Question about LG KS660 Cell Phone
My phone loses bluetooth connection as soon as I try to connect a call
Lg tone keeps losing connection
Bluetooth wireless signal can be blocked by your body and even by your head. Try orienting yourself so that the audio source is directly in line with the bluetooth antenna in the headset.
Mar 26, 2014 | LG Stereo Wireless Bluetooth Headset Tone...
I cannot connect my bluetooth on kenxinda m1 when
Try to delete all paired devices. MAYBE, there is no vacant room for new searches.
Nov 04, 2013 | Cell Phones
Plantronics k100 loses connection and reconnects mid call how to solve this problem
First, try deleting the K100 out of your phone and, if you can, remove the battery from your phone. Once the phone reboots, try pairing the K100 back up to the phone and see if that resolves the issue.
Good luck from Headsets Direct!
Nov 28, 2011 | Plantronics K100 Bluetooth Headset
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
My ck-7w kit is connected in my van ford ranger
sounds like the 12v+ cable (blue wire) may be lose, the kit is designed to switch off when the engine is off to save battery... the blue wire controles this. with regards to the bluetooth... make sure the box all the wire go to for the car kit is not behind any metal frame or anything that could block radio waves.
Jun 12, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
My bluetooth does not get turn on.....
hi try to switch off ur mobile for sometime and then try connecting ur blutooth device. if still problem exists u can add the other persons bluetooth device in ur mobile and u can transfer datas
Jan 19, 2009 | Sony Ericsson Z550i Cellular Phone
No sound on receiver or keypad after using Bluetooth in car
you should take it to a mobile shop and have them reinstalled the device for you.
Dec 22, 2008 | Motorola Mobility RAZR V3
I lose my Bluetooth connection, and the problem is with the phone
You will need now to take the phone and have the firmware reflash in the phone.
Dec 10, 2008 | Motorola Mobility RAZR V3
Bluetooth "device out of range or powered off"
I had lots of trouble too. I thought it was my phone. Well here's what you do. First off remove the device completely from your phone. Turn off the phone and take the battery off so it can re-boot. When the phone is powered back up put your bluetooth in pairing mode and get it back on your phone. It should connect without any problems. Now....here is the trick. When you want to disconnect the device(bluetooth) from your phone don't turn it off on your phone. Shut the actual power off on your bluetooth. The phone will recognize this and disconnect the device. The only thing left on your phone will be the bluetooth icon. Being the icon still on your phone it is still in discovery mode and can overtime use up your battery life searching for a device. This is when you can go to your phone and turn off the bluetooth. On your NV 2 go to your bluetooth menu and just use your left softkeyto turn it off. Now there is no connection whatsoever. And to turn it back on do the opposite. Go to your bluetooth menu and turn on your bluetooth. You will see the bluetooth icon. Now you power up the bluetooth and it will connect as soon as it get the signal. This took me 2 weeks of trial and error and other stuff but I am happy now and I hope this solves any bluetooth problems...
Sep 16, 2008 | Plantronics Explorer 220 Bluetooth Headset...
LG KS660 Cell Phone Logo
95 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
