Question about Nokia 5800 XpressMusic Smartphone
Does not actually start up (screen with weird lines)
It is first time I use it (well, I try to). I first plug the charger and the red light remains off. I do not understand but the phone's guidebook says it may happen in case the battery comes really off from the factory. I wait for hours and the charger light always remains off. Does not matter! I try to switch it on anyways and the phone actually starts up, but it shows a weird screen with some crooked lines that look like ray lights. And after that, nothing happens: does not ask me for the date, not the pin code, no nothing.
I guess the phone is not broken as it actually starts up, but I do not understand why the charging light does not light up an neither why the phone does not start working. Could someone give a hand? Thanks!
What could be the problem if my son dirt bike says its fully chaged but when he turns the throttle nothing happens
Did the socket the charger was plugged into actually have 120vac in the socket?
Or are you sure the charger is actually working? Is there a short so that the battery is draining as fast or faster than the charger is providing a charge?
Mar 27, 2015 | Razor Dirt Rocket MX350 Miniature Electric...
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
I took this blackberry bold out of a recycle bin at my school and when i plug it into my dads bb charger the red light comes on but after 10 minutes of charging it still wont turn on.I think its a corrupt...
try this:
JUMP STARTING A BLACKBERRY
1. Plug wall charger into wall and then plug into blackberry
2. Take off back cover and pull the battery out (while it is plugged in still)
3. Wait 30 seconds. The red LED may remain on (tech said it didn't matter).
4. Put the battery back in and wait about 5-10 seconds and it'll begin to boot up (white screen with clock icon).
Jan 28, 2011 | Computers & Internet
MY BLACKBERRY BOLD 9000 WON'T TURN ON!!! My friend gave me her Blackberry Bold 9000. It's battery was replaced a few months ago but it hasn't been used since then. When I plug it into the wall charger,...
Ok...don't panic. The charger you are using is not compatible. Verizon only works with verizon blackberry's. Non verizon will not work with blackberry and vice versa. This is what will happen. you plug it in and it will boot for a few seconds and then the lightning bolt you see is the charge icon and then a red line in it means that charger is not compatable. Blackberry does make its own charger but there is a "pin" on the plug in that will tell it it is not the right one. Am I confusing you?
Jan 06, 2011 | RIM BlackBerry Bold 9000 Smartphone
My 32LG70 won't turn on and the screen remains blank.
Try resoldering everything back onto the power board.They become brittle sometimes.
That doesn't do it then buy a cheap cap meter off ebay for around a tenner and firstly pull off every single electrolytic then ceramic capacitor and test.
Very easy to test,look on YouTube for videos.
Replace faulty&marginal caps and your problem should be gone.Remember m8,take your time,don't rush these things.
Jun 05, 2010 | LG 37LG30 37 in. LCD HDTV
Nokia N900 not turning on or charging
not turning on. red notification light showing
May 14, 2010 | Nokia N900 Smartphone
Completely blank screen when power is on.
do a hard reset....remove charger>remove peripherals>remove battery> press and hold the power button for about 30secs, while batt and charger is removed> then plug in the charger only and turn ON!
Please vote, thanks!
Jun 27, 2009 | Acer Aspire One Netbook 8.9" Notebook
Compaq V5005us is weird. Powers on with black screen and freezes
It sounds like your Video card and/or motherboard are starting to give out or your LCD is giving way. Try plugging the laptop into an external screen and see if it still acts strangely or even displays on the external monitor.
Mar 18, 2009 | Compaq Presario 2100U Notebook
Red screen of death
try to, borrow your friends batt and try, and if it's not working,, then here's what they gotta do put the cables in your fone and flash your fone with firmware and it will go back all to normal.. only prof's can do it, bring it to the center
May 10, 2008 | Motorola Mobility RAZR V3
Nokia 5800 XpressMusic Smartphone Logo
100 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
