Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Need an ignition and key - Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Caddilac ignition locked
You need a new ignition switch lock cylinder. You must first read the resistance of the key to order this part. It is the little wire embedded in the black plastic near the shank of the key, you need a Digital volt-ohm meter to read it.
Jul 08, 2016 | 1998 Cadillac Seville
Program a key fob 98 Cadillac cateria
So good news and bad news. Bad news is the remote portion for a 1998 Cadillac Catera Key Fob requires profressional programming. We suggest using a locksmith, they should save you some money compared to the dealer.
The good news is if you need to program another transponder key, you can do that yourself. Get a spare key cut and simply follow the instructions below:
If you need to order a key or remote you can order them online and save even more money: https://www.keylessentryremotefob.com/Cadillac-Catera-Remotes-and-Keys-s/5113.htm
· Switch ignition ON with master key to be programmed
· System LED will illuminate
· After approximately 10 minutes system LED will switch OFF
· Switch ignition OFF
· Wait 5 seconds
· Wait 5 seconds
· After Approximately 10 minutes system LED will switch OFF
· Wait 5 seconds
· Start engine
· New master key now programmed
· Erase stored trouble codes
· Replacement parts caan also be programmed using diagnostic equipment
· NOTE: The vehicle learns the key transponder information on the ignition switch transition from OFF to CRANK. Ignition must be turned OFF before attempting to start the vehicle
· Insert master key into ignition switch
· Remove master key
· Within 10 seconds insert new key
· New key now programmed
· NOTE: A maximum of 10 keys can be programmed using the master key
Feb 15, 2012 | 1998 Cadillac Catera
How I take out my ignition switch without the key.
hi.
the ignition units on all modern cars are designed so they cannot be removed without the key.
you normally need to turn the ignition to position I or II before you can remove the ignition.
without the key, you would normally need to change the steering lock assembly.
also, the key in most new cars has a security chip inside the key itself to confirm the identity of the key itself, and if you replace the key, you would normally need to have the ignition module reprogrammed to accept any new keys.
without a key, you will almost certainly need to get a professional to sort this out.
Apr 11, 2011 | 1996 Ford Thunderbird LX
I have two remotes, both needs to be reprogram, how do i do that whithout take to the dealer
hi, sometimes this is easy. put key in ignition turn key to IGNITION. DO'nt START IT. leave ignition ON for 3 seconds. then turn OFF . take key OUT of IGNITION wait 3 seconds and replace ignition key turn key to ignition. this is key recognition. some cars do and some cars do'nt. try this. gerry
Sep 13, 2010 | 2001 Volvo S40
2001 blazer. Lost the key. Had a new key made. When I turn it over a security light flashes on the dash. Someone told me there is a key reader in the ignition that some how needs to be reset. Is this true...
hi, because the key is not been recognised. you will have to switch the ignition ON leve it 3 seconds switch ignition OFF take key out from ignition for 3 seconds replace key in ignition swich ignition ON for key to be recognised with the unit under the steering colomn. if this don't work. you need the key programed. gerry
Sep 08, 2010 | 2001 Chevrolet Blazer
If i change my ignition after a break in do i need a new key for the doors and ignition too
If the door lock is undamaged then it's fine to use the old key in the door and the new key with the ignition - you then have 2 separate keys for ignition and door -
I dont quite understand the question... could you word it fidderently,
You said you "changed my ignition" - which parts of the ignition?
Jan 22, 2010 | 2000 Nissan Xterra
2000chevy malibu keyless entry problem need help
1. Close the vehicle doors.
2. Turn ignition to the ON position then OFF.
3. Remove key from the ignition.
4. Press and hold the driver side door lock switch in the UNLOCK position
until step 8.
5. Insert the ignition key into the ignition lock cylinder and remove the key.
(Do not turn the ignition key in the lock cylinder)
6. Insert the ignition key into the ignition lock cylinder and remove the key.
7. Insert the ignition key into the ignition lock cylinder.
Leave key in the ignition cylinder.
8. Release the door lock switch. The vehicle will sound three beeps in order
to verify the Program Mode has been activated.
9. Press the LOCK and UNLOCK buttons together on the keyless remote and
hold unitl the vehicle beeps twice to verify that the keyless remote has been
successfully programmed. This may take approximately 15 seconds.
10. Perform the previous step (9) to program up to four keyless remotesm, including
any old ones.
11. Remove the ignition key to exit Program Mode.
Thanks for using Fixya - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 22, 2009 | 2000 Chevrolet Malibu
Car was stolen ignition was ripped out of 2002 grandam, now car won't start with ignition and security light keeps flashing
groan.....gunna need a bit more info. but i'll try. What portion of the ignition was ripped out? The tumbler + switch? If so, you might need to get the car's system resent to recognize that it has a new ignition put in. Sime vehicles have a theft prevention system in place to prevent the vehicle from running if its been hot wired. Your best bet would be to replace the damaged ignition components (You did not mention if you did or not). If it still doesn't work after you have replced all of the ignition components. You can try to reset the vehicle (doesn't work on all) disconnect negative battery terminal and go back into vehicle and press down the brake pedal for about 30 seconds then reconnect battery and try it....good luck, hope this helps
Aug 17, 2009 | 2002 Pontiac Grand Am
Ignition alarm will not stop 97 ford f150
The key switch usually breaks or wears out and makes contact. It is on the lock cylinder. This would cause the chime to not come on, or stay on. Sounds like the switch is bad.
1997 F-150/250 Warning Chime, Key-In-Ignition The key-in-ignition chime warns that the key is still in the ignition when the driver's door is ajar. The key-in-ignition warning chime will sound when:
  • GEM: Driver door is ajar, the ignition switch is in the OFF/LOCK or ACC position and the keys are in the ignition.
  • CTM: Driver door is ajar, the ignition switch is in the OFF/LOCK, ACC or RUN position and the keys are in the ignition.
The key-in-ignition warning chime will stop sounding when:
  • Driver door is closed.
  • Key is removed from the ignition.
  • GEM: Ignition switch is switched to the RUN position.
The key-in-ignition warning chime inputs are:
  • Ignition switch RUN position (battery potential on both RUN and RUN/ACC inputs).
  • Ignition switch ACC position (battery potential on RUN/ACC input only).
  • Key-in-ignition switch (grounded with key-in-ignition, open circuit with key-out).
  • LH door ajar switch (open circuit with door closed, grounded with door ajar).
This is a pic for a 98, could not find one for 97 which may be the older style which is more prone to break.
Feb 14, 2009 | 1998 Ford F150 Regular Cab
Code to program my key fob
Here are the program instructions
2. Turn OFF the ignition.
3. Remove the key from the ignition.
4. Press and hold the driver side door lock switch in the UNLOCK position.
5. Insert the ignition key into the ignition lock cylinder and remove the key. (Do not turn the ignition key in the lock cylinder.)
6. Insert the ignition key into the ignition lock cylinder and remove the key. (Do not turn the ignition key in the lock cylinder.)
7. Insert the ignition key into the ignition lock cylinder. (Do not turn the ignition key in the lock cylinder.) Leave the ignition key in the ignition lock cylinder.
8. Release the door lock switch. The vehicle will sound three beeps in order to verify the Program Mode has been activated.
9. Press the LOCK and UNLOCK buttons together on the keyless entry transmitter and hold until the vehicle beeps twice to verify that the transmitter has been successfully programmed (this take approximately 15 seconds).
10. Perform the previous step to program up to four transmitters (including your old ones).
11. Remove the ignition key in order to exit the Program Mode
Oct 25, 2008 | 1999 Oldsmobile Intrigue
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
46 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
