Question about Metrologic Instruments Eclipse MS5145
Plugged into USB port and message came up saying drivers installed successfully but barcodes do not appear either in word or excel. operating system is Vista.
    Novelist:
  • 75 Answers
Try the drivers located at:-
http://www.honeywellaidc.com/Site.aspx/eu/en/product_center/product_support/?category=38&product=296
Metrologic are now part of Honeywell.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Posted on Dec 10, 2009
Testimonial: "fixed thanks"
Hello, I am trying to install my d-link 125 usb adapter. I had to download the windows 7 driver from the d-link website, and now I am trying to install it to my computer. When I try to run the driver...
Use the following steps to let Windows do the installation for you.
Step 1: Use an Ethernet cable and plug your computer directly to your Internet gateway. Make sure Internet is accessible.
Step 2: Place your new adapter in the proper slot or port.
Step 3: With your computer running, a bubble message will appear stating that this device was not installed successfully. Left click on the message.
But if the message no longer appears, skip to Device Manager Installation.
Step 4: On driver installation failure, you can change the setting to use Windows Update by clicking Change setting...
Step 5: Chose to allow Windows to update your driver when it is not found on you computer.
Step 6: Once the driver installs successfully, close the window.
Step 7: Click/Right Click on the Network Icon located on the system tray to View the Available Wireless Networks. Find your personal Network and double click to connect. It should request for a wireless key, which by now should have been set up.
Oct 26, 2011 | D-Link DWA-125 Wireless 150 USB Adapter...
Good day I am in need of drivers for an LG external HDD hxd7.Reason being my laptop will not recognise the hdd but sometimes it does.
Hi
You do not say which operating system you are using.
You do not say which type of computer this is (laptop or desktop).
Most operating systems do not need extra drivers to recognize a hard drive. The drivers are almost certainly already built into your operating system to operate almost any hard drive.
It could be a faulty USB port (try a different USB Port) or a faulty USB cable (try a different USB cable).
If the cable and port are not the problem, then either the hard drive itself or the hard drive enclosure are faulty (open the enclosure and test the hard drive in a hard drive dock or another (custom) external hard drive enclosure.
I hope this helps.
Aug 29, 2011 | Computers & Internet
USB DEVICE NOT RECOGNISED
Be sure the problem is not from the cable, by confirming that the cable works well with another phone. If it works well on another phone, try another USB cable.
If it shows the same message, then connect the cable to a different port on the PC.
If the message still shows plug it into another system.
If it works on the other system, then the device was not recognised on the initial system because USB ports must have been faulty.
You would have to un - install, then re - install the USB drivers.
Do this by clicking 'My Computer', then 'Device Manager'. Select 'USB Ports'. Right click it and select Re - install.
But if it still does not work on another system, and then your phone's USB port might need to be changed.
Hope that helped?
Success.
May 12, 2011 | Nokia N95 Cellular Phone
I put the disc in the drive follow the instructions then when it asks to plug the USB port in a few secounds after it says "inatallation unsuccessfully please help
Hello benlaverick
Do not plug the usb port before finishing full installation of the device .
The best way to get your device running is to delete the software ( if installed , check in Control Panel \ Programs ) , disconnect usb port ,reboot , install software / driver and reconnect usb port .
You should get a confirmation message of successfull installation and the device should run .
Make sure you have installed a compatible driver with your OS .
Best regards
fanaudi
Mar 15, 2011 | Computers & Internet
Can't transfer or view images from camera to computer. All USB ports are working on computer. Double checked connections. Get following messages: 1. installing device driver software 2.searching...
Consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 16, 2010 | Sony Cameras
How do i install my printer without a cd
You do not say what type of printer you are using, or what operating system and version, so help will be fairly limited on this forum!
Most manufacturers publish printer drivers on their web sites.
Oct 29, 2010 | Computers & Internet
I have connected my 4Gb Usb Device to my PC, But
insert the usb drive
if a notification bubble appears click it
a dialog box appears showing the new hardware found
click on the detect automatically button.
it starts searching..
if the driver is in r system it installs
if not download the driver from net
write the device model number and company
check ur usb port......
try using in ur friends computer
Mar 11, 2010 | HHP ImageTeam 4710 Barcode Scanner
USB ports work at 1.1; s/b 2.0
Your computer is functioning correctly.
The USB ports on your laptop are USB1 ports its pard of the hardware.
Your PCMCIA USB 2 card runs at USB 2 speed and therefore when you connect a USB 2 device to this port you will not get this USB message.
Jan 18, 2009 | Lenovo ThinkPad R51e Notebook
Failure to install X4650
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X4650 InkJet Printer
Lexmark z11 Vista Compatible?
Looks like I've cracked it [Touches wooden desk]. Need a USB to IEEE 1284 36-pin Parallel Printer Cable, like the one I received today (ordered yesterday from www.cables2u.co.uk). First, connect it to Z11. Turn on Z11 and boot up Vista PC/laptop. (I run Vista Business on my laptop.) Connect cable to computer. Message appears "Installing device driver software". Click it for status. 'Found New Hardware' box appears. Click 'Locate and install driver software'. A message appears "Error loading LXADSUI.DLL. Specified module could not be found". Click 'OK'. Message appears saying driver software installed successfully. ["Yeah, right ..."] (Have faith, folks!) Now, click Start, then Control Panel and double-click Printers. Right click on Z11 and click on Set As Default Printer. Right click on Z11 again and click on Properties. Check on Ports tab that Port USB is ticked for Z11. On Cartridge Maintenance tab, check right cartridge is showing. If not, click 'Install/Change Cartridge' and follow instructions. Then 'Clean Print Nozzles' and 'Align Cartridges'. Check settings on the other tabs in Properties look OK and try printing a test page! It looks good to me!
Jan 15, 2008 | Lexmark JetPrinter Z11 InkJet Color...
Metrologic Instruments Eclipse MS5145 Logo
589 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
jackcity
jackcity
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
