Question about Zenith VCS442 VHS VCR
ZENITH VCR TAPE KEEPS EJECTING
My Zenith VRE4222C VCR tape player keeps ejecting the tape. I have tried to look inside to see if something is amiss, but it looks okay to me. This just started yesterday and has been working fine up to now.
Can you suggest what I should do ?
Thanks
Nancy
  • Anonymous Mar 01, 2008
    Same problem with a Sony
Happened to me last nite wi 2 old tapes - the end of the tape came off the right wheel when it rewound - that was the cause - look up how to fix tapes by taking the casette apart - only thing I cant find is a picture of how the tape will feed between the heads inside he case since i suspect the tape will have fully rewound
Posted on May 26, 2008
  • 979 Answers
Got pets or young ones? This problem just smacks of having something lodged inside. Could also have come from a label coming off inside, too...accordianman
Posted on Jan 21, 2008
  • magmom24 May 12, 2011
    Solved my vcr problem. After scanning other problems I asked my husband if the label was still on the last tape he used. He hadn't bothered to tell me that he was using a new tape and that sheet of labels was missing from the box. The sheet was in the vcr. Grabbed a flashlight, took it out and now my prerecorded tape works fine. Thanks to accordianman who suggested looking for a label in the machine.
Hi Nancy
1 does the vcr display ERR message on front
try a different tape if only to trouble shoot
if this works the first tape got the tension buggerd
sometimes this happens when the tape rewinds too tight.
2 unplug vcr give a little tilt sound loose or rattle inside?
its probably a hot wheels car you'll have to disassemble
start off remove shroud slowly i hope you've unplugged
it already remember how it goes back together
don't bump or touch the heads those are the silver round things
@ front of the tape port if you bump these no movie tonight.
don't touch the little cylinder things on the board either
they can zap you
remove obstruction reasemble watch a vid!!
now that you have taken apart you're vcr please keep in mind
never take apart a television set or microwave ect...... even unplugged they store enough electricity to kill a person.
good luck hope this helps. Jm.
Posted on Mar 20, 2008
6ya staff
SOURCE:
Why does vcr/dvd vr2945 keeps ejecting the vhs tape?
ELECTRO MED SERVICES is partially correct with his answer but I'm pretty sure it's not going to be that complicated. First unplug the unit remove the cover and use 90% isopropal alcohol on a cotton swab or q-tip and clean off all of the metal pins that stick up and ride against the tape while it plays, then clean off the big rubber roller that pinches the tape to pull the tape at the correct speed. this is where most often the problem lies. the tape will get sticky and will bind up slightly. Then a there's a sensor on the left side that puts tension on the tape, if that sensor feels the tape is being pulled to hard and has no slack it will shut the player down and eject the tape. Another thing try another tape, that tape may have some hard rolling hubs or spindles. You can also try fast forwarding the tape to the end and then rewind it to make sure its not just rewound with something rubbing inside the tape case it's self. Sometimes the tape case will get deformed over years and it will rub on the tape spools inside and it will cause that sensor to trip when the tape starts to become hard to pull through the player. Also you can clean the big silver head but be careful no make sure you leave no residue on it. look at it with a magnifiying glass to make sure it's cleaned and free of any residue. 1 last thing that happens also is the automatic tape head cleaner will act up and cause problems, you can easily just remove that from the player and see if thats the culprit.
May 01, 2014 | GoVideo Go Video DVD/VCR Combo
Tape keeps ejecting
You can check tape player for any type of object lodged in it. Maybe unplug and turn upside down to here anything inside. Or even any broken tape that come off inside. The only other thing is that the belts inside are worn and will not put device back in play mode.
Dec 22, 2007 | Sony SLV-N55 VHS VCR
Stuck tape -- Zenith model VR4176
Remove the top cover to see the tape and get at it. Remove it there using plastic tools, not metal.
Dec 15, 2013 | Zenith Televison & Video
A vhf tape got stuck in the machine. I could see the tape itself was caught on some moving prongs. now i don't know the proper setting for the prongs and cannot get any vhs tapes to play.
Hi, if VHS tape is in you have only one solution..to disassemble DVD/VCR ..Can you do it ? you may try !!t
Here's how to do it..
* 1 Turn off the COMBO. and unplug it.
* 2 Remove the 4x screws off COMBO on the sides and take off the DVD/VCR casing.
* 3 Look for the Tape which messed up with VCR transport mechanism ,try to release tape of the transport with your hand..
* 4 Since EJECT feature works with power only ,while you keep the tape off from transport plug the device to power and turn it on..Don't worry,you will see the eject mechanism starts moving back on forth,keep the tape off it and let it eject..
* 5.When tape is out .If it destroyed badly normally you should not use it however if the recording in is valuable for you you can cut the chewed portion and
splice it back together .(Pls see the video included...How to fix a broken VHS tape.)
* 6 While it is open,place another Tape to see if mechanism works properly. and eject it...
* 7 Replace the casing and the screws. Plug the player in and turn it on. Now player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
http://www.youtube.com/watch?v=Q1PJWA2KGyg
Mar 13, 2011 | Philips DVD740VR DVD Player/VCR
I put a vhs tape in an the vcr turns off by it self a green light keeps flashing by where it says cst in. I have a Hitachi DVD/VCR COMBO DV-PF2U. I also can not get the tape out
Unplug the power supply for thirty seconds and plug back in, this will reset the processor and might eject the tape. If this fails the next step is remove the top of the combo unit this will give access to the vcr tape, if the tape is spewed in the machine and wrapped around the video head and other mechanical parts use scissors to cut the tape and carefully removing the particles, press power to eject the tape for normal operation. However! if the vcr tape is okay, there may be a loading problem, broken drive belt, bad idler assembly to name a few, this is where a technician will be needed but may not justify cost.
Jan 23, 2011 | Hitachi DV-PF2U DVD Player/VCR
I cannot get my vhs tape to eject and i don't want to take it apart.
Try taking out the power cable from wall and the plug it back in and keep hitting eject if it does not want to then unfortunatly there is noway to get it out unless it was forced out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 28, 2009 | RCA DRC8335
SONY VCR: Keeps ejecting video tape
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
VCR continually tries to eject the tape after it is inserted
If you have cleaned the head with a good head cleaner and you are still having a problem...the belt is probably worn. A good head clean should fix the problem.
Mar 18, 2009 | Zenith VR4127 VCR
Zenith VCS442 VHS VCR Logo
1,080 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
