Question about Zanussi FJS1225W Front Load Washer
Door won't open and no error lights
Switched on machine and the door lock was locking/unlocking (you could hear is clicking and the light on the door switched on and off). Put a load in (I know stupid!), and now the door is locked. Can not open it at all.
Can then set the parameters for a wash, but when press start, it doesn't! So have dirty clothes in a locked washing machine and no way to get them out or clean them!! HELP!
All buttons seem to work (apart from Start), and switching on and off at mains does not help. No error codes to be seen.
Has the locking mechanism jammed or is it a new control board or something else?
    Sergeant:
  • 236 Answers
Sounds like the door interlock is manfunctioning.
Posted on Jan 20, 2008
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
How do I get washing machine door to unlock?
The error F26 does indicate a fault in the door switch circuit. See the image below for a complete listing of what can cause this error. There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close. One thing to try first before scheduling service or replacing the part is to check the connections on the door switch.
Unplug the washer first and remove the lower access panel and reach up to the door lock and try to feel for the connections and make sure they're tight.
If you need further help, reach me via phone at https://www.6ya.com/expert/timothy_c6f309c0f75b6f43
Jun 16, 2014 | Whirlpool duet Washing Machines
Hoover Nextra HNWF 3135 Door Not Locking
1) since you do not have any error code, because you do not mentione, we must shure you have problem with the switch door, test for open or defective and replace, Test the wires loose, or broken wires.
God bless you
Jun 28, 2012 | Washing Machines
Door ajar light on and locks keep locking and unlocking
need to gain access to the BCM to see which door the module is seeing open. the locks won't lock with key in ignition and a door is "open"
Jun 09, 2012 | 1997 Chrysler Town & Country
LG WM3431 door won't unlock
did you unplug it,leave it unplugged for 5 minutes and plug it back in,if it's to hard to get to plug flip the breaker and leave the power off for 5 minutes or longer when you power it up again the door should unlock.here's a link to check hope it helps
https://www.google.com/search?q=lg+front+load+washer+how+to+manually+open+a+locked+door&oq=lg+front+load+washer+how+to+manually+open+a+locked+door&aqs=chrome..69i57.21935j0j8&sourceid=chrome&ie=UTF-8#kpvalbx=1
Dec 29, 2017 | LG WM3431 Front Load Washer / Dryer
Washer. door lock wont lock. I hear a click click, like it's locked, but the indicator lock light is not on, then a couple seconds later I hear another click click like it's unlocking and then...
the actual door lock switch inside the wall of your washer where the door clips in has most likely burnt out or a piece has broken out of it i have found the only way to fix this problem is to replace the door lock switch
Jun 07, 2011 | LG WM-2277HW Front Load Washer
My washer says du and it wont come on! the door lock keeps clicking like its tring to lock but cant
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 16, 2010 | Whirlpool Washing Machines
Front load washer. Door will not unlock get error code "do" or FL. Door lock light is not on but door is locked and wont unlock. You csn hear a buzz as the lock energizes but does not unlock. Allready...
Sturdy little door, isn't it? Make sure you don't have extra water in the machine, as this will cause the door to not unlock. With that done,unplug your washer. If you can get the top of the machine off and reach down the front of the washer, you should see the latch mechanism. Push this down. Door should unlock. Now. Buy a new latch assemby.
Mar 16, 2010 | Maytag MAH8700A Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
229 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
