Question about Samsung Tocco F480 - Pay Monthly Cellular Phone
Hello I was wondering how I put my samsung f480i into discovery mode on my bluetooth
Microsoft bluetooth mobile keyboard 6000
Wireless keyboards connect to tablets using Bluetooth, a wireless technology with a short range of only about 30 feet.
In most cases, you can prepare a keyboard to connect with a tablet simply by turning the keyboard off, then turning it on again while it is close to the tablet.
Read the instructions that came with the keyboard to see if it requires a passkey to connect with a device.
The passkey ensures that your keyboard is not accidentally connected to another nearby device. The steps required to connect a tablet to a wireless keyboard can vary slightly depending on the tablet's operating system.
Unlike docked keyboards, a wireless keyboard does not have to be designed for your specific tablet for it to be usable.
Turn on the keyboard and put it in discovery mode.
Place it near the iPad.
Tap the "Settings" icon, then tap "General."
Tap "Bluetooth" if it is in the Off position.
Tap the "On/Off" switch to turn it on.
Choose the wireless keyboard when it appears on the screen. Enter a passkey for the keyboard if prompted.
The keyboard name and a Bluetooth icon appear on the screen.
BlackBerry PlayBook Tablet
Turn on the Bluetooth keyboard and put it in discovery mode before placing it near the tablet.
Tap the "Settings" icon on the tablet status bar, then tap "Bluetooth."
Tap the "Bluetooth" switch to choose the "On" position.
Tap "Add New Device," then select "Search."
Wait a few seconds for the keyboard to appear.
Enter the keyboard passkey if prompted.
Samsung Galaxy Tab (Android)
Turn on the wireless keyboard and put it in discovery mode.
Place it near the tablet.
Navigate to the Home screen. Press the "Menu Key," then select "Settings."
Tap "Wireless and Network," then "Bluetooth Settings."
Tap "Bluetooth" to turn it on, then tap "Scan Devices."
Select the keyboard by tapping it.
Enter the passkey if prompted.
HP Slate (Windows)
Turn on the wireless keyboard while it is near the tablet, then put it in discovery mode.
Tap the Start button, then "All Programs."
Tap "HP," then "HP Connection Manager."
The device searches for nearby devices and lists them.
Locate the keyboard in the list, then tap the "Power Button" beside the keyboard entry.
Enter a passkey if prompted.
http://bluetooth.org/
Jun 29, 2013 | Microsoft Bluetooth Mobile Keyboard 6000
My bluetooth isn't work...my windose is 7...when i turn bluetooth of my cellphone and my laptob my cellphone found it but the laptob bluetooth couldn't find it.
Hello, the reason your laptop cannot find your cellphone is becaus the cellphone's bluetooth is not in discovery mode. You will need to put the cellphone into discovery mode. To do that, open your bluetooth settings, and choose discovery mode or something like that. Then have the laptop look for new devices.
Thanks for using FixYa!
Jul 01, 2011 | Computers & Internet
I have a samsung behold T919 & I am trying to pair my Emerson EM228WM Bluetooth Headset to my phone but it wont find the signal please someone help me! Thanx :)
hello ,now most blue tooth devices have to be put into a discovery mode,if you dont have your owners manual to follow the procuders most of the time you just hold the power button while turning the bt device on for 6 to 10 seconds and that turns it into discovery mode usually a solid light is on then when the device is found it will ask for a pin or pairing code,this is a 4 digit code,most manufactures use the following codes,0000,1234,9999,1111, hope this helps you out.
Feb 21, 2011 | Southern Telecom Emerson Bluetooth Headset...
How do i pair with an iphone 3g
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 23, 2010 | Samsung S3650 Corby blackwhite + WEP 490...
I was wondering how to hook up a Bluetooth headset to a Samsung Gravity
Hold down round button on earbud for 5-6 seconds until it flashes alternating red and blue. Then set your device (Phone/PDa) up for connectivity by allowing it to be discovered...Once your phone is in discovery mode, it will search and hpefully find the earbud.
Jun 29, 2010 | Samsung Gravity SGH-T459 Cell Phone
How to use bluetooth headset in samsung corby???? plz plz help me
1. Just activate the bluetooth in your mobile.
2. Put your bluetooth headset in discovery mode (for this you may need to press the ON button in your headset for more no. of secs around 15 secs) . Please read the user manual of your bluetooth headset to know about how to put it in discovery mode.
3. After that, search for bluetooth devices in your samsung mobile.
4. your headset should be detected in your mobile. If not, still your bluetooth headset is not in discoverable mode. you have to turn it on and try again.
5. If listed in your mobile, select it and it may ask for Passcoe. Provide 0000 as passcode. Thats all now the bluetooth headset is connected to your mobile. If passcode is not accepted, then please do refer the device manual to know about that.
I hope this is useful to you.
Thanks
May 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
I am having trouble getting my 6230i to pick up my bluetooth headset.
you have to put the Bluetooth in pairing Mode and put the Phone in Discovery Mode also.
to put your bluetooth in discovery Mode - press and hold the middle button for about ten Seconds and when it starts flashing - or stays on a Sold Color ( red or Blue ) depending on the bluetooth. - - that means it is in Pairing mode.
hope this helps
thanks
Mar 31, 2010 | Nokia 6230i Cellular Phone
How to put my n82 nokia into discovery mode
Go to your Connectivity>Bluetooth>My phone's visibility>change to "Show to all". That's it.
Sep 06, 2009 | Nokia N82 Cell Phone (Unlocked) - Silver
4pr909 bluetooth headset passcode won't work with samsung juke
had same problem with this headset on two phones and finally solved it.
1. make sure bluetooth on phone is activated (know that sounds silly but some people forget)
2. with the headset turned off, press and hold the on/off button on the headset until the light on the headset FLASHES CONTINUOUS BLUE AND RED (about 8 seconds). This is most important, because if lights on headset are not continuously flashing blue and red, the headset is not in discovery mode.
3. once headset is in discovery mode, go into "my devices" on bluetooth menu on phone and click to search for new devices. make sure phone and headset are close together. phone will say searching- BE PATIENT, THIS STEP TAKES THE PHONE SOME TIME. eventually phone will show that it found your headset.
4. once the phone lists the headset, click on the headset and tell the phone to connect to the device. at this point the phone will bring up a passcode screen. enter 0000, and tell it to connect. when it connects, the lights on the headset will automatically go to an intermittent blue. you should be all set.
the biggest mistakes my kids made trying to pair these headsets were:
1. failing to turn bluetooth on for the phone
2. turning the headset on in something other than discovery mode (continuous blue/red flashing lights)
3. not being patient enough to wait for the phone to find the device.
hope this helps
Dec 21, 2008 | Cell Phones
Reseting Jabra Bluetooth
Jabra headsets sometimes have a different way of being put into discovery mode. Most headsets just have you press and hold the big call button on it. Some jabra headsets require you to JUST hold down both volume buttons and some other jabra headsets require you to hold down ALL buttons on the headset to put it in discovery mode (or pairing mode as they sometimes call it)
Try of those combinations ... The light will stay solid when it's in discovery mode... Once the light is solid THEN have the EnV search for headsets.
hope this helps
Dec 18, 2007 | LG enV VX9900 Cellular Phone
Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
118 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
