Question about Uniden PCD2000A Cellular Phone
How do I change the nam and sid
Or get it to just work with the american roaming network
Samsung flip phone manual
Roaming setting is part of a service from your phone service provider and is not controlled by the phone itself. You will have to call your phone service company and find out what roaming you need.
The network selection mode setting will have to change on your phone to ensure you pick up the correct network overseas once your roaming service is set.
Aug 29, 2014 | Cell Phones
How to turn digital roaming off?
  1. On the Home screen, click the Manage Connections icon.
  2. Click Mobile Network Options.
  3. Perform one of the following actions:
    • To turn on or turn off data service, change the Data Services field.
    • To turn on or turn off data service when roaming, change the While Roaming field.
    • To receive a prompt when roaming that allows you to turn on or turn off data service, change the While Roaming field to Prompt.
  4. Press the Menu key.
  5. Click Save.
Apr 20, 2012 | Samsung Cell Phones
HOW TO OPENLINE HITACHI CDMA W42H???
All type of phones (old modeles):
NAM programming: 47*869#08#9
Test mode: *759#813580 or 5809540*45680
exit test mode - 02
A-Key: menu + 0, code 25##
Samsung A500
1. Enter ## and the 6 digit OTKSL
2. SERVICE MENU will appear and 1.Basic will be highlighted
3. Press OK
4. Device will display NAM CDMA/ Phone Number
5. Enter 10 digit MIN
6. Press OK (3 times)
7. Display will return to Service Menu. Press END.
8. Programming is complete
Samsung N240 and N400
1. Enter ## and type in the 6 digit OTKSL
2. The display will show SVC MENU and 1. Phone Number
3. Press OK
4. Enter the 10 digit MIN and press OK
5. The display will show NAM with Home SID on the second line (Note: SID is no longer used)
6. Press OK
7. The display will return to the SVC MENU
8. Press END to complete the programming
Samsung Uproar
1. Press MENU key
2. Enter 9 2 0
3. Enter the OTKSL
4. At SVC Menu screen press OK
5. Enter MIN and press OK 4 times
6. Enter SID (4654) and press OK
7. Press END key
Samsung N300
1. Press ## followed by the OTKSL
2. SVC menu will be displayed
3. Press 1 for Phone #
5. MIN that was entered will be displayed press OK
6. SVC Menu will display press 3 for NAM
7. Enter the 4 digit Home SID press OK
8. Press END and handset will power cycle
Samsung i300
1. Tap on the Phone Icon with stylus
2. Press #907*9#0 ENTER LOCK should appear on screen
3. ENTER OTKSL
4. SVC MENU will appear press 1
5. Enter 10 digit MIN and then press SAVE
6. Press SAVE again
7. Press 3 and then press SAVE 6 times
8. Enter the HOME SID and press SAVE once
9. Press END key twice
Samsung A400 and A460
1. Enter ## and OTKSL
2. Press 1 for Basic at MENU (1 of Phone # when using the MSL)
3. Enter 10 digit MIN and press OK
4. At 1.Basic Menu press the END key
5. Handset will power cycle
Samsung 3500 8500 6100 N200
1. Press MENU
2. Press 6 0 (3500) 8 2 0 (8500/6100/N200)
3. Enter OTKSL
4. Press 1 at SVC MENU Screen
6. Press OK 4 times
7. Enter SID (4654) and press OK
8. Press END key
9. Programming is complete
Qualcomm:
QCP-800 programming: menu + 3 + 0.
SPC: "000000" or may be other SPC typed by user.
QCP-820/1920/2035: type "111111" and press Jog Dial.
Choose "Programming" and enter SPC: "000000" or may be other SPC typed by user.
QCP 1960 and 2760
1. Press softkey under the work MENU
2. Press 8 0
3. Enter the OTKSL
4. Press softkey for OK
5. Enter MIN and press softkey for OK
6. No SID is require for this handset
7. Press softkey for EXIT
LG:
LGC-300 programming: menu + 9 and enter SPC: "000000" or may be other SPC typed by user
A-Key: press STO for some time while you can see special code enter zone. Type 2539** and enter A-key
LGC-330W programming: menu + 4 + 0 and enter SPC: "000000" or may be other SPC typed by user.
A-Key: type 2539** and enter A-key
LGC-800W /500 programming: menu + 0 and enter SPC: "000000" or may be other SPC typed by user.
LGC-510 programming: menu + 3 + 0 and enter SPC: "000000" or may be other SPC typed by user.
LG1010 LG4NE1 TP2200 TP2100 Touchpoint SB/DB TP 1100 TP5200
1. Press ##
2. Enter the OTKSL
3. Scroll to SAVE and press OK
4. Scroll to MIN and press OK
5. Enter 10 digit MIN scroll to SAVE and press OK
6. Scroll to SID and press OK (Skip on 4NE1 go to RESET PHONE and press OK to complete)
7. Enter SID (4654) and scroll to SAVE and press OK
LG5350
1. Enter ## and enter the OTKSL and press the left soft key under the word clear.gif
Mar 01, 2012 | Cell Phones
I changed from NAM 1 to NAM 2. and lost unlock code
Try this URL : http://www.blurtit.com/q1652331.html
Nov 27, 2009 | Samsung Smooth SCH-u350 Cell Phone
Unlock my Samsung!!!
enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to
Sep 05, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Please find my motorola security code
To enter the secret menu mode: flip open phone and quickly enter: #073887* then enter your Security Code (default is 000000). It has menu items Web Sessions, Browser Reset, User Activation, AKEY, Extended NAM, Vcode, Data Rates, SPC Overwrite, System ID, SID/NID Pair, Test Mode, and Get It Now Config. Note: to get out of test mode (white background and blue text), press CLR then left soft key quickly. User Activation
To enter the secret menu mode: flip open phone and quickly enter: 74663#[CLR][CLR]. You will see the "User Activation" menu and have two items listed: NAM 1 and NAM 2.
Enter Operator Codes
TODO: 3/30/2006 - Find if this is available on the VZW Phone.
Jul 15, 2009 | Motorola Mobility RAZR V3m Cellular Phone
I have the same problem stuck in nam 2 cant unlock it
I did this on my SCH-u740
1. Dial: #43574357*
2. Select "System Info"
3. Look for SID (There should be a number beside it)
4. Use the last four digits of the SID number as your lock code.
Jul 11, 2009 | Samsung Glyde SCH-u940 Cellular Phone
I DON'T know what is initial programming is?
initial programming occurs when your phone needs a second roaming based and if you accidentally change the NAM settings of your phone to NAM2. the default NAM settings of your phone is NAM1.
Jul 01, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Phone activation american roaming network
The one you got from Ebay is defective. you were scammed. There is no such thing as the American Roaming Network, ARN is like a collect phone call service. You were scammed. Return the phone if you even can. sorry about that
Mar 20, 2009 | LG Rumor LX260 Cellular Phone
I have a Samsung U520 and I accidentally activated NAM2. Now my phone does not work. When I try to deactivate NAM2 it asks for a password. Can you help? It needs a 4 digit code. It also states Initial...
hi sir have you done restore factory settings firstThe Nokia 2160 series hand portable CMT uses an EEPROM NAM that can be programmed directly from the standard user keypad. In order to access the
NAM, you must enter the special access code currently programmed into the
phone. Once the programming mode is accessed, NAM parameters are loaded
by entering them into the display and "storing" them to selected memory
locations. Be sure to obtain all parameters before proceeding.
EASY NAM PROGRAMMING
1. Turn on phone.
2. Enter the Easy NAM access code. Access code is: *#639#
3. Verify the display now reads "Cellular Number" and enter the 10 digit
MIN for the phone.
4. Press the softkey under the word "OK" in the display. If less than 10
digits are entered an error message will prompt you to reenter the
number.
5. Verify the display reads "Enter code" and enter the five digit SID
followed by four zeros. (Example 001750000 is a SID of 175 followed
by four zeros). An error message will display if an incorrect entry
is made. Do not add more than four zeros to the code.
Note: Change the Lock code by adding a pound sign and new lock code after
the code. (Example: 001750000#7788. Lock code = 7788).
Change the Language code by adding a pound sign (#) and new
language code after the code. (Example: 001750000#2. Language = 2)
Language Code: 0 (default) = English, 1 = French, 2 = Spanish,
3 = Portuguese
Change the Lock code and Language code by separating each set of
numbers by a pound sign. (Example: 001750000#7788#2). The SID =
00175, Lock code = 7788, Language = 2 (Spanish).
6. Press the softkey under the word "OK" in the display.
7. The display will tell you t
Sep 10, 2008 | Samsung Cell Phones
Uniden PCD2000A Cellular Phone Logo
220 people viewed this question
Top Uniden Cell Phones Experts
castletech
castletech
Are you an Uniden Cell Phone Expert? Answer questions, earn points and help others
