Question about Acer Computers & Internet
Can not find lead or plug to connect to tower
It was the lead from epson printer to tower PC world supplied a new usb cable which did the trick
Posted on Dec 11, 2009
I put new power supply and button to turn and wot turn on
Do the fans come on. ? on the power supply. Do you know if power comes out of the power point. Can you plug in a lamp into the power point and get power out of the power point and light up a power point. Do you have a VOLT METER you could test the
DC leads coming out of the power supply .
There may be a power lead that powers the CPU fan have you connected this to the cpu cooling fan connection point on the motherboard .
Mar 15, 2015 | HP Pavilion Slimline s5-1414 Core i3-2130...
Tower comes on but not the monitor
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Test all power and data leads that attach to your hard drive IDE,SATA the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even something as small as a faulty electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error Check your RAM. The RAM is located in the middle of the motherboard. There are tabs that you can push to release the RAM. Remove it and put it back in place until the tabs pop out. Loose RAM can cause your computer not to start properly where you want to see a video signal.
Make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free Restart your computer then reinstall it this should activate found new hardware wizard Check the vga lead for secure dust free connection or try another vga lead.
Mar 02, 2013 | Acer Computers & Internet
Fujitsu tower smoke out of rear no power
Sounds like you need a new power supply. Have a look at the labels on the old one inside the tower. The thing to look for is the total power output in Watts.
If it's 300watts for example then buy another with the same or higher wattage, I would go for a higher one. Then check the leads that come out the back in to the drives and motherboard etc. Especially the power to the motherboard. If it's a 20 pin socket thats the standard, if it's a 24 pin socket thats the more modern type but can still be used on a 20 pin connector on the motherboard, you just don't use the other 4 pin plug thats usually seperate at the end of the plug. The power supply is usually only held in place with 4 screws on the outside of the tower.
The main power connector to the motherboard has a little clip on the side of the plug that you have to press in to remove, it's like a little hook to stop it comming loose. There may also be a black and yellow wire 4 pin plug near the pocessor heatsink on fan, that also has a clip to press.It's not a hard job, just take your time and don't apply to much pressure when connecting the new leads to the board.
Feb 05, 2012 | Fujitsu Computers & Internet
I NEED TO HELP WIRING MY COMPAQ HOME COMPUTER
Set all items up ready to be installed Plug in your mouse and keyboard into the back of the tower. If u are using the old style connectors these have pins and will also be colour coordinated so you know where to plug into tower. They will have a notch inside so plug in carefully so not to break pins. If they are USB connections they will be square at the end and u will see where these plug in at the back of the tower these do not have colour coordination as u can plug in anywhere. Next your VGA cable, this is the cable that looks the same both ends with 15 pins in it. One end goes into your monitor and the other into the back of the tower these are shaped so they only fit in one way, again caution that you do not force in as you could bend the pins. Next ensure u have the power leads into the tower and the monitor, these are the cables with a plug on one end and a female 3 hole socket at the other, u will see where these plug into both devices. Next plug into wall ensuring socket is off first Then switch on Switch on your tower....monitor should come on by itself, if not hit the power button on your monitor Voila ...done
Oct 27, 2011 | HP Compaq Evo D310 PC Desktop
My desktop tower refuses to display on the monitor i am using and i have tested the actual monitor on another computer, or a laptop to be precise, I have also made sure there is nothing underneath the...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 15, 2011 | EliteGroup P4VMM2 Motherboard
Computer is not booting up. Usual blue light over power switch is red.
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 15, 2011 | Thermaltake Wing RS 101 Case + 430W PSU:...
1997 buik lesabre,witch plugs are what number.
1-3-5 are in the back
2-4-6 are in the front.
you can also look on the coils. Each tower is marked with the corresponding cylinder (unless they have been replaced). So if the coil tower is labeled "1" and you followed that plug wire it would lead you to the number 1 cylinder.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 03, 2010 | 1997 Buick LeSabre
I dont know where the Dell 725 Printer Power Cord goes into the tower Which outlet on the tower
The Dell 725 printer power cord does NOT plug in to the tower. The Video Cable, on the other hand, plugs in to the tower's video output. Look for a connector like the one from the printer (often USB these days) to plug it in to the computer. There was a diagram that came with the computer that showed how to do all the connections, and the Power Cord does NOT plug in to the tower. USB connections are in various locations on your computer's tower, in the back and sometimes in the front too.
Nov 09, 2009 | Dell 725 InkJet Printer
Power connections for tower led's
The manual in question can be located here
http://download.intel.com/support/motherboards/desktop/sb/d1047103_en.pdf
It is a pdf file, so you will need ADOBE,
I have checked and the pinout for the front panel connectors is there.
May 24, 2009 | Intel D945GTP Motherboard
Tower won't turn on
hi try to put the monitor lead in the tower, the leads are both the same, the fuse might be out in the tower lead.
Mar 28, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
