Question about Sony Ericsson w580i Cellular Phone
How to separate two halves of phone - Sony Ericsson w580i Cellular Phone
How to remove ball from Dyson dc 25 Animal ?
Remove the torx screws that hold the two halves of the ball shell assembly together, then the ball halves can be separated and removed from the vacuum. Take note of how they come apart and how they line up su you can reassemble them properly.
Feb 05, 2017 | Dyson DC25 Animal Bagless Upright Vacuum
How do i replace the blade on my utility knife?
loosen the screw that is holding the two casing halves together and separate the halves. pay attention to which way the old blade is in the compartment, remove it and put in a new blade in the same direction. close the casing and tighten the screw
Jan 16, 2013 | Cutter Tools
My Nokia 3110c Screen's Backlight Is Gone. After Falling From Bed...What SHould I Do? Pls Reply
Check the casing to make sure it is not separated anywhere. If it is, gently squeeze to snap it back together. I can only guess that it is an issue of contact being broken between the casing halves, the backlight in your phone is a simple EL backlight, and it's really not very easy to damage it even if you are trying.
May 06, 2011 | Cell Phones
I have an Acer aspire one model #KAV60 and Im replacing the screen and can only find 2 screws on the front behind the rubber plugs
Yup, that's all they usually have...now it's time to get out the plastic wedge, and start separating the 2 halves on the screen cover!
Watch the lid locking clips as you separate the two halves.
After that, it's pretty much a walk in the park. Just remember to mark what screws came from where and you'll be fine. If not, send a reply here.
Feb 25, 2011 | Aspire Computers & Internet
I have a Craftsman 17" rear tine tiller with
check to see if there is a snap ring on the shaft or a roll pin.
Feb 23, 2011 | Craftsman Garden
The screws holding the face for my speedometer came out. Is there a way to take apart the speedo and fix the problem?
Typically the upper and lower half of the speedo and tach are held together with a metal band that is folded over the lips of the two halves. to separate you will have to carefully cut the band (usually on the bottom,towards you), peel it of trying not to kink it(save for later) and two halves should easily separate. Clean, lubricate,screw,etc. Put band back on, put a spot of glue at cut seam (only)and carefully wrap band with tape( electric works good)to hold speedo band and halves together.
Jun 02, 2010 | 1980 Honda CX 500 A
How do you replace the lcd screen on A LG shine KE970
Take off the back plate that houses the battery, undo the four screws, then look where the bottom of the battery is just below are two cover caps remove and undo the two screws below now separate the cover. There is a circuit board under neath the panel unplug may seem tight but go careful, underneath this there are a futher six screws undo these and the two halves of the phone will separate. Now undo all the screws you can see here including the two that are under the two covers at the top they look like moulding marks separate the halves, undo the screws on the roller switch,lift this and you will find a ribbon connector that appears to be glued it's not, go careful and separate. Congratulations you have now removed the LCD. All you have to do now is remember which screw goes where and reverse the whole process. Good luck.
Feb 08, 2009 | Cell Phones
1990 Pontiac Lemans choke plate location
I'm venturing to guess that a 1990 lemans is fuel injected. then you wouldn't have a choke plate. I would start by checking the iginition system first, plugs, wires, cap, rotor, and if all that looks good then look at the fuel system.
Jan 10, 2009 | 1990 Pontiac LeMans
Dismantle instruction for W880i Sony Ericsson
At the bottom end of the phone, there is a sticker (directly beneath the last row of numerals * 0 #. In my case it says Vodafone on it and is silver. Carefully peel that up using a craft knife. The other 2 screws are beneath it. The phone halves then separate. As for taking the guts out of the phone, I have yet to figure that out myself. Good luck with it.
Sep 05, 2008 | Sony Ericsson Walkman® W880i Cellular...
Sony Ericsson w580i Cellular Phone Logo
20 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
