Question about RIM BlackBerry Storm 9530 Smartphone
After having the device on....white screen appears
Blackberry Storm - after having the device on....white screen appears with a running clock simbolizing "please wait".....this goes on and on endlessly but the device never get booted
My black berry phone shows app error 523 with white screen and keeps rebooting what do i do it is giving concern
(IGNORE THE SIM STEPS IF ITS STILL ON VERIZON PLEASE)i had the same issue on my 9700!!! its either the sim or the software on the phone. DO NOT SELECT RESET YOU WILL LOSE ALL YOUR INFO!!! take out the battery with the phone on and take out your sim card. replace the battery without your sim card and see if the error still shows up. if it doesnt its your sim, super quick and easy most carriers will provide you a new one free of charge! if its does appear without your sim its the software. still fixable but not as quick. replace the sim & battery & power your phone on. you'll need a computer and the desktop manager which you can down load if you dont have it already from blackberry.com for free. then run the app loader. the storm has the blackberry 5.0 software and you want to make sure your desktop manager matches. follow the steps from http://www.blackberryforums.com.au/forums/bis-blackberry-desktop-manager/734-use-blackberry-application-loader-load-blackberry-device-software.html and you'll be set!!!
Use BlackBerry Application Loader to load BlackBerry Device Software
Doc ID : KB03621
Last Modified : 2007-05-18
Document Type : How To
Environment
  • BlackBerry® Desktop Software 3.6 and later
  • BlackBerry Device Software
  • BlackBerry device
Warning: You should not install BlackBerry Device Software that is older than the version installed on the BlackBerry device. Doing so could cause the BlackBerry device to malfunction.
Procedure
To use BlackBerry Application Loader to load BlackBerry Device Software, complete the following steps:
  1. Install the BlackBerry Device Software on your computer.
  2. Open BlackBerry Desktop Manager.
  3. Connect the BlackBerry device to the computer.
  4. If prompted, type your BlackBerry device password and click OK.
  5. Complete one of the following steps:
    • If the Application Updates Available window appears, click Update Now. The Application Loader Wizard appears.
    • If the Application Updates Available window does not appear, double-click the Application Loader icon. The Application Loader Wizard appears.
  6. Click Next.
  7. If prompted, type your BlackBerry device password and click Next. Note: When the Application Loader Wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation. The selected check boxes indicate applications that are already installed on the BlackBerry device.
  8. Select the check box for the BlackBerry Device Software.
  9. Click Next.
  10. If the On the Device Backup screen appears, choose whether to automatically back up the BlackBerry device and click Next.
  11. Click Finish to begin loading the BlackBerry Device Software.
  12. Click Close when the software is finished loading.
Dec 24, 2010 | RIM BlackBerry Storm 9530 Smartphone
The phone says invalid sim card. This is the second blackberry pearl lip 8220. It is a piece of junk. Usually the screen goes white and then a little square clock appears in the middle of the screen....
Your Blackberry probably just needs a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry to factory settings. Download the Blackberry Desktop manager and run the application loader. If it asks you for a password, you can enter it 10x wrong and that will wipe the blackberry as well.
Jul 07, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Busted lcd of blackberry storm
First, you should download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Jan 13, 2010 | Cell Phones
NOTHING SHOWS ON THE SCREEN OF BLACKBERRY STORM, HE CANNOT SEE THE KEYS TO FIND THE MASTER RESET, IF THERE IS ONE.
If you are able to see any light lit on you are blackberry.First charge your mobile for atleast 1 hour,and switch it ON you have to remove the battery when mobile is turned ON and wait for few seconds re insert the battery then check
If problem still exsists connect your blackberry to computer check wheather its recognising the device If "yes" you need to take a back up of your hands set and re-install the operating system of your Blackberry. Or else please visit the nearest service centre.
Nov 22, 2009 | RIM BlackBerry Storm 9530 Smartphone
My bb storm screen doesnt come on the phone is on but the screen doesnt come on
Not to worry , If you are able to see any light lit on you are blackberry.First charge your mobile for atleast 1 hour,and switch it ON you have to remove the battery when mobile is turned ON and wait for few seconds re insert the battery then check If problem still exsists connect your blackberry to computer check wheather its recognising the device If "yes" you need to take a back up of your hands set and re-install the operating system of your Blackberry. Or else please visit the nearest service centre
Nov 19, 2009 | RIM BlackBerry Storm 9530 Smartphone
Random rebotoing - white screen with clock
The BB Storm is plauged with these problems unfortunately due to insufficient hardware & buggy software.
There is hope however - you can try update your software. You can find it here
Aug 31, 2009 | RIM BlackBerry Storm 9530 Smartphone
My storm screen freezes on the black screen when i turn it on it looks like a time colck and then the red light stays on and then goes off....cant get to home screen
Does the screen go black after the Time Clock comes on? When I plug in my storm, the time clock comes on.
If in the time clock, you should be able to press the Blackberry Menu button, and choose close to close out of the Clock. If you are in Bedside mode, you will be asked if you wish to exit.
Click yes.
Jul 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
I got my password wrong on my blackberry storm
This is a security feature in the BlackBerry. It means you have to reload the device software into the BlackBerry via a computer. All data on the phone has been erased. The device software varies depending on the model of the phone and what carrier it is used on.
Jun 28, 2009 | RIM BlackBerry Storm 9530 Smartphone
Blackberry storm has random resets
i called verizon have the same problem and they said to deinstall an 3rd party apps. i have 3 face book, whether bug, and vlingo. thick around what time it did it what apps did you just get. i thick vlingo is one of them. my brother has it on a curve and said to get i did and just a cupel of days after i notes it.
Apr 13, 2009 | RIM BlackBerry Storm 9530 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
130 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
