Brother mfc printer
I can't get my brother mfc printer to print from the computer, It goes the process, but the paper comes out blank. Lera
  • 56 Answers
Hi Lera,
In you brother suite you can go to the maintanence tab and do the nozzle clean and print head allignment.
After you do that print a test page, either from the suite on in the properties of your printer.
You can also do general maintanence from the LCD screen on the MFC.
Scroll through the menu and you will find there are options for head cleaning and nozzle allignment.
Hope this helps.
Posted on Jan 19, 2008
I have a Brother MFC-295cn. I first ran out of blue ink. I replaced it and it was working fine. Then it started printing out blank paper. it goes through the motions but paper comes out blank. Anyone...
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 17, 2012 | Brother MFC 420CN All-In-One InkJet...
I am using my Brother MFC 240 C printer for the first time. I bought all new ink cartridges, installed them, the printhead cleaned....all that to say everything seemed to be in order. When I press print...
Hello.
Brother printers have very fine tubes running from the cartridges to the actual print head itself. Using it for the first time you may need to run the head cleaning process up to 3 times to get the ink primed to the head correctly.
If it still does not work i would say that it is a mechanical failure and recommended taking it back to where you purchased it from for a replacement.
I hope this helps Regards GM
Apr 26, 2011 | Brother Multi-Function Center MFC-240C...
My Brother Printer (model MFC-290c) and ink
On your printer take a look on the "ink management button"press it then look for cleaning using the arrows up and down then press ok or set or what ever the command the printer will display just try to perform head cleaning.try for several times lets say 4x don't clean too much it might ruin all other color if it has no changes try to bring it to a service center,they can soak it to a chemical solution,the head is clog.
Sep 10, 2009 | Brother MFC-290C Printer
Brother MFC 4420C prints plain sheets of paper.
To start ensure that is not a software problem.
Go to Control Panel >> Installed Printers. Remove the printer. Install the printer again using the software disk or downloading the driver software from Brother website.
If that does not fix the problem, and the printer prints blank sheets, then it is usually a clogged printhead.
The printheads can be cleaned removing the ink carriage and soaking it in isopropyl alcohol overnight. If that does not work, then the printhead must be replaced.
Regards
Jun 17, 2009 | Brother MFC 4420C All-In-One InkJet...
Brother mfc paperfeeding problem
does the fmc240 has a back to stop paper from going out and when the paper comes out without the back, it only blank paper that comes out
Feb 12, 2008 | Brother Multi-Function Center MFC-240C...
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Will not print
Did you do a testprinting after cleaning? Do you have all blocks in bk, c, m and y?
Sep 13, 2007 | Brother MFC 210C All-In-One InkJet Printer
Computers & Internet Logo
112 people viewed this question
Alun Cox
David Payne
David Payne
