Question about Nokia 1100
Im a shopkeeper,... 1100 model mobile does not work properly when battery is paced on it but it works when i test it from the meter which section should i cheak first
    Sniper:
  • 129 Answers
Check battery connectors of your phone,clean and pull carefull to better contact with battery.also clear battery connectors of corosion.
Posted on Dec 10, 2009
2001 Yamaha V Star 1100 Classic not charging
Hi, Rex before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test:
Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Connections and wires:
Inspect the regulator stator plug, and check the battery terminals for connection corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC output and resistance test fail and stator test passes then the rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator start motorcycle and change Voltmeter to AC volts. Probe both stator wires with your meter lead. The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale. Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on the system, check the service manual for specifications.
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
5. Stator Ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity your stator is shorted to ground and must be replaced.
6. Regulator Test:
Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from the regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from the regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test:
This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire. The reading should be Infinite. With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires. The reading should be Infinite.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads for viewing or printing that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.sloneservices.com/SilverBack/Other-Stuff/VS-1100-chagre-syst.pdf
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
Yamaha XVS1100 Service Manual
OEM parts for Yamaha
Yamaha star 1100 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 09, 2017 | 2001 Yamaha V Star 1100 Classic
Mobility scooter is unresponsive
.good mobility scooter
humm strange
...fitted a new throttle but still no go
any fuses in the system
might need a volt meter to test all the wires voltages and resistance between battery and throttle
info says comes with two batteries
ouch the w/55AH Batteries are about $250
are both batteries holding full charge
May 30, 2016 | Pride Mobility Products Hurricane PMV...
Charging system failure low voltage
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12 volts or better after charging.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor. Good luck
Jan 07, 2014 | 2011 Harley Davidson FLHTK Electra Glide...
How can i know if my voltage regulator is working, Im not getting any of my lights to work
quick check is to remove a battery cable while the motor's running. If the motor stays running when you pull off the battery cable, the charging system is functioning properly, if it dies then there is a problem with the charging system. Don't leave it off long, as this test is stressful to the circuit. You can test the voltage regulator by putting a volt meter across the battery posts to verify voltage. A fully charged 12 Volt battery should show slightly above 12 volts DC. With the engine running and the volt meter hooked to the battery, the charging system should be showing around 13.8 volts DC.
Dec 02, 2012 | Cars & Trucks
Toro 2009 personal pace mower transmission went out
You should post this question in the lawnmower section so the proper expert will see it..
Aug 29, 2012 | Toro Lawn Mower. 22 in. Personal Pace with...
How to test rectifier.
there are several ways to test a rectifer the quckest way to check if it is working properly is with a voltmeter first check ground resistance one lead to good known ground (battery neg.) the other to rectifer should be 1 ohm or less.Then hook meter to battery and start the bike and check and watch battery voltage should start to increase after a minute or so check at 2000 rpm again increase if it does not check stator if stator passes replace rectifier
Mar 01, 2010 | 2002 Yamaha V Star 1100 Classic
Does changing mobile parts change display menu???
It sounds like he removed the at&t software, and "flashed" it with generic software. Should work fine for making and receiving calls, but without the at&t settings in your phone, internet and texting probably won't work.
In my opinion, it would have been better if the shop had explained what they planned to do before they did it so you would have a better understanding of what was going on. Hope this helps you.
Feb 15, 2010 | Cell Phones
Nokia 1100 mobile phone not working
may be the battery is lowbat or defective/ or u have to re-program it!!!!!!! by.mhikefox08
Aug 01, 2008 | Nokia 1100
Fault in chinese mobile zt188
you should take it back to whom repaired it to get this corrected
Apr 14, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Nokia 1100 Logo
55 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Laxman Bisht
Laxman Bisht
