Don't know if it's the same problem i had but its maybe worth a try. Canon MP160
My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print. Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Check that there is no paper in the fuser section (The hot area) as the paper maybe jammed in there also check that the paper size is ok and the paper stops are correctly against the paper finally remove paper tray and clean the paper pickup roller with meths and wipe dry.
Hi we have an extened warranty on out Sharp 16661 all in one. We moved office's and now we can get...
(More)
Hi we have an extened warranty on out Sharp 16661 all in one. We moved office's and now we can get the scanner or fax to work. The photo copier and the printer works
I have reviewed a previous solution you gave regarding reseting the drum counter on my printer. Your...
(More)
I have reviewed a previous solution you gave regarding reseting the drum counter on my printer. Your procedure was: Press c interrupt c interrupt within 15sec display goes off enter 24 press start button enter 7 press start button 000 blinks press ca to exit from the program or restart the machine. I cannot make this work, please help me understand the interrupt? Is that a space of time, a button on the machine, etc. I appreciate any advise on this matter.
I have replaced the drum but do not know how to reset the counter
I don't understand the interrupt,...
(More)
I don't understand the interrupt, I can't make the procedure work? Please help.
