Question about Tascam 2488 Portastudio Multitrack Recorder System
I am trying to import WAV files from Tascam HDR 2488
I am trying to import WAV files from a Tascam HDR 2488 straight into Cubase SL because we don't have enough inputs into Cubase to record a drum kit with 5 mics. (My A level class have been doing drum kit recordings and have recorded five tracks simultaneously.) It imports the tracks ok but it appears to be cutting them off if there is any period of silence in the original recording. For example, when doing two complete takes of a piece on the same track, (one after the other so as to be able to keep both tracks), it exports the first one and the second appears to be missing if there is any silence between the first and second takes. Also, if the drummer stops during the recording because the drums take a break, the WAV file is cut short. When there is a gap in the song where the drums don't play for a few bars, the rest of the WAV file just isn't there. Any suggestions?
5 Suggested Answers
  • 189 Answers
SOURCE: Tascam 2488 Recorder
The 2488 has three effects types: “Mic” effects (compression, exciter, de-esser) you use while recording or insert into a channel; multieffects (distortion, amp model, modulation effects, delay, wah, etc.); and an internal send effect (reverb, delay, chorus, pitch shift, flanger, phaser, and gated reverb).
To add effects to an already recorded track you can assign the effect using the internal send loop for the channel and then bounce the track to print a copy of the track with the effect applied.
Posted on Jan 03, 2008
  • 189 Answers
SOURCE: owners manual for tascam 2488
Manuals for the 2488 can be found here:
http://www.tascam.com/products/2488;9,16,5,19.html
2488mkII manuals are here:
http://www.tascam.com/products/2488mkii;9,16,109,19.html
Posted on Jul 08, 2008
  • 3 Answers
SOURCE: Boot Problem in TASCAM 2488
Turning the power off with out going through the shut-down process will sometimes trash the hard drive making it un readable. To force format of hard drive hold down the shut down, send, shift and quick routing keys at the same time then turn power on. This will format the HD. When finished the display will show "Factory initalize complete" "please power off" NOTE you will lose every thing on the HD including the demo song.
Posted on Mar 05, 2009
  • 189 Answers
SOURCE: Making Midi Files for Importing to Tascam 2488
You should always work in wav format if possible because there is a loss of quality with mp3 which is a compression format in which bits are lost in order to compress the file size.
There are a number of wav editors available which will allow you to load a stereo wav and then save it as a mono wav. The free one I use is called Audacity.
When working with FL or Reason I will sometimes import files to the Tascam, or I will take the outputs from my PCs sound card and line them into the tacams inputs and record them live. I only tend to do this with programs (like synths) where I am using an external midi keyboard and can play live what I want to record.
With basic drum pattern tracks I'll usually create them on the PC, save as wav, convert to mono, and then import to a track on the Tascam.
hope this helps.
bd.
Posted on Jun 25, 2009
MY PC wont recognize my Tascam Portastudio device2488, i have Vista
Tascam 2488:
I use Vista and my 2488 MK1.
When you plug in the USB cable from the 2488 into your Vista PC, Vista will always say 'not recognised'.
You do not need any PC drivers for the 2488. On the Tascam 2488, go to 'Menu', then 'Disk', then 'USB Open/Close', then click 'Yes'.
On your PC the 2488 will appear as a new hard drive in the 'Computer' folder, called HDR2488.
You'll see three folders in there: WAVE, SMF and BACKUP.
Use the WAVE folder to import and export WAV files, the SMF folder to import midi files to the 2488, and the BACKUP folder is where you can import and export Backup files to and from the 2488.
Hope this helps!
May 09, 2012 | Tascam 2488 Portastudio Multitrack...
I want to sing over disk soundtrack.I have tascam neo.Please tell me how to do that,Thank you
The best way to accomplish this would involve ripping the sountrack from disk first using your PC to create a wav file and then importing the resulting stereo wav file into a pair of tracks on the 2488 NEO.
The process for ripping would depend on whatever software you use to rip from the CD (lots of free ones available out there) and the process to import a stereo wave into the 2488 NEO would be detailed in your 2488 manual on pages 81 and 81.
Hope this helps.
bd.
Oct 07, 2009 | Tascam 2488 Portastudio Multitrack...
hope this helps.
bd.
Jun 25, 2009 | Tascam 2488 Portastudio Multitrack...
How do i import my rap beats into my tascam 2488
You must first mix down your beat to a .wav in mono (not stereo, or .mp3), from there go to the menu options to import audio from cd.
Mar 18, 2009 | Tascam 2488 Portastudio Multitrack...
16 bit 44.1khz monaural wav format files
I'll assume first that you have wav files on your PC that you'd like to import into your 2488 to use as percussion tracks.
You'll have to convert those files on the PC first into mono wav files. The 2488 can handle 16 or 24 bit so the bitrate shouldn't really be a problem. (It will also automatically truncate a larger bitrate down, but you should really dither the files rather than let them truncate... another topic).
You can use Audacity (free) to convert stereo wav files to mono wav (audacity will also dither for you).
Once your files are converted and saved on the PC, on the 2488 open the USB connection from the DISK menu. (This assumes you already have a usb cable connected between your PC and your 2488.) You will see a device appear on your filelist called HD_2488 or something like that with a drive letter. Copy your mono wav files into the WAV directory on the 2488 USB device.
Then on the 2488 press 'exit' to close the USB and from the WAV IN/OUT menu choose 'USB import'. You should see the WAV files listed. If those files are not mono waves you won't even see them listed. Select the file(s) and press enter to import. You'll be prompted to choose which track to import them to.
That's pretty much it.
bd.
Feb 20, 2009 | Tascam 2488 Portastudio Multitrack...
Dp-o2 wont Import wav files from my pc
For wav files to be imported to the DP2 have to be 'mono' wav files. The DP-02 won't even show stereo waves in the fat area. So make sure you are converting any stereo wav files into mono first. That's usually the problem. They should also be 44.1 khz sampling frequency and 16 bit (I believe the DP-02 will accept a 24-bit wav, but the file will be truncated rather than dithered down to 16 bit while importing which may not be ideal for quality).
Hope this helps,
bd.
Jan 26, 2009 | Tascam 2488 Portastudio Multitrack...
Problem importing files to Tascam DP02-cf
They don't mention in the manual that in addition to being 44.4khz, 16bit, mono, the wav file also has to be at a bit rate of 705kbps. Using Audacity (freeware) you can convert most any audio file into the necessary wav format for the DP-02cf to use.
Jan 24, 2009 | Tascam 2488 Portastudio Multitrack...
Load imported songs on tascam dp02 cf
Make sure you have the song loaded first. In this case it sounds like you are importing into a new song, so make sure that you have a new song created and loaded prior to importing.
Then go to the menu by pressing the 'MENU' sutton and from there select 'WAVE' and then 'IMPORT TRACK'. You'll see the list of wav files on the fat partition of the CF media displayed. Select the wav file with your beat track on it (use the DATA DIAL or up/down arrow buttons to highlight the right wav file) and press the 'YES/ENTER' button. You'll be prompted for the track to import into. Select Track01 and press the 'Yes/Enter' button again and the WAV file will be read and inported into track 1.
Please note that the wav file should be a 44.1 kHz, 16-bit and a mono wav before trying to import it. If the beat track was created as a stereo wav you'll have to go into a wav editor like Audacity and resave the file as a mono wav file first. Also for a wav with a bit rate higher than 16-bit, the DP-02 is going to truncate the bits rather than dither and this might effect quality adversly so you might want to make sure that the file is properly saved as 16-bit prior to attempting an import to avoid this.
Hope this helps.
bd.
Jan 10, 2009 | Tascam 2488 Portastudio Multitrack...
I can't import midi files
There shouldn't be any compatibility problems, especially since you can transfer files one way already. You might want to make sure any wav files you are trying to import to tracks on the 2488 are saved as 'mono' waves rather than 'stereo'. The 2488 won't import a stereo wav file.
Another problem sould be naming. Try to stick to the old dos 8.3 naming standard (xxxxxxxx.xxx) for any files which you wish to import.
Hope this helps.
bd.
Dec 24, 2008 | Tascam 2488 Portastudio Multitrack...
2488 to pro tools
There is no way to 'sync' with protools from the 2488. In order to use your 2488 tracks in protools you have to first export your tracks as wav files and move them to your computer via usb and then import them into protools.
To get Protools files into your Tascam 2488 you'll have to export your Protools files into mono wav files first. They must also have a sampling rate of 44.1KHz and can be either 16 or 24 bit. Then load these files into your 2488 via usb and import them into tracks on the 2488.
Nov 21, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
194 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
