Trying to boot up my Foxconn 945G7MA m'board. On screen shows a startup sequence for a Mitel Networks SME Server, continually restarts this sequence. What's gone wrong? RonG1
  • mjrg Dec 10, 2009
    Hi lala linda,
    I've put in a brand new 2GB chip of DDR2 800 RAM. All that is connected is a 40GB HDD, keyboard, mouse and DVD burner. When I boot up, it does a quick IDE scan and then goes into this SME Server boot up sequence. Hope this info helps. Rong1
  • Priscilla mcdaniel May 11, 2010
    Just an idea but you mite not have enough Ram in it sounds like ?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Dearest Rong1, mite try lower amount of ram your use to start sounds like to much to me..... linda
Posted on Dec 11, 2009
Foxconn 945G7MA-8EKRS2 Motherboard will not post with pentium d cpu ,i have even updated with the lates bios flash,
Good day,
According to Intel 945G chipset supports Celeron D up to Core2Duo. Intel Gigabyte's 945 DS3 even supports up to Core2Quad. GByte Foxconn has 3 mobo bios from there site. Foxconn
According to their date: Latest to oldest
4BFF1P56 No Version 4BFF1P40
Have you tried installing the no version bios? In my experience some latest bios have some problems with other devices so try to use the no version bios. or try a different mobo bios with the same chipset from Foxconn. below are two foxconn mobo models i can't see the difference.
945G7MA-8EKRS2 945G7MA-8EKRS2H
Update at your own risk..
hope this helps, thanks for posting.
Jul 01, 2011 | Foxconn 945G7MA-8EKRS2 945G P4/Pentium...
I have 2 IDE Hard drive but my board only picks one at IDE1 how to enable both at same time
you will have to set one as a slave or set as a raid pair
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
don
Feb 28, 2011 | Foxconn 945G7MA-8EKRS2 945G P4/Pentium...
Im trying to install agp...how do i disable the on board vga
Hi there.
Remember that if you are swapping from on-board graphics to a card you have to go into the BIOS and tell the machine that the primary graphics adapter is AGP/PCI Express.
Plug the VGA cable into the on-board graphics port, start the computer and enter the BIOS, tell the computer to use the AGP/PCI card as primary, press F10, save the changes and exit the bios.
The computer will try and restart so let it boot to post and turn it off, then put in your card and try to boot again.
Please post back if you need more help or advice.
Good luck and thanks for choosing FixYa!!
Jun 04, 2009 | HP Compaq Motherboard
No on board graphics after power up.
there are only a few things i can think of that might help. recheck to make sure all of the power supply cables are plugged in, although im sure that you've allready done that. you don't wan't to clear cmos due to the fact that you only do that if you are going to reflash it. could mke it unbootable. try going in to cmos and enabling quick boot this bypasses POST test and might get you in. also try reinstallling the Operating system as this load drivers for your display. the only other thing is you might have recieved a faulty motherboard, this happens mor frequently than you might think.
hope this helped.
please rate good.
best of luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 02, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Setting boot sequence
press Del or F2 or Esc while booting ..
Feb 17, 2009 | Systemax ™ Mission Xeon™...
Startup fault
Software Error Or Corrupted windows File files
Jul 15, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Foxconn 945P7AA-8KS2
Well to start, you do not give enough info ,for example what was you doing to the pc when this happened,was you installing the o/s, however try the following.
Ensure that all connections to the board are in, check ram is seated fully into its slot,check that the cpu & fan are installed correctly,infact remove everything and start again,maybe you will need to re-install your operating system, if infact you had already installed it .
good luck
Terry
Mar 05, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Foxconn p945 g7ma
turn off. unplug. remove small coin sized battery from board and leave out for about 15min. replace. plug back in. turn back on. this should reset bios to default
Feb 24, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Install motherboard drivers for the first time
did u format your hard drive with new mobo ? resisnatll it all then defult bios rechesk all settings in there
Jan 19, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
