Question about JVC HR-A592U S-VHS VCR
Cancelling a Timer Recording
After setting a timer recording, I cannot cancel it. Is there anyway to do this.
  • Joe1962 Jan 26, 2008
    Actually, the button to press (based on info sent from JVC) is to press the "timer" button until the timer setting is cancelled.
    Thanks for the response leo2.
  • 619 Answers
Hi , to cancel just push the record push button .
Posted on Jan 21, 2008
Timer mode is locked on vcr
You must have set a timer record. Press the button that sets a timer recording and cancel them. If you have the manual check what it says if you don't have a manual Panasonic do have PDF of most videos free. IF you can't clear try the factory reset opition.
Jan 14, 2013 | Panasonic 4-Head VCR PV-V4525S
I have the timer light alone one and cant get the cd player to go on please help me
UNset the Timer control. On Page 40 of the manual...
Cancelling the timer setting in the timer stand-by mode:
1 Press the CLOCK/TIMER button.
2 Within 10 seconds, press the '<< << or >> >>' button to select
"ONCE" or "DAILY", and press the MEMORY button.
3 Within 10 seconds, press the '<< << or >> >>' button to select
"ONCE OFF" or "DAILY OFF", and press the MEMORY button.
Timer will be cancelled (the setting will not be cancelled).
May 18, 2011 | Sharp CD-SW330 Shelf System
The power light is not coming on,only some timer light
May 08, 2011 | Sharp CD-SW330 Shelf System
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
• After timer recording is completed, the VCR turns off
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
Press SET –/+ to select one of
the program lines, then press
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
Aug 28, 2010 | JVC Televison & Video
How do I get timed recording to stop recording
Usually, if you press stop or cancel, you'll stop it. If you want it to stop recording at a specific time, try pressing timer on your remote, and from there, you should be able to adjust settings and times
Jul 10, 2009 | Toshiba W522 VHS VCR
You can schedule for automatic recording, specifying the start time
and end time of recording. When the timer-controlled recording
completes, the setting is released.
In Menu mode selection... SET, On, OFFAfter selecting SET, press the PLAY button to set the time to start the recording.
Apr 09, 2009 | Olympus VN-2100PC Digital Voice Recorder
Eject dvd doesn'start recording
This sometimes happens when a disk is not formatted prior to recording .. the DVD is telling you it cant record on it at the time you want because it would have to format first and then start recording so missing the times you have set .
Best thing to do is use re- recordable discs only and format prior to use then the dvd should start straight away .
If not then the set has a serious read problem and requires looking at by a qualified engineer ... Regards Vortash
Jan 30, 2009 | LG RH266 Recorder
Won't timer record
- Does it have a tape inserted?
- Is the clock set?
- Is VCR off? (has to be off to be in timer mode for many VCRs)
- Is it recording but just plays back blank or does it not even start?
- If recording blank, make sure you are giving it a signal (Is your monitor hooked to the VCR output?)
- If timer doesn't start double check timer settings - they can be very tricky.
Nov 06, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
65 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
