Question about Apex Digital AT3208S 32" TV
Can't get my dish network remote to program to work my new APEX 40 TV. The remote codes on the dish network website does not work.
5 Suggested Answers
SOURCE:
SOURCE: dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Posted on Mar 09, 2009
willadavis76
SOURCE: Need code to program universal remote for my Apex LCD TV
i have apex tv 2003 and i need a code for my remote
Posted on Jun 02, 2010
BeckiB_DISH
  • 286 Answers
SOURCE: I need a code to
Hello!! All you need to do is follow the link that I provided below. That will walk you through a power scan, where the remote scans the codes on the tv, until it reaches the right one. It is simple and quick!!!
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Posted on Jan 27, 2011
gopakumarg43
  • 76036 Answers
SOURCE: the philips universal remote codes for my apex tv
Hello
Philips universal remote control cannot be synchronised with Apex Digital TV. There is no code for Apex with it. There are very rare remote controls which have codes with Apex Digital. Comcast On Demand Custom DVR 3-Device Universal Remote Control is one amoung them. Codes for Apex Digital Tv; with this remote are:
0748, 0765, 0767
Buy this one. It can be sychronised with most of the present devices. OK.
Posted on May 31, 2011
We are trying to program the APEX TV code into the Dish network remote and none of the codes in their book is working.
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. In order to address your remote to your TV you are going to need the model number of your DISH remote. The model number will be located on the back of the remote at the top, usually a two to three digit number with a decimal point. I will list here for you the best codes for our more popular models of remotes as well as the instructions for addressing your remote to the TV. I hope you find this information useful and if you have any further questions or concerns feel free to email me directly at Cheri.Torres@Dishnetwork.com. Thanks.
Remote model # Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 745, 743, 744, 595, 757.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 595, 743, 745, 757.
4.0 and 4.4 IR/UHF remotes - codes 744, 595, 745, 757.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 744, 745, 595, 785, 743, 757.
20.0 IR and 21.0 IR/UHF remotes - codes 552, 594, 815, 595, 743, 757.
Instructions for addressing the remote to the TV
  1. Turn the Television On.
  2. Press and hold the TV Mode button until all other mode buttons light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once.
    Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Sep 26, 2011 | Apex Digital LD4088 LCD TV
How to i program a direct tv remote to my digital tv converter. dt250 model apex
nucklebuster
I have provided a link with instructions on how to program yoru remote to your TV. The Webpage also has links for the codes. I hope this helps.
http://2getdtv.com/directv/remote_codes.html
Ray Calo
DISH Network
Mar 23, 2011 | DISH Network IR Remote Control
I would like to program my dish network remote control on my tv apex
You can use the following link to find the codes for your Apex tv.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Just click the remote codes in Step 1 to get to the list.
That main link will also provide the step by step instructions to program it.
Nick Franta
Jan 24, 2011 | DISH Network IR Remote Control
Trying to set up dish network remot to apex dvd player
dr172120,
I'm sorry you are having problems programming your DISH Network remote to your Apex DVD player. I looked through our remote codes but I don't show we have a code for an Apex DVD player. We do have remote codes for an Apex TV. You can run a power scan to see if you can find a code for the DVD player. I have provided the instructions to conduct the power scan below. If you have any other question, please post to this site.
Ray Calo
DISH Network - Executive Offices
Address To Other Equipment Using Power Scan
  • Remote: All Remotes (except Basic)
    1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
    2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device.
      Then Press STAR (*)
    3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
    4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Jan 14, 2011 | DISH Network IR Remote Control
I have an apex tv but can't get the dish network remote code to work
Hello! Sometimes the remotes have trouble programming to the tv. But follow the simple steps by following the link below to run a scan on your remote to get the correct code so that it will work the tv. Hope it helps.
Becki Barned
Nov 27, 2010 | Apex Digital LD3249 LCD TV
I have ( Apex digital LD4688 ) I neeed the code. Thank you.
I install dish network. i have tried all versions of dish remotes, . the only one that works is Dish Network 21.0 Learning Remote. it will work with all dish products and i have programed it for this tv apex ld4688 hd and it works great.here is a link for the manual on how to use.
http://www.satelliteguys.us/dish-network-forum/158496-dish-network-21-0-learning-remote.html
Nov 27, 2010 | DISH Network IR Remote Control
Looking for remote control code for Phillips/Verizon that works with the LD 4088
This is a solution for DISH NETWORK users that have the remote that comes with the system.
I just purchased my television yesterday and I did the same, as I spent about 3 hours searching online, and found about 600 codes to try, but ultimately, I didn't want to spend a month programming my remote. I ended up calling APEX the company and they gave me three codes: 591, 594, 11531. 591 didn't work for my tv, and 11531 is five digits meant for direct tv users, but 594 worked on my dish remote that came with the dish system. Hope this helps everyone, try the codes for yourself, you don't need to buy a new remote. I was told if these codes didn't work that you would have to call your cable provider to get the additional codes for your remote. The number I called and spoke directly with an APEX Representative was 866-427-3946.
Nov 19, 2010 | Apex Digital LD4088 LCD TV
I need a code to program my Dish network remote control to my APEX AT2002S TV please
Becki Barned
Aug 24, 2010 | Apex Digital AT2002S 20" TV
APEX CODES
I need the code for my ad-1500 apex dvd so I can program a new remote control
Mar 23, 2008 | Televison & Video
Haier TN201AUV 20"
The GE Universal Remote will do the job. I have on and it works for my Haier TN201AUV TV. You can also find a replacement Haier remote on Remote Hound's web site.
On the other side of this I have a Dish Network remote that WILL NOT work. The Dish Network remote does not list any codes for Haier. Dish Network Tech Support could offer no help.
In an attempt to solve the problem myself, I looked on-line at GE's site listing all of the manufacturers' for their remotes and found the identical code that worked for my Haier TV also listed under APEX TV's. The Dish Remote lists (11) APEX TV codes. Ironically, NONE OF THEM WORK!
I'm stuck with using both remotes... and that's BULL$H!T
Dec 01, 2007 | Haier HTF20R21 20" TV
Apex Digital AT3208S 32" TV Logo
316 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
