Intermittent heat I have a Carrier (Payne) unit (FA4ANF030) with intermittent heat output. The air works as does the fan when in heat mode, but usually no heat. Sometimes it will suddenly begin to put out heat normally and will function fine...until it doesn't. The thermostat was old, so I replaced it first. Seems to make no difference at all since it works exactly as before.
  • Daniel Gooch
    Daniel Gooch Jan 19, 2008
    Sorry, it is electric heat only. I think that is just the air handler number. The heat unit listed is: KFAEH0401N10
    (I think this is the correct number to use.)
  • 104 Answers
Check wiring of heater, it may have loosed connection or corroded connection.
Posted on Jan 20, 2008
  • 447 Answers
It sounds like the unit has lost its first stage of Heat (It uses the outside unit to bring heat in with freon) When the thermostat is put 3deg higher than room temp it uses Heat Pump and heat strips, this is probably the only time yours heats. Have it checked as you will pay a lot on next month's electric bill.
Posted on Jan 19, 2008
  • joey  shearer
    joey shearer Jan 20, 2008
    Sounds like you have a relay issue with the heat strips then you will probably need a professional to diagnose and replace the faulty part unless you have a amprobe and volt-ohm meter, also a source to get a replacement part.
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - Community Forums > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from
Nov 01, 2015 | Heating & Cooling
My blower on my carrier furnace unit won't turn off? a/c or heater doen't turn on.
gas furnace??? check the start capacitor, put unit in ac mode and see if fan comes on(switch fan to on at thermostat) if it does not a fan problem or capacitor problem. when in cooling mode thermostat controls fan, when in heating mode, furnace controls fan
Feb 18, 2015 | Carrier Heating & Cooling
Carrier fa4anf030
Sounds like the reversing valve is the problem
The reversing valve is located near the compressor
It has four copper tubes coming from it
On this valve there is a solenoid which makes the valve open or close
You can check this by placing a strong magnet on it while the system is running which will activate or de activate the heating
You should hear a swoshing sound if it's working properly each time you remove the magnet if this doesn't happen it will need to be replaced by a licensed refrigeration technician if it does work you may have a gas leak which will require a friggy as well
Jan 04, 2014 | Carrier Computers & Internet
Air conditioner blowing warm inside and cold outside
it's a heat pump in the heat position . Check the thermostat to see if it's in the heat position. If not then the changeover valve on the unit is stuck.
Feb 08, 2013 | Carrier Payne 2.5 Ton Air Conditioner...
Heat/AC unit will not kick on.
sounds like spark ignition coil bad the little fan combustion fan will run even after a fail ign attempt.
turn off power/restore power the unit will try to fire the part is easilly avail and easy to replace
Jan 18, 2010 | Ruud UBHC Air Conditioner
Is it normal for fan on outside unit to be on while on heat mode
Yes, it is normal with a heatpump, you run the outside unit in cooling and heating.
It is also normal when the outside unit goes into defrost for the outdoor fan to shut off during the defrost mode and to see steam coming out of the outside unit, while it's melting the frost or ice, then the fan will come back on.
Jan 06, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Have a Payne A3PZ airconditioner and a Roberts Aire thermostate need help with wireing it up. The was I understand is that you need a Payne therostate to use with Payne AC unit. But surely there is a...
No, Payne is a cheap Carrier unit. Keep track of your wires and what terminals they are attached to. Usually, units are either a 4 wire or 5 wire setup. In either of these the R terminal is your 24v power, G term is your fan, W is your heat, and Y is your cool. Some times there is a 5 wire which is your common. You use a common if your thermostat isn't powered by a battery. On the R terminal, they are usually marked RC/RH and have a jumper between them. The only time you should remove the jumper is in a 5 wire set up. RC refers to the common and RH refers to Hot or power. Make sure that when you are installing the new tstat there is usually a very small switch that you change for either an electric unit or a gas unit. Change according to what you have. As long as you keep track of your colors and terminals on your old tstat, you won't have to open up your unit to see where the wires are terminating. Good luck to you!
Mar 22, 2009 | Heating & Cooling
My outdoor heat will not operate. It is a Carrier 38YRA042330, with a Carrier Thermidistat thermostat and a Carrier Air Handler 40FFKB005300. I have an H5 error code on the thermostat will I put it in...
you need to go oside and look for a red reset button on the unit. you tripped the high ressure switch when you let your filter get that dirty. go check on this and when your done if it still is not working then ask me more.
Jan 25, 2009 | Carrier Heating & Cooling
One Step Beyond Castlelakein's
I hate to admit it but this is a common problem with the Honeywell S86A control. If you can find a heating slpy house neat you that sells to the public your lucky, more than likely you will have to get it from a heating company. a carrier/bryant/payne/day&night (all made by carrier) should have one on hand.
Jan 02, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier RADCO unit FA4ANF030
the best thing to use is any alkaline base with water
Aug 16, 2006 | Carrier IBM UNIT 2380 79F4796 Drive Case
Heating & Cooling Logo
358 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
