Question about Neff U1721 Double circotherm Electric Oven
There is only one wire available for attaching to the oven element. If there was a 2nd one it must have come off behind the oven, how do I get to it ?
  • Neff Master
  • 3,463 Answers
You will have to remove the oven from the housing if it is built in, then remove the rear cover, and possibly the top.
This should give you access to the element terminals.
Hope this helps .
Posted on Dec 10, 2009
My ariston oven won't turn on. The stove works and
check and see if the broil works in the oven ,2 if it turns on meaning the element in the top turns red then this generaly means both side of the switch are good. and you need to replace the element on the bottom of the stove.now turn off the stove .1st unplug the stove. 2nd there are 2 screws at the back of the stove on a metal plate which is attached to the element take them off.3rd gently pull out the element about 3 inches until you see 2 wires. there are 2 ways the wires could be connected either push on or by screws if you dont see a screw abviusly its push on. just grab the end of the wire ON the connecter and grab the elemnt at the connecter and wigglethe connector back and forth while pullin on the connecter. wala. now locate the model number and go to amazon.com or your local parts house and install in reverse
Aug 20, 2012 | Ovens
How do you replace bottom element in top oven?
Turn off the power to the oven at the breaker box.
Take out the screws holding the element bracket in place. These will be on the back wall of the oven, or sometimes on the top.
Pull the element toward you a little bit until you see the wires behind it.
Unscrew the leads and take the bad element out.
Hold the new element up while you attach the wires to it. Don't stretch the wires any more than you have to.
Line up the element while tucking the wires back in. Be sure not to pinch the wires between the bracket and the back wall.
Fasten the brackets, making sure they're tight.
Restore power to the appliance.
Dec 23, 2010 | Ovens
Something went on fire behind the fan,there was a buirning smell and there was orange light coming from behind the fan. Now the oven wont heatr up
That fire and burning smell was your oven element burning out. The element is located directly behind the fan. This is why your oven will no longer heat up.
If you are going to replace the element yourself, there are some universal elements available (try eBay) much cheaper than the OEM replacement parts. You need to make sure it's the same rating though (e.g. 2000W) and is roughly the same dimensions and has the same fitting pattern.
You will also need a service manual unless you know how to get access to replace the element.
Oct 06, 2010 | Neff B1421 Electric Single Oven
When replacing an element in a neff oven, what should I do with the earth wire? There's no point on the new, replacement element to which I can attach it to. Do I just wind a bit of insulating tape around...
So long as you make it safe, it does not matter if it is not connected, as the element will still be earthed via the cabinet earthing connections.
Please rate my solution.
Thankyou.
Jan 20, 2010 | Neff U1421 Double circotherm Electric Oven
Replacing heat elements in oven
To replace oven heat element follow the steps below carefully
  • Step 2 Take out the screws holding the element bracket in place. These will be on the back wall of the oven, or sometimes on the top.
  • Step 3 Pull the element toward you a little bit until you see the wires behind it.
  • Step 4 Unscrew the leads and take the bad element out.
  • Step 5 Hold the new element up while you attach the wires to it. Don't stretch the wires any more than you have to.
  • Step 6 Line up the element while tucking the wires back in. Be sure not to pinch the wires between the bracket and the back wall.
  • Step 7 Fasten the brackets, making sure they're tight.
  • Step 8 Restore power to the appliance.
  • basically to install the elements , place it in the same position as the old one. Connect it the same way the old one was connected, using the same screws to hold it in place. Just about all the other components of an electric range or oven
  • Jan 03, 2010 | Jenn-Air Ovens
    How to get the heating element out of the large oven in a De Dietrich DOD348*
    If you mean the element at the back (not the bottom one), inside the oven undo a screw at the back to reveal the element, then undo one more screw attaching the element. THEN, totally disassemble the oven, removing all the cladding, taking off the top oven and controls, detaching lots of wires to be able to do this, in order to finally gain access to the 2 little nuts securing the element behind the oven. Then if you're not sufficiently dismayed by De Dietrich's design skills, email their customer service to be given the wrong part recommendation at twice the price of an independent supplier. Finally, buy part from independent supplier, spend several hours dismantling and rebuilding oven. Then it will work. But maybe don't ever buy De Dietrich (Brandt) again!
    Dec 22, 2009 | De Dietrich Ovens
    MY BOTTOM ELEMENT & MY TOP ELEMENT WILL NOT HEAT UP IN MY OVEN THE STOVE WORKS FINE
    It would be very unlikely that both elements went out at the same time. Is it possible that one element went out a long time again and went unnoticed?
    Do this: Turn your oven on BROIL and the temperature up all the way and see if the top element begins heating.
    Then turn it on COOK and see if the bottom element comes on.
    If both elements fail to work then your problem may be in the selector or thermostat control. You may also have a wire that has come loose (or burned loose).
    If you are comfortable working with electricity, you can turn the circuit breaker off and remove the controls for testing. Also, verify that all the wires are properly attached.
    If you are not comfortable, have a service technician check it out immediately. It scares me that there may be a loose wire behind the control panel!
    If one of the elements worked and one did not then the problem is "most likely" a bad element. Turn off the circuit breaker to your oven and make sure all the knobs are off on the oven and you can remove the element and take it to a parts store for replacement.
    It is easy to remove. Take out the wire shelves and unscrew the screws where the element goes into the back of the cooking cabinet. There will be some wires attached which should pull off.
    Good Luck!
    Oct 28, 2009 | Ovens
    Oven won't heat.
    EUREKA! I found the reset button and my oven is heating as we speak. Ok, open the oven door. there is a thin panel with vents right at the door latch. Unscrew the (6) screws and pull off the panel. There is a red button on the left back behind the wiring. GOOD LUCK!
    Dec 08, 2008 | Dacor ECS130 Epicure Electric Single Oven
    I lost the one element wire behind the unit, can I get to it?
    yes, but the unit will need to be pulled out. then, you can unscrew the back panel and attach the wire to the element. Joe
    Nov 19, 2008 | Whirlpool RBD305PD Electric Double Oven
    How to replace a fan bake oven hidden element
    Before attempting any repairs, make sure the power is turned off! If you are unsure or not confident, please call a service technician.
    The element is behind a cover that is held in place either by screws or clips. Once the cover is removed, the element will be visible. The element will be screwed in place by a number of screws on the base plate and around the element itself. After removing the screws, pull the element fron the rear of the oven. the wires should be attached to the element via lugs. The lugs need to be unattached from the element. Before removing the wiring, take note of the connections so that reinstallation can be carried out.
    Oct 25, 2007 | Fisher and Paykel AeroTech - OS302M...
    Neff U1721 Double circotherm Electric Oven Logo
    79 people viewed this question
    Top Neff Ovens Experts
    Hjalmer Lamminen
    Hjalmer Lamminen
    bobby1964
    Level 1 Expert
    Paul Carew
    Are you a Neff Oven Expert? Answer questions, earn points and help others
