Question about Zebra Thermal S4m Dt Zpl 203dpi Rs232/par & Usb Label Printer
No label output appears when I copy a ZPL text file to a USB-connected Zebra S4M printer on my local machine (running Windows XP Pro). The Printer successfully produces a Windows test label. However, we need to copy a ZPL-formatted text file to this printer (which has been shared as \\computer\zebra). Although the job appears and processes in the spool queue, no label is produced. Any ideas?
4 Suggested Answers
bartech9
  • 155 Answers
SOURCE: Printing on a continous teffeta label using zebra S4M zpl printer
Con un windows driver, sí imprime? Intenta reiniciar la impresora con los parametros de fabrica. La impresora tiene zpl o epl firmware?
Roberto Martinez
Posted on Oct 06, 2009
  • 32 Answers
SOURCE: Zebra S4M label printer
Check the drive belt. It might be missing a tooth if the printer is older. I can assist if you want to check this.
Posted on Oct 27, 2009
ozztech
  • 285 Answers
SOURCE: Zebra, I have a Customer that has your Zebra
the problem can be on the software that bild the label format, not on the printer.
Posted on Nov 23, 2010
I am trying to install a lp 2824 plus zebra label printer and i need to know whether to select epl or zpl?
You should probably select ZPL, but that depends on which program you will use together with the printer.
Jun 20, 2011 | Zebra LP 2824 Printer
Good day, We are currently using a Zebra 2746E, that needs to be replaced, the problem is we have a huge amount of labels designed in Create A Label, is there a way to use a new Zebra S4M with the...
the language from your printers is EPL and the zebra S4m come from factory with ZPL language program, you need to install diferent firmware to the printer,
"...This firmware release includes all features of the previous V4.49 release. It is for use with
the following EPL printer models:
• TLP 2746e..."
Special Firmware Version Size E53.17.3 3 MB
http://www.zebra.com/id/products/global/en/firmware/barcode/e53_17_3.NotesFile1.File.tmp/14328L-006.pdf
download the firmware, go to the driver and "send file" and send the file *.zpl to the printer.
Nov 22, 2010 | Zebra Create-A-Label 3 (105580-001) for PC
I have an S4M that is used in a stand-alone label printing app. It connected to a KDU and receives input via RS232 connection. It has a stored label file on the printer. The problem is occasionally the...
The printer file is recorded in flash memory? The printer have EPL or ZPL firmware? Using ZBI may be a better solution, developed an application that stays in the printer memory and allows many uses.
Roberto Martinez
Sep 30, 2009 | Zebra S4M Thermal Label Printer
How to print to zebra s4m 203dpi using vb6 and usb port
You can generate the ZPL code in a text file and send it to a generic printer connected to USB.
Roberto Martinez
Sep 28, 2009 | Zebra S4M Thermal Label Printer
My zebra printer s4m is saying ALERT CLEARED HEAD OPEN, ALERT RIBBON OUT
Alert Head Open will show everytime u open the Head , when u close back the head it will show Alert CLeared Head Open, then it's normal.
Ribbon Out Show means the printer doesn't detect a ribbon, make sure there's nothing wrong with ribbon installation. if everything fine, then the problem is you Ribbon Sensor. u can try to adjust the sensor with a screwdriver ( - ), make a little bit higher
Jul 11, 2009 | Zebra Thermal S4m Dt Zpl 203dpi Rs232/par...
Roberto Martinez
Jun 30, 2009 | Zebra S4M Thermal Label Printer
How do I identify my SM4??
try looking at the bottom of the printer, it should have the detailed model in there
Jun 22, 2009 | Zebra S4M Thermal Label Printer
S4M doesn´t print
The S4M comes with either EPL or ZPL programming language installed. (installed at factory) The S600 is a ZPL only printer. Check that you have correctly specified the S4M as a ZPL printer. Print a config label to check. If it is set as an EPL printer contact your supplier and ask him to download the correct programming language. It should only take a competent engineer about ten minutes (If he knows what he is doing)
Jan 20, 2009 | Zebra S4M Thermal Label Printer
Zebra Thermal S4m Dt Zpl 203dpi Rs232/par & Usb Label Printer Logo
116 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
