Ferguson B39F TV
Hi Guys,
Original remote gone and am doing my head in slowly. I can find the channels but cannot memorise them. Any clues most appreciated.
On the front of the tv I have #4 Top Buttons and underneath, 2 sets of Up/Down Arrows.
To Tune the Channel I Hold Down the Pict Button and eventually get the Pal 1 choice and Channel options. Having found a channel I repeatedly press the Pict. Button down to the Programme No. Using the UP/DOWN Arrows I chose the relevant Programme Number and after that I am at a loss as to what button to press to memorise.
Thanks & Regards
Al Davis
  • 3130 Answers
SOURCE: Buttons on TV or remote not working. Can only cycle through video input options.
It sounds as though the TVs in a demo mode. Has someone recently been over and was playing with the remote. If so go into the menu of the tV set and look for set up and demo mode. Turn off the demo mode. if this doesent help call i-866-427-3946 and talk to the customer service deptartment. Good Luck
Posted on Aug 09, 2006
  • 1153 Answers
SOURCE: can't get TV onto the AUX channel
Do in your menu have like VCR or DVD in the option area? If so then put on vcr or dvd. Also you can look for the channel in the add or erase area and move past the channel 2 by going the other way and see if the aux or video1 comes on then simply chose it.
Posted on Sep 09, 2007
  • 5 Answers
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
Posted on Feb 05, 2008
  • 375 Answers
SOURCE: Programming AUX as a channel.
pick up a universal remote
Posted on Mar 28, 2008
  • 8596 Answers
SOURCE: magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Posted on Jun 14, 2008
What is the code for a Ferguson TV
Ferguson tv sky remote codes ' AVForums > ... > Satellite TV, Sky TV & FreeSat
Sep 24, 2014 - Hello, does anybody know what the sky remote control codes are for aferguson television. I have tried to find the solution on the internet but the... Sky Remote Code for Ferguson TV
Sep 28, 2014
Sky code for Ferguson Tv
Apr 22, 2010
More results from
Remote Code For Ferguson TV - Sky - Digital Spy Forums
Dec 15, 2015 | Televison & Video
My Sylvania LC320SL1 TV is changing channels all by itself, like it is stuck in auto memory, and I do not have a remote for the TV any suggestions? Tks
Hi, its probably searching for channels. You need to get your original remote for your TV. You can purchase it here:
LC320SL1 remote control
Using the original remote you can fix this.
Nov 28, 2012 | Philips SRU2103S-27 Remote Control
I need instructions and remote for ferguson F2614LVD
Hi, I have a Telefunken LCD which is not activated, but only on light ignited, can you please help me
Jan 12, 2012 | Televison & Video
No channels listed on tv after reset was done
The entire memory was wiped off as you had reset the TV . Soo all you need is to open the menu and choose the settings, choose the auto programming and scan.
Once the programs listed on your cable or network has memorised you can shift the channels to the required selected program numbers to your desire.
Sep 06, 2011 | Westinghouse Televison & Video
I can change channels by entering the actual channel number on the keypad, but the channel up and down buttons don't work
The up/down button is worn out (guys do this, since we love to channel surf). Keep the original
remote that came with the TV (they're invaluable), but buy a cheap universal replacement remote
(I got my last one at Dollar General for $8), program it for your TV, and surf with that - you'll
get power ON/OFF, channel up/down, and volume control from any universal remote.
May 30, 2011 | Televison & Video
I tried to program my Toshiba TV Model 27A43 to a new Universal Remote, because the original Toshiba remote was functioning more+more slowly ( I changed batteries on the original Toshiba remote first)...
Yes do a complete new channel scan. Play this like you just got the TV. If you want to buy the OEM factory remote you can most likely get it at the link and avoid all this hassle. Follow the link below. 1 800 Remotes
Mar 28, 2017 | Vacuums
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? ( has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
Is it working????
you will have to select the video channel source for the TV, usually like av1 or av2 or something like Video 1 Video 2, channel 3 only works with RF switches it wont work with RCA jacks. there should be a video source button on the remote, if you lost your remote then try pressing channel down it usually comes before channel 2, if it dont show up then you will have to press the video or source button in the remote.
May 11, 2009 | Nintendo 64 Console
Help! How can you unlock a pin on a TV that you don't know?
Tried unplugging it for five minutes then plugging it back in? It resets the software.
Sep 09, 2007 | JVC AV-27020 TV
Remote not working
Hi Suzanne. What you need to do first is get or have the original RCA remote available. next, go into the menu and do whats called a channel search, but you will need an antenna or cable line attached to the RF input of the TV set, Do whats called an auto search. Let the set complete its cycle. If it found no channels, then there is no input sourch or you have a bad tuner or its assoicitated componets. it should be in the owners manual on how to do this. If you do not have an owners manual, get one here*&brands=RCA%2cGE%2cPROSCAN%2cRECOTON%2cSPIKEMASTER%2cAR%2cJENSEN%2cAMBICO%2cADVENT%2cUNBRANDED&doctypes=IB&categories=ACCESSORIES%2cAUDIO%2cCOMMUNICATION%2cDTVS%2cDVD%2cMULTIMEDIA%2cCOLOR_TV%2cVIDEO&firstdocnum=1 If you need a new remote or original replacement please go to Good Luck please do not forget to rate this thread.
Oct 22, 2006 | RCA P52921 52" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
