Question about Euro-Pro 6131 Mechanical Sewing Machine
Why won't my needle pick up the bobin thread?
  • 96 Answers
The bobbin case may not be in correct position or completely threaded sometimes the thread will slip out of placemment in the bobbin case
Posted on Dec 13, 2009
My needle will not pick up the bobin thread
Install a brand new needle. Verify the needle is installed with the flat side facing the correct direction.
If it still will not pick up the bobbin thread, most like the machine is out of time. Search for sewing machine timing or take it for service.
Apr 25, 2017 | Sewing Machines
I have kanmore sewing machine its not stiches at all one time noise & stop stiches thered not pick up for bobin its not come out.
Wow. If I understand your attempt at English. Your machine made a noise and now won't sew or pick up the bobbin thread.
First change your needle and make sure it's full inserted and correctly oriented in the needle bar. Do a test stitch on scrap fabric.
If you still have problems.. check the timing. The shuttle hook should just be starting to pass the needle scarf when the needle is at the lowest point of travel.
I hope that helps you. Good luck.
Aug 20, 2012 | Kenmore 15218 Mechanical Sewing Machine
The needle won't pick up the thread from the bobin. everything is threaded correctly help!
check your needle and turn it the other way from how you have it.that will correct your problem or the loose the knob that hold the needle and pull out the needle a little out more.then you tighten the knob back.good luck.
Mar 06, 2011 | Brother LS-2125 Mechanical Sewing Machine
I CANNOT PICK UP THREAD FROM BOBIN TO NEEDLE. I HAVE CORRECT THREAD ON MACHINE AND BOBBIN-BOBIN IS IN CORRECT NEEDLE IS CORRECT. THE MACHINE I HAVE IS THE 3230 ELNA AND it SEEM TO BE SOMETHING WRONG WITH...
* Try to hold the end of the top thread towards to the back of the machine while you turn the hand wheel towards you .* Have the tension on top set to four.
* Check the bobbin tension. It should be set to set to four. This is an equivalent pull with the above tension.
*If this doesn't work the machine will need to be "timed" properly. Your local repairman can help.
Sep 04, 2017 | Elna 3210 Mechanical Sewing Machine
It can't pick up the thread out to sew
Make sure that you have a tail on the bobin thread when in place and a tail on the needle thread, hold the needle thread and turn the wheel to bring up the bobin thread before trying to sew
Aug 13, 2010 | Sewing Machines
Bottom thread not picking up for 4500 series,,,tried new needle.new bobin,new thread,,pliz help
The most common reason the bottom thread won't pick up is because the needle is inserted wrong. Check that the needle is inserted with the flat side of the needle shank is facing away from you.
Robbie
Aug 09, 2010 | Toyota SE-06 Mechanical Sewing Machine
Needle not picking up bobbin thread. Seems threaded properly. lsd-1 (classic) Problem occurred after needle hit something perhaps the the cap spring which had some marks on it but no real damage. ...
change the needle, if bent it may skip, use top thread while holding to pull thru, turn bobin around to turn in oposite dirrection, bobins usually turn in 1 correct dirrection
Sep 28, 2009 | Sailrite Sewing Machines
Upper thread not being picked up by bobin thread
Is the under thread getting all bunched up?
Mar 23, 2009 | Sewing Machines
Bobbin not picking up through the needle part of the machine
thread only shows the bobbin thread when i sew and needle thread also please e-mail me the attachment instructions. marybellroberts@msn.com
Oct 14, 2008 | Singer 3116 Simple
Euro-Pro 6131 Mechanical Sewing Machine Logo
97 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
