Technosonic LCD TV no sound
I plugged my headphones into the television and then when I unplugged them there was no sound. Now I have to listen to the TV through speakers in the headphone sockets. Any ideas?
Thanks Simon
  • simondilly Dec 10, 2009
    It is probably the later that the switch is stuck. Any idea how I unstick it? Is it just a question of taking off the back and playing around with it or do you have specific instructions. Cheers!
  • 585 Answers
Hi my name is Roety,
I can help you with your issue ,
 The headphone jack has a switch that turns off the speakers. Either you left part of the jack still in the socket or the switch is now stuck
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Dec 10, 2009
  • Eric Rotmil
    Eric Rotmil Dec 10, 2009
    Try looking with a flashlight first in the hole, you can try a toothpick but don't make it worse getting that stuck in there,
    Or open it up and see if the jack is sealed shut or open back type.
    Tapping it gently make free it up too from inside,
    best of luck
    Thanks
    Roety
I have a lg tv and we bought headphones to listen without bothering anyone else. however I used headphones last nite and unplugged from back of tv and now I cannot get sound on my tv (ONLY SOUND THROU
Simply click on your menu button, goto Audio, notice the TV speakers switched to off? Sometimes the TV won't switch it back. Problem Solved. Goodnight
Jan 18, 2015 | LG Televison & Video
Bravia hdmi hdtv lcd
It will be so. When you insert the headphone pin into its socket, the internal speaker connection will be automatically cut off, and you can listen the sound via the headphone only.
Sep 28, 2013 | Sony KDL40EX600 TV
Have an Hitachi 42 PMA400e Plasma Tv.
Unfortunately, if there is no headphone connector on the TV there is no practical way of accomplishing the alternate arrangement.
Mar 21, 2017 | Hitachi 42PMA400 42 in. Plasma Television
Just get a headphone jack that does not shut off the speakers and have your dad plug his headphones into that.
Mar 22, 2017 | Hitachi 42PMA400 42 in. Plasma Television
Having problem with audio, with auria tv (when unplug headphones, sound will not come back on tv)
The socket for the jack on the set has a leaf connection that when you insert the jack moves aside routing sound to head phones and cutting it off to speakers= the socket for the jack is out of position inside, either needs to be replaced or tweaked inside just a little.
Not much else can cause this if the headphones work.
May 02, 2012 | EQD Auria EQ2488F 24 LCD TV
I'm using the tv as a monitor for my pc. How come I can't get my headphones for my pc to work when plugged into the back of the tv?
This is because the cable you are using to connect your PC to your TV does not carry a sound signal, only picture. To play sound you will need to connect a pair of external speakers to your PC, or if you want to listen on headphones, connect the headphones to the PC instead of the TV.
Oct 23, 2010 | Venturer PLV36220S1 22 in. LCD TV
I plug in headphones, but sound still comes out of TV speakers
This information was found on the Dynex website: (http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) in the frequently asked question section on page 7. If the solution below dos not work for you. You can either go to the website by copying the web address and putting it in your address bar. Once there you can use the e-mail function to talk to customer support. You can also use the Dynex customer support telephone number 1-800-305-2204 between the hours of 7am and 12 am CST. Give them the model number of your television and the problem you are having with the use of the headphones. I hope this information helps you solve your problem. How do I get headphones to work with my TV? o Connect the headphone cable to the headphone jack on the side of your TV. o The sound will be heard through both the headphones and on the TV speakers. o Press Mute to hear sound only through the headphones. o Use the volume buttons on the remote to adjust the volume level. o You must remember to press mute again to hear sound through speakers. It will not automatically come on when you unplug the headphones.
Jun 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
No sound through the headphones
The way the headphone jack works is:
plug your headphones in and then mute the television using the remote.
While the TV is muted you can still use the volume up and down controls to adjust the volume through the headphones. I find that having the volume at 60-75% is more than loud enough on the headphones.
Just be careful when you unplug the headphones and take the TV off of mute, if your volume levels are still turned up you will be in for a jolt :)
Jan 10, 2009 | Dynex DX-LCD37 TV
TV has no sound
Just a thought...does the set have a headphone jack? When you plug in most headphone jacks it disables the internal speakers. If it does have a headphone jack trying plugging in some headphones to see if you have sound there. If you do, plug/unplug it a few times...worth a shot.
Nov 18, 2007 | Philips 25PS40S 25" TV
Televison & Video Logo
178 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
