Question about ASUS WL-600g Wireless Router
We have a problem with the password being changed and unsecured access for others to our internet.How do we secure our modem access?
  • 2,263 Answers
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Posted on Dec 10, 2009
I have an unsecured Linksys wireless set up installed. How can I go back and make it secure?
Hi jenkinsbebeg,
There's a possibilty that you will get an unstable connection due to unsecured Linksys setup. Poeple around you can pick up your network easily and could eat up your bandwith. So it is highly recommended to set up a security on your router. There are several options on how to set up or configure your router. You can use the setup wizard or by opening your web browser.
Here are some steps on how to set up your router using your web browser:
1. Open your web browser ( Internet Explorer, Mozilla ).
2. Now enter the the following URL: http://192.168.1.1
3. Enter your Username and Password.
common username and password for linksys:
--> username blank, password "admin"
--> username "admin", password blank
--> username "admin", password "admin"
4. You need to connect to the internet then click "internet setup".
5. From the drop down menu select DHCP for cable modems, and for DSL modems please select "PPPOE".
6. Now set the SSID (Service Set Identifier) to identify your network name. You could also change the password from here.
7. At this point you can encrypt your wireless connection using the WEP ( Wireless Encryption Protocol ) or WPA. If you will be using the WEP just go under " wireless security" option, then enter your preferred password (passphrase) then click on "generate".
From here you should now be able to connect to your router using your preferred password.
Hope it helps.
Thank you for using FixYa.
Feb 14, 2011 | Linksys Computers & Internet
How do i secure my router from other users.it's unsecured, and anyone can access wireless conection.how do i block other users
Hi i got your issue .......
Please try with the following steps ......
Step 1 : Connect modem -Router - Computer ( Wired)
Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 2: On the left under wireless click wi - fi protected setup
Step 3 : Leave the password blank and click on submit
Step 4: Disable it and Click on apply changes
Step 5: On the left under wireless click Security
Step 6 : Enable 64 Bit WEP
Step 7: Type a 10 digit number on the key 1 ( 2 in each box )
Step 8 : Click apply changes
Step 9: on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13: Click apply changes
Step 14: Now Scan and connect to this network ( Wireless )
If problem still presists please contact 24/7 belkin technical support 1800-2235546
Thanks.....
With regards ......
Priya ,,,,,
Oct 06, 2010 | Computers & Internet
Unable to access some secure and unsecure websites
Step 1: Connect the Modem to Router (in the port named Modem) and take another ethernet cable and connect one end to the Router(in the port named wired) and other end to any one of your computer
Step 2: Open the Internet explorer and type 192.168.2.1 and click on Enter in the keyboard
Step 3: Now you will be able to see the belkin router setup page
Step 4: On your left hand side click on Connection type,it will prompt for Login Password,leave it blank and click on Submit
Step 5: Now select the Connection type as "pppoe" and Click on Next.
you can find MTU size there....
it should be 1454 by default, if it is changed in your case then change it to the default vale(1454), and apply changes.....
Apr 04, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I am hooked up with the Internet via Buckeye Cable System. However, when I log on, I get a notice that I am connected with the Internet via ''MS Home'' and it says it is an unsecured connection. When I...
The router is a Microsoft, not the modem. I know of only one other person that owns a M$ router. A Netgear would have been my preference and a lot less trouble.
If you press the window key and R, you'll open up a RUN box that you type in CMD and press OK. It will open up another box (DOS) and you type IPCONFIG. The machine will respond with your IP address and gateway. If the gateway is something like 192.168.1.1 and your IP address is 192.168.1.x where x is anything but 1, it's a good start.
Open up Internet Explorer and type in the 192.168.1.1 or whatever into the address bar. It should open up the web browser for the Microsoft router. Now, did you get a set of instructions with a quick setup? Is this the MN-xxx box? You get to search the M$ website for the setup instructions if you don't have or never had them. Or, remember that $40 Netgear?
The username and password might be admin and admin or blank. That lets you set up wireless security. It should have some pretty self-explanatory help screens to give you either a WEP key or a WPA-PSK key. I'd start with WEP and a simple 10 character hex password like FACE123456. If the neighbors guess it, you can always go for better passwords or change the one you just set.
Hope this works, and think of me down the interstate from you (x187).
Carl
Nov 14, 2009 | Computers & Internet
Setting up a belkin n wireless router. How do I
You have to go into the setup for the router. Most default to the 192.168.1.1 IP address. You would type that address into your internet browser and hit enter. Then you will be asked for a name and password. If you have your belkin manual it will tell you the default name and password. Once in the settings you can change the password. You can also turn off SSID broadcasting, enable the highest level of security that your particular router supports in conjunction with your computer and enable MAC authentication. If you enable MAC authentication you have to type in the MAC address for each device you wish to have access to the router.
Nov 07, 2009 | Belkin Computers & Internet
How do I set up this modem as a secured network .
Is your modem wired or wireless?
if it is wired you donot have to worry but if it is wireless and the network is unsecured you need to perform the following steps.
if your computer is using the same wireless connection then you will loose the internet connection wirelessly as you will need to setup the configuration with the computer again..
1st u need to find the ip address of the computer..
click on start,then click on run in the box type in cmd and hit enter
now you will see a black box in that box type in ipconfig and hit enter
out of all the results you will see something which says default gateway there will be numbers beside it make a note of those number(eg it will be something like 192.168.1.125..this is just an example)
go to the browser page and type those numbers in the addres box,
it should open a user name and password box,type in admin/admin as the user name and password,
there you will see a tab for wireless under that tab you will see the option for security and then you need to make it secured..
YOU CAN TELL ME WHO IS THE MANUFACTURER OF THE MODEM SO THAT I CAN EXACTLY TELL YOU WHAT YOU NEED TO DO....
vedhick
Feb 04, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Securing wireless network connection
You need to log into the wireless router either by a computer that successfully connects wirelessly or by physically connecting with an ethernet cable. Once connected, log into the router by open a web browser (Internet Explorer, Mozilla Firefox, Google Chrome, Apple Safari), and typing the router's address (usually 192.168.1.1 or 192.168.0.1) into the Address (or URL) line. The default usernameand password is usually "admin" & "admin" or "admin" & "password". Once successfully logged in, look for a tab or link that says "Wireless" or "Security". You'll be able to change whether security is enabled or disabled, and the password associated with it. Your security options are WEP or WPA (or WPA-PSK). WPA-PSK is the most secure, but WEP is also an acceptable choice. Select the security option of your choice and either enter text into the passphrase generator or choose your own password and type it into one of the security key text fields. If you use a password that is not a plain english combination of letters and numbers, be sure to write it down so that you can enter it as needed on other wireless devices that need to access your router (ie-pda phones, game consoles, laptops, desktops, etc). Be sure to save changes so that the security settings and password is saved.
Let me know how you make out.
Dec 19, 2008 | Arris Touchstone 450a (CM450) Modem
Username & password
yes you can change the ssid
do to device then select adminstrator then change it username and password
Jul 15, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a Comcast cable modem (Arriss) with a Linksys router attached to a Dell PC desktop in one room. In an other room is a Dell PC laptop with a Linksys Wireless -G Notebook adapter card inserted. I am...
you will have to access the router by the ip address.
(192.168.??.??)once you log in, user name blank and password admin. you will have to set up wireless security. there are several ways and each that is selected has a brief tutorial.
Sometimes, people who are gamers or use Ipods, leave the router unsecure but limit the wireless access by mac address or by ip address so only those wireless devices gain access.
Apr 11, 2008 | Computers & Internet
Security
Till the time you put a access code for the wireles it would show it as a unsecure connection.You can change this by accessing the router page.Just type 192.168.1.1 in the address bar of internet explorer.Than it would ask you for username and password.Its ussually admin and the password field blank.Than go to wireless settings and the security to WEP.than you can put a password of either 5 or 10 digits.U can put your phone # which would be easy to remember and than just save the setting.Next time when you would try to connet to it than it would ask you to put the access code and will show up as secure connection.
I hope that helps
Dec 25, 2007 | Linksys A+G WRT55AG Wireless Router
ASUS WL-600g Wireless Router Logo
118 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
