Question about HP LaserJet P2015dn Printer
How remove & configure ip - HP LaserJet P2015dn Printer
    Problem Solver:
  • 3 Answers
How to solve when the paper jam flash is flashing
Posted on Jan 04, 2010
How to configure router & switch
You shouldn't have to configure anything except the PC's should have IP and gateway set to auto.
Here is how it works:
A router connects two separate networks and manage the traffic between them.
In most home network applications the router connects your local group of computers and devices known as the LAN with the Internet, commonly called the WAN or Wide Area Network.
The router usually assigns unique Local IP addresses to all of the devices connected to it via a service known as DHCP. The addresses assigned by your router are private addresses http://en.wikipedia.org/wiki/Private_net... and are not routable across the Internet.
Dynamic Host Configuration Protocol (DHCP) is an auto configuration protocol used on IP networks. Computers that are connected to IP networks must be configured before they can communicate with other computers on the network. DHCP allows a computer to be configured automatically, eliminating the need for intervention by a network administrator. It also provides a central database for keeping track of computers that have been connected to the network. This prevents two computers from accidentally being configured with the same IP address. http://en.wikipedia.org/wiki/Dynamic_Hos...
Your cable or DSL modem will get a Public WAN IP address from your ISP's DHCP service. These public IP addresses are leased in blocks by your ISP and are Internet routeble. The modem is connected to the WAN port on your router. The router will manage the traffic between the devices on the LAN and the Internet.
If your 5 port switch is connected to one of the router's LAN ports and router's DHCP is on then it will configure the clients attached to It automatically.
Feb 04, 2013 | Computers & Internet
Amber light is flashing on network card
Switch off the printer, re connect the net work cable, switch on the machine & wait till ready mode comes.. Go to administration on control panel, select configure device,select configuration page, print,, total three print out will come, in that see the IP address.. If any IP address showing, ping that IP from system, if its pings, reload the drivers once again.. check for the print. If no IP adress showing in configuration page, try with another net work cable & try above said exercise.. Even no luck, remove formatter from the slot & re-fix once again & try... Even no luck.. it might be network port faulty. If its warranty contact HP support for free replacement.. If no warranty purchase HP620n or higher version of zetdirect card(net work card) install it... But take service engineers suggestion before replacing the network card..
Aug 01, 2012 | HP LaserJet M4345 MultiFunction Printer
I have a set Motorola Canopy 2400BH but i forgot ip address and username and password, how can i access it for using.
You need to user an Override Plug, which can be fabricated this way:
To fabricate an override plug: 1. Install an RJ-11 6-pin connector onto a 6-inch length of CAT 5 cable. 2. Pin out all 6-pins. 3. Short (solder together) Pins 4 and 6 on the other end. Do not connect any other wires to anything. The result should be as follows: Pin 1 ? white / orange ? Pin 1 Pin 2 ? white / green ? Pin 2 Pin 3 ? white / blue ? Pin 3 Pin 4 ? green ? Pin 6 Pin 5 ? blue ? Pin 5
Regaining access to the module To use the override plug 1. Insert the override plug into the RJ-11 GPS sync port of the AP. 2. Apply power to the module through the Ethernet cable. RESULT: The module reboots with the default IP address of 169.254.1.1, password fields blank, and all other configuration values as previously set. 3. Set passwords as desired. 4. Change configuration values if desired. 5. Save the settings. 6. Remove the override plug. 7. Power cycle the module.
You can view more details at:
http://www.canopy-wireless-solutions.com/AppicationNotes/APManualIss5.pdf
Apr 30, 2011 | Motorola CANOPY 2400AP (2400APBC)
Could someone pls help me to configure my Samsung GT-B7722. My network Sun Cellular (Philippines) says they do not have the setting for my phone model. Thank you!
Since Sun Cellular does not have specific settings for your phone for an automatic configuration, you can still connect to the internet by configuring your device manually. You just have to look for internet settings in your phone and input the configuration as indicated below.
SUN GPRS Settings (HTTP & WAP)
Connects to:The Internet
Access Point:minternet
User & Password :
Primary DNS:210.23.234.65
Secondary DNS:0.0.0.0
IP Address:
SUN MMS Settings
Connects to:MMS Connection
Access Point:mms
User & Password :
Primary DNS:0.0.0.0
IP Address:
Go to programs-accessories-MMS Setup
MMS Connection
IP:202.138.159.78
Port:9201
Mmsc Address:http://mmscenter.suncellular.com.ph
MMS Download:Auto
Mar 22, 2011 | Samsung SGH-D900 Cellular Phone
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do you add this printer to the network?
for networking take the configuration page & note down the default ip add then open the internet explorer & note down the default ip & enter you will conect the printer directly then change the ip add as per ur requirement & uncheck the dhcp .
hope ur problem will be resolve...
Jul 01, 2010 | HP LaserJet 1320 Printer
Pspcl drivers for ir400 machine
press the option switch
in screen press function
press print pages
print configuration page
see the ip address & install the printer on this ip
in your computer networks use tcp\ip is smaller than machine ip if machines ip is 192.168.1.33
computers ip is 192.168.1.32
Aug 15, 2009 | Canon imageRUNNER 400S Copier
I want all cmmands of router dx 1821
Please send all commands for configur & view of dax
Dec 04, 2008 | 2wire HomePortal 100W (1000-400026-000)...
HP LASERJET 3055 Manual IP Address not saving
Switch off the printer and press * & enter key together &switch on wait till you see " permanent storage int"
then release button your printer comes back to original defaults
then re-configure printer as you require
Murali,
PALLAVI INFOTECH
BANGALORE
Jul 16, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet P2015dn Printer Logo
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
