will be grayed out until you acquire a lock.
The secure location is your "back-up key" in case you forget your PIN. If you have forget your pin, all you have to do is physically go to the secure location. Make sure your antenna is up and that you have a satellite lock. When you are in the secure location, your GPS will NOT ask you for the PIN when you turn it on. You'll then be able to reach the main menu and change the PIN and secure location to something else if you desire.
If you have forgotten both the PIN and secure location, you are out of luck. You'll have to send your unit back to the manufacturer to have it unlocked. The manufacturer may charge you for this service.
Note: If you do send the unit back to the manufacturer to be unlocked and you are found not to be the original & rightful owner of the GPS and it's determined to be stolen, the manufacturer may contact law enforcement (they're policy on this is right on their website under FAQ's).
Apr 27, 2013 | Garmin Nuvi 610 GPS Receiver
I forgot my password to open this jump drive.My computer will not let me gain access to any of my files on the disk. What can I do to access it again?
Retrieving a forgotten password on a Cruzer Enterprise drive How do I recover the password on my Cruzer Enterprise drive? Password hint
If you set a hint when you enabled the password protection, click Hint in the log in window to display the hint you entered. If you did not set a hint or still can not remember your password, you can click Forgot Password on the logon window and choose a new password. This will reformat the drive.
Reformatting will delete all files and applications in the user-accessible removable partition.
Password attempts
There is a limit of 10 attempts (default) before the drive is locked and no further access is possible. During this process, you MUST change the password and reformat the drive. This is an important security feature, protecting data in lost devices from brute force hacking attempts.
Cruzer Enterprise drive managed by CMC (Central Management and Control)
A drive managed by the Cruzer Enterprise CMC software can be unlocked remotely by the System Administrator when it is inserted into an online computer. The System Administrator can unlock the drive remotely even after the maximum failed password attempts has been reached. The user must then choose a new password. Data stored in the removable partition will be preserved.
If the device is managed but in an offline computer, the System Administrator can send the user a one-time unlock code. The user must enter the code then choose a new password. The existing data on the removable partition will be preserved.
hope this helps
Feb 27, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I can't turn off closed captions please help
Hello
There is only one way, and that is to unlock the closed caption feature by entering the code. By entering the code you have set to lock closed caption you can set it off. If you have forgotten the password you have entered, do the folloing ot unlock your TV, and then reset all the features later.
if you ever forget your
code, the 0, 7, 1, 1 code is the factory
default and can be used to
enter and create a new access
code.
After unlocking the code you have to reset all the settings again if you wants.
OK.
Dec 26, 2010 | Philips 32PT6441/37 32" TV
Change my aficioDSM635 language
A. Press the {User Tools/Counter} key.
The User Tools main menu appears.
Note
? When the key operator code is set, the key operator code input
display appears when changing the default settings. Enter the
registered key operator code beforehand.
For key operator codes , see "Key Operator Tools", General Settings Guide.
B. Press [Copier/Document Server Features].
The Copier/Document Server Features menu appears.
C. Select the menu you want to set.
The setting display for each menu appears.
Reference p.83 "User Tools Menu (Copier/Document Server Features)"
D. Change settings by following the instructions on the display panel,
and then press [OK].
Exiting User Tools
A. After changing default settings, press [Exit] on the User Tools main menu.
Changes to User Tools are complete, and the machine is ready to copy.
Note
? You can also exit User Tools by
pressing the {User Tools/Counter}
key
Dec 17, 2010 | Office Equipment & Supplies
Copier is located in an open area -limit users access
Well, most of the copiers are having dept code features where u can set access code for the copier. But the setting is depends on the brand & model.
Feb 24, 2009 | Xerox 5830 Copier
How do I enter the User ID codes for a Xerox CopyCentre 275?
The Tools menu is used to set up machine parameters. The menu is protected by a system password, referred to as the System Administrator password. The default system password is 1111.
NOTE: If the System Administrator password has been changed or forgotten, contact Support for additional assistance.
  1. Press the [Access] or [Access A] button on the Control Panel to enter the Tools Mode. The Login screen will be displayed.
  2. Enter your password using the numeric keypad on the Control Panel, and then select [Enter] on the Touch Screen. The Pathway Options screen will be displayed.
    NOTE: The default password is 1111. The password will be displayed as an asterisk (*). If you make a mistake, press the [Clear (C)] button on the Control Panel and re-enter the password. To cancel the operation, press the [Cancel] button. If you are experiencing problems with your password or have forgotten your password, contact your administrator.
Sep 09, 2008 | Xerox Office Equipment & Supplies
Programming feature access keys
These Keys may be set as line keys instead of feature access or not tagged as "feature access" in the programming, also you can only have so many feature access keys... 8 comes to mind but I could be wrong, some features can be programmed permanently onto a button in the main programming so you can free up some more feature access (user programable) buttons.
Jul 18, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Factory ringtones
Sir,
You can lock your phone manually or set the phone to
lock automatically whenever you turn it off.
To use a locked phone, you must enter the unlock
code. A locked phone still rings or vibrates for incoming
calls or messages, but you must unlock it to answer.
You can make emergency calls on your phone even when
it is locked (see page 68).
Locking Your Phone Manually
Find the Feature > Settings > Security
> Phone Lock > Lock Now
Unlocking Your Phone
Tip: Your phone’s unlock code is originally set to 1234.
Your service provider may reset the unlock code to the last
4 digits of your phone number.
Setting Your Phone to Lock Automatically
You can set your phone to lock every time you turn it
off:
Find the Feature M> Settings > Security
> Phone Lock
> Automatic Lock > On
If You Forget a Code, PIN, or
Password
Note: Your phone’s 4-digit unlock code is originally set to
1234, and the 6-digit security code is originally set to
000000. Your service provider may reset the unlock code
to the last 4 digits of your phone number before you
receive your phone.
Press To
1 keypad keys enter your unlock code
2 OK (+) unlock your phone
> Phone Lock
Master
Clear
Clear all user settings and entries
except SIM card information, erase all
downloaded pictures and sound files,
reset all options except unlock code,
security code, and lifetime timer:
M > Settings > Initial Setup
> Master Clear
Caution: Master clear erases all
user-entered information (including
phonebook and datebook entries) and
user-downloaded content (including
photos and sounds) stored in your
phone’s memory. After you erase the
information, you cannot recover it.
Thanks
Good Luck
Don't forget to rate the solution
Jul 05, 2008 | Motorola Mobility Mobile PhoneTools 3.0...
PICK UP GROUPS AND HUNT GROUPS
You will need to talk to the phone administrator. It needs to be set up in system admin.
Nov 08, 2007 | Avaya Definity 6408D Corded Phone
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
94 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
