Question about Brother HL-2040 Laser Printer
The printer won't print, it's trying to pick up the paper inside
The printer won't print, it's trying to pick up the paper insite but the roller just keep rolling and cannot catch the paper.
    Champion:
  • Brother Expert
  • 265 Answers
Pull out the paper tray, at the front of the tray, there's a translucent roller in the middle. Remove the roller and clean out any waste paper dust inside & wipe clean the roller before putting it back.
Posted on Dec 11, 2009
  • 428 Answers
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). After blowing, if you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Posted on Dec 10, 2009
PAPER NOT RECIVE
Paper not picking up?..shoot print command and observe printer trying to grabbing the paper?..see any marks on paper leading edge? Remove cartridge and see inside paper pick up roller,might be its dusty or warn out, remove the pick up roller releasing the side locks, clean with wet cloth, fix it back then try once, if its success..end the process.. if not replace pick up roller..observe similar kind of machine: 2_4_2012_9_32_43_am.gif2_4_2012_9_33_08_am.jpg
Feb 04, 2012 | HP LaserJet M1005 Printer
Tip
Dell 1700 1710 series printer. Paper not picking up trick....
Here's a quick tip. If your Dell 17XX series (not confirmed for newer than 1710dn printers) is no longer picking up paper from the tray, it MAY be from worn out rollers. Try this tip to get it going while you wait for a replacement roller to get to you:
1 - remove the paper tray
2 - remove toner
3 - flip printer upside down (exposing the rollers)
4 - remove the rubber on the roller
5 - invert it. (turn it inside out)
6 - replace rubber back onto roller (still inverted)
7 - test print.
If this doesn't work then the problem is likely a paper setting (set to legal or something) Good luck.
on Aug 27, 2010 | Office Equipment & Supplies
Printer i making a weird clicking sound. It won't print. It has error light On. Status: load tray 1 / Plain letter Toner level is 80%
check if there is a paper at tray 1. if so, may be the printer is unable to pick up paper due pick-up roller problem. try to remove the tray and look in the middle, there should be a rubber like roller. if its too glossy it cant pick the paper.
Sep 18, 2011 | Dell 1720dn Laser Printer
Will not print on regular size copy paper paper gets jam to the right of printer but will print an envelop
hi; try cleaning the paper pick roller and the paper guide and check if it has any foreign objects blocking the paper inside the print hope this help, thanks
Aug 26, 2011 | Lexmark X2600 InkJet Printer
Paper feed wont take paper to print gets crinkled and wont print
This is sort of scenario could be caused by dust inside the printer. Dust prevents the rollers from having a firm grip on the paper while picking paper. When one roller has a firm grip and rolls the paper well while the other doesn’t, crumples result. So I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front; if you have a blower please use it as well). This, if properly done should do it. Brush especially the rollers etc.
Dec 21, 2009 | Canon Pixma MP500 All-In-One InkJet...
Paper jam in HP Laserjet 4V
remove the cassette you can see two or 3 roller down the printer clean that roller and try.....
Oct 07, 2009 | HP LaserJet 4mv Printer
My printer does not pick up the paper sheets from the paper tray.When I took paper sheet in to slot it works.
Well - I don't know if this will solve it (since there could be many causes) but it worked for me.
1 - Remove Paper Tray
2 - look at rubber rollers in printer undercarriage
3 - carefully remove "rubber bands" from roller
4 - turn rubber bands inside out and carefully return to rollers
5 - remove toner cartridge
6 - remove print drum assembly
7 - return printer drum assembly and toner cartridge
the roller trick helps the printer pick up paper
the toner/print drum trick helps reseat the inner workings of the printer correcting any misalignments that impede paper flow
Jun 09, 2009 | Lexmark E232 Laser Printer
Paper is not picking up in the hp deskjet 3745 printer
THERE MAYBE PAPER STILL IN THE MACHINE, YOU MAY HAVE TO REMOVE AS MUCH AS THE CASE PARTS TO SEE IF THERE ARE ANY PAPER INSIDE THE MACHINE, TAKE SOME ALCOHOL AND CLEAN THE ROLLER, FEEDER AND ANY OTHER ROLLER YOU CAN GET TO YOU MAY EVEN WANT TO USE A Q-TIP TO GET TO THE ROOLERS NOT REATCHABLE BY HAND. REMOVE PRINT CARTIGES MAKE SURE THEY ARE CLEAN OF DIRTS,
TRY DOING PRINTER ALIENEMENT OR PRINT TEST FIRST AFTER CLEANING.
ROD
May 12, 2009 | HP DeskJet 3745 Printer
Dell 1700 will not feed paper
If your Dell 1700 laser printer is not pulling paper all the way, try cleaning the pick up rollers.
To access the pick up rollers. Turn off the printer. Unplug everything from the back of the printer. Take out the toner/drum and set this aside out of the light (the drum is effected by light). Remove the paper tray. Set the printer on its backside. The rollers are located on the underside of the printer where you just removed the paper tray. You may have to move a blue flap to get at the rollers. Take a damp paper towel and clean these off. Another possible solution is to take the grey rollers off and turn them inside out and then place them back on the printer.
The pick up rollers should not be shiney, or cracked and dryed out. If they are, they will not pick up the paper to feed it into the printer. The tires should have "traction" to them so that they can grip the paper and feed it into the printer.
Once you have the tires cleaned off or turned inside out and placed back on reassemble the printer and try printing.
Mar 28, 2009 | Dell 1700n Laser Printer
Paper jam light is on with no sign of a jam printer wont print.
1-paper is most likely stuck in the fuser, (where it exits and gets hot) you will have to remove it
2-it would be better to clean the rollers w/ alcohol then inside out.
Oct 09, 2008 | Dell 1700n Laser Printer
Brother HL-2040 Laser Printer Logo
407 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
