Question about Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television
Lines horizonal - seems to be caused by voltage to green CRT
If you give the green CRT any voltage at all... red to blue lines appear depending on the settings of the other two CRTs...You have to turn the voltage regulator completely off to eliminate the lines.. leaving a distorted blue/red picture... There is also a humming noise when voltage is turned on to green CRT...
  • DaneC Jan 21, 2008
    Yes, I should have mentioned that I switched up the wires to make sure it wasn't a short in the controls. It disrupts the picture on the green, no matter what control that CRT is hooked into. So what do you do about a shorted out CRT?
    I don't see anything loose or any visible problems whatsoever...Can you buy and replace these things yourself?
  • Mitsubishi Master
  • 8,617 Answers
Your green CRT is shorted. To test put your red crt socket on the green and your red on the green. then try turning up red control if the green now works its not your tube. If the same thing happens with the red socket on the green you can be sure its the green CRT if the green works properly with the red socket, then you have a problem in the green drive circuit and not the CRT. hope this helps.
Posted on Jan 20, 2008
I gotta a green screen
It is possible that you have a shorted green CRT, you can remove the front speaker cover, and you will fine a focus block, and if you turn down the green screen voltage, very slowly, the green should turn down. if not then the gun (CRT) will have to be replace, If it does turn down, then go into the menu and turn the color are the way down and that should give you a black and white picture. If it is not black and white. adjust the red, blue, and green screen voltages until you receive a good black and white picture. Turn slowly they are touchy, and if turn to high, you will get retrace lines and the TV will shut down.
Nov 14, 2010 | Toshiba 61A60 TV
I get interferance mainly red and green lines appearing on top of the picture plus crackling noises
Please put off your tv and open the back side of the TV. Look for dirt on the back side of the CRT that is causing the arcing of the high voltage. So when the high voltage is sparking against the ground section the lines are coming to the screen. So use a good dry cloth to clean and wipe clean.Use a good solvent like methy spirit to clean. Check to trial and repeat if the fault is repeating. Make sure the HT lines are not touching but keep them apart to redduce the sparks. Hope this will get the TV right. Good day
Aug 10, 2010 | Samsung TXM3297HF 32" TV
Nec pf-68v21 pwr led flashing red green after horizontal output
check the supply at horizontal driver trans former ,if voltage is correct at ho/driver trasistor ...then check allthe fusible resistances from power supply,,,if tv is taking h/oscillation for awhile ,,give more screen control in lot,,, & see for a horizontal line ,,,before tv becomes off,,, if so vertical ic problem...
Mar 16, 2010 | Televison & Video
Dark and light horizontal lines in picture. What to do?
red, green and blue bowed lines? could be retrace lines. check CRT(picture tube) or try adjusting G2 voltage. What brand and model?
Dec 28, 2009 | Televison & Video
Lines distorting the picture appearing on the screen
It's the Electrolyte Capacitor ( Elco )on the Vertical board that already damaged, try replace it with new ones.
Oct 18, 2009 | Dell W3000 30 in. HD-Ready LCD Television
Samsung CRT HDTV - Color Problem - Red, Blue, No Green
This will be a lack of green drive caused either by the green output transistor having failed or no green output from the driver IC. As to which you have depends on how old the TV is. These are located on the CRT base (square type board connected to the neck of the CRT. You would need a multimeter to check the voltages going to the green output on the crt. It is also very possible the CRT is internally faulty giving no green, if this is so, you will need the crt (tube) to be replaced,it is not very economical to do this now a days.
Jul 06, 2009 | Samsung Televison & Video
Sony KP65WS500 5 blinks
I think problem is in Protection circuit itself. Protection seems unstable in your tv that's why it doesn't give you chance to diagnose problem.
Try to isolate protection command and check tv.
Its an idea and hopefully it will work.
Sep 24, 2008 | Televison & Video
Please help
I suspect if you have green lines .you have a bad crt. there are three tubes red green and blue i suspect blue tube. tubes cost is around 300.00 to fix.
thanks doctor video
note sometimes you could adjust screen voltage located near the front grill black box . becareful high voltage ony a pro should do.
Jun 14, 2008 | RCA D52W15 TV
My TV has blue lines,flashes then turns off
Bad blue CRT common problem.....................T.
Nov 09, 2007 | Sony KP-51HW40 51" Rear Projection...
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television Logo
461 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
