Question about British Telecom Response 75 Digital Answering Machine
When testing the outgoing message the volume seems
BT Response 75 Answerphone
When testing the outgoing message via the OGM button the volume seems fine (and at maximum). However, when a call is made to trigger the answerphone, the outgoing message is barely audible as is the incoming message. I'd be really grateful if anyone knows how to sort this out.
  • 945 Answers
Http://www2.bt.com/static/i/media/pdf/response_75_userguide.pdf
If you click on the above , go to p.11,12 on setting the volume .
I agree with everything you say the only thing I can add is you may not be setting the volume correctly see note on p12.
Hope i`ve helped.
Posted on Dec 10, 2009
Can you record your own message on a bt response 75
Hi
Your BT response 75 has 2 built in responses depending upon whether it is set to Ansaphone or Answer only. How to do it is all clearly described in the manual which can be downloaded from here:
http://btsupport.custhelp.com/ci/fattach/get/388827/1219393992/redirect/1/session/L2F2LzEvdGltZS8xNDE5OTM1MzY5L3NpZC96Ymt6X2FibQ==
and saved to your computer for future reference. It is in pdf format and can be read using Adobe Acrobat Reader. The page you require for reading about the outgoing message is p11 of he manual, which is p13 of the pdf file.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 30, 2014 | BT Response 75 Plus Answering Machine...
I need a user manual for a Cable and Wireless CWT2100 answerphone, Thanks Anne
I have the same phone. To record a message, press Menu - press down arrow keys until you get to Record Outgoing Message - Press and hold down Menu again to Record. You record handsfree. I have a problem with the quality of the recorded message, it is very hard to hear it, there is a lot of background noise.
If you want to revert back to the pre-recorded message, do all of the above as far as recording the message but instead of actually recording a message, lift the handset and it reinstates the pre-recorded message.
To listen to the message you have recorded, Press Menu, click on down arrow keys as far as OGM and press Menu again to play the message.
Oct 29, 2011 | Lands Phones
Bought second hand i how do I change the answer phone message to mine?
Hello. I have located the owner manual for your phone and I will provide the link at the end of this response. If all you wish to do is change the outgoing message to your own, do the following:
The OGM is your announcement to the caller and may be up to 2 minute in length. If
you choose not to record your own OGM, the caller will hear a prerecorded OGM. Use
your OGM to advise the caller to begin talking after a beep is heard. For example:
“Hello, we are unable to take your call right now, please leave a message after the beep,
and we’ll return your call as soon as possible. Thank you for calling.”
Recording your OGM
1. Press .
2. The total number of (new) recorded ICM’s will now be announced.
3. Press 8 to stop playback.
4. Press 4 5.
5. Record your OGM.
6. Press 8 to stop recording.
7. Your OGM will be repeated after a few seconds. Repeat the same procedure if
you wish to change the OGM. Any old OGM will automatically be erased when
a new one is recorded.
Here is the link I promised: http://www.doro.com/global/businessunit/dorocare/support/imagesdownloads
please rate my answer. thanks. Regards, Joe
Dec 07, 2009 | Doro 830R Cordless Phone
Resetting the voice message on the answerphone - betacom DAS 100
I solved the problem through trial and error. I held down the OGM button until a beep occurred, then I spoke into the machine, then I think I pressed Play. It took a few tries, but eventually the result was wholly satisfactory!
Nov 23, 2009 | Lands Phones
One tel magma 300 - can't change message on answerphone
1) Press the 'tape' symbol to access the answering machine mode.
2) Press 9 then 1 for 'answer and record'.
3) Whe you hear a 'beep' speak your message. Whilst recording the display shows REC OGM1 or REC OGM2
4) Press 5 to stop recording. Your message is played back to you
5) Press 'tape' symbol to exit.
To check your Out Going Message (OGM)
1) Press 'tape' symbol
2) Press 6 then 2 and the message is played back.
Jan 26, 2009 | GE 29888GE1 Digital Answering Machine
NEED TO RECORD NEW ANSWERPHONE MESSAGE ON ONETEL OT150
To record a new OGM, on the Onetel OT150
Press "menu" on the base unit, then "up" once to record OGM 1 or twice to record OGM 2.
Press "OK" The existing OGM will begin to play. Whilst this is playing press and hold "MEMO"
Record your message, speaking close to the base unit. Press "stop" (square) when finished.
If you decided you don't like your message then, repeat the process above but when it tells you to record your own message press "stop" (Square) and the default will be reset.
Jun 11, 2008 | Cable_and_wireless CWD4901 Cordless...
Instructions for model 1188
Hi Diana - To record your outgoing message, hold down your ogm button ( outgoing message) for two seconds and it will ask you to record a message. To play back your message, just push the same button and it will play your message. If you don't like it just do it again. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks and have a good day.
Jeff
Jun 11, 2008 | BellSouth Digital Answering System 2006C...
Online manual
Hi - took me ages to work out without the manual, but when you're in the answerphone menu (described above), press 9 (record OGM) then either 1 or 2 (1 for OGM 1 and 2 for OGM2), speak your message, then press 5 (stop), the message will automatically replay, then you're sorted
BRIAN
Dec 27, 2007 | Lands Phones
British Telecom Response 75 Digital Answering Machine Logo
459 people viewed this question
Top British Telecom Lands Phones Experts
honeybun1986
David Burbee
David Burbee
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
